Trying to recover a partition
simonsayssurf
#1 Post by simonsayssurf »
Hello. I have a 2gig external Fantom Drive Greendrive. The drive was accidentally used when testing some Dell backup software which wrote out a couple of partitions and nothing more. When I do a deeper search with Intel, I see a 3rd partition. I get a message that says "The harddisk seems too small!" Then shows "The following partition can't be recovered" as seen in the attached log.
The partitions Recovery and OS are the ones the Dell backup utility wrote out.
Any guidance is appreciated. I'm hoping to avoid data carving as there are a lot of jpegs and mp3s on this drive.
Log file:
Mon May 25 18:48:58 2020
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1023549636608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=786432000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1999610314752
Disk /dev/sda - 1024 GB / 953 GiB - CHS 124519 255 63, sector size=512 - NVMe THNSN51T02DUK NV, S/N:0008_0D02_0013_297F., FW:4101
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - FANTOM ST32000542AS, S/N:5XW149W6, FW:2.10
Disk /dev/sdb - 2000 GB / 1863 GiB - FANTOM ST32000542AS
NTFS at 0/32/33
NTFS at 95/188/30
1 * HPFS - NTFS 0 32 33 95 188 29 1536000 [RECOVERY]
2 P HPFS - NTFS 95 188 30 243201 45 44 3905488896 [OS]
NTFS at 0/32/33
filesystem size 1536000
mft_lcn 64000
mftmirr_lcn 2
NTFS, blocksize=4096, 786 MB / 750 MiB
NTFS at 95/188/30
filesystem size 3905488896
mftmirr_lcn 2
NTFS, blocksize=4096, 1999 GB / 1862 GiB
file_pread(5,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(5,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(5,8,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(5,8,buffer,3907030912(243201/108/44)) lseek err Invalid argument
file_pread(5,6,buffer,3907031042(243201/110/48)) lseek err Invalid argument
file_pread(5,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(5,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(5,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(5,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(5,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(5,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
NTFS at 0/32/33
mft_lcn 64000
mftmirr_lcn 2
NTFS at 95/188/29
mft_lcn 64000
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 786 MB / 750 MiB
NTFS at 95/188/30
mftmirr_lcn 2
NTFS at 243200/254/63
filesystem size 3907024002
mft_lcn 2
mftmirr_lcn 244189000
HPFS - NTFS 0 1 1 243200 254 63 3907024002
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
mft_lcn 2
HPFS - NTFS 243200 254 63 486401 253 62 3907024002
This partition ends after the disk limits. (start=3907024064, size=3907024002, end=7814048065, disk end=3907029168)
NTFS at 243201/45/44
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 1999 GB / 1862 GiB
file_pread(5,8,buffer,3907029183(243201/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,3907029311(243201/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,3907029439(243201/85/20)) lseek err Invalid argument
file_pread(5,8,buffer,3907029567(243201/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,3907029695(243201/89/24)) lseek err Invalid argument
file_pread(5,8,buffer,3907029823(243201/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,3907029951(243201/93/28)) lseek err Invalid argument
file_pread(5,8,buffer,3907030079(243201/95/30)) lseek err Invalid argument
file_pread(5,8,buffer,3907030207(243201/97/32)) lseek err Invalid argument
file_pread(5,8,buffer,3907030335(243201/99/34)) lseek err Invalid argument
file_pread(5,8,buffer,3907030463(243201/101/36)) lseek err Invalid argument
file_pread(5,8,buffer,3907030591(243201/103/38)) lseek err Invalid argument
file_pread(5,8,buffer,3907030719(243201/105/40)) lseek err Invalid argument
file_pread(5,8,buffer,3907030847(243201/107/42)) lseek err Invalid argument
file_pread(5,8,buffer,3907030975(243201/109/44)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4000 GB / 3726 GiB)
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
NTFS at 0/32/33
NTFS at 95/188/30
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 64000
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
5 dr-xr-xr-x 0 0 0 25-May-2020 16:55 .
5 dr-xr-xr-x 0 0 0 25-May-2020 16:55 ..
37 dr-xr-xr-x 0 0 0 27-Nov-2013 02:44 $RECYCLE.BIN
42 dr-xr-xr-x 0 0 0 25-May-2020 16:55 System Volume Information
35 dr-xr-xr-x 0 0 0 25-Nov-2013 20:21 recovery
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 64000
mftmirr_lcn 2
Status: OK
Status: OK
NTFS at 0/32/33
NTFS at 95/188/30
NTFS at 0/32/33
mft_lcn 64000
mftmirr_lcn 2
NTFS at 95/188/30
mftmirr_lcn 2
Re: Trying to recover a partition
Unfortunately data carving seems to be the only way to recover your data.
If most files are missing, enable the Expert mode in PhotoRec, after starting the recovery, force the blocksize to 512 bytes, use the defaut options otherwise (no need to unformat a FAT32 or to create an image remaining file)
