Add partition on deleted partition
karma
#1 Post by karma »
Thank you for providing Testdisk and Photorec.
After a chkdsk at Windows boot, my NTFS partition was automatically formatted by Windows (thus, NTFS formatted as NTFS), and I'd like to recover it.
It was the largest partition of the whole disk, still exists with the same name, but now contains only Windows dummy files.
As a too-late-backup, I was able to retrieve the files with Photorec, but I would like to recover the folder structure as well.
A Deeper Search on Testdisk (Ubuntu) shows:
 * HPFS - NTFS              0  32 33    12 223 19     204800
 P HPFS - NTFS             12 223 20 16817 209 32  269971456
 D HPFS - NTFS          16817 209 33 22039 124 37   83886080
 D Linux                16817 242  2 21517 114 37   75497472
 D Linux                19185  41 57 23884 169 29   75497472
 D Linux                19186  79 30 23885 207  2   75497472
 D Linux                19186 111 62 23885 239 34   75497472
 D Linux                19187  19 33 23886 147  5   75497472
 D Linux                19190  67 14 23889 194 49   75497472
 D Linux                19195 222 36 23895  95  8   75497472
 D Linux                19197 135 11 23897   7 46   75497472
 D Linux Swap           21517 147  7 22038 249 35    8376320
 D HPFS - NTFS          22039 157  7 243201  78 13 3552962560
>D HPFS - NTFS          22039 157 22 243201  78 13 3552962545
     Enter: to continue
NTFS found using backup sector, blocksize=4096, 1819 GB / 1694 GiB
The last 2 partitions seem the same.
On the first, "list files" shows the files after format.
On the last (which is selected in the above Testdisk screen) "list files" reports "Can't open filesystem. Filesystem seems damaged.".
The last partition is not shown in Quick search, and is not available in the Advanced menu (for Rebuild BS).
So, I thought:
- assuming the last partition is the filesystem before format, how do I recover it ?
- could I fix the filesystem by adjusting the CHS/geometry of the last partiton? if so, how?
- can I do Rebuild BS to the last partition? if so, how?
Regards,
Peter
Re: Add partition on deleted partition
Reading your description of the problem, I don't think the partition table has been altered, so a partition recovery will not work.
Your partition was corrupted and chkdsk "fixed" it by removing all files.
Try TestDisk, Advanced, select your NTFS partition, Undelete. If you are lucky, your lost files will be listed and you will be able to copy them.
If it doesn't work, you will have to sort the files recovered by PhotoRec.
