Partial Recovery of ext4 drive, what next? (Linux)
foggys916
#1 Post by foggys916 »
I did post some of this on the Ubuntu forums, but this is not really a Ubuntu issue.
So my daughter accidental formatted the 250GB drive in my HP machine, with a version of CENTOS using a logical volume (?). The disk had version 11.04 of Ubuntu on , with ext4 partitions.
I ran testdisk and recovered the /homes partition (separate logical partition) and another partition labelled DATA (with, funnily enough, data in it!!). However I’d really like to recover the main file system (MBR - not important) as I’d also put a directory in there with files in it.
Testdisk seems to have discovered the original Windows Vista structure (not needed) and obviously the CENTOS boot partition.
I’ve attached the full testdisk report and the graphics of the GParted programme (supplied with Ubuntu and ran from a LiveCD version of Ubuntu). The GParted programme shows the "unallocated" partitions which are the ones I would like to recover, but I assume testdisk is seeing the CENTOS boot partition and the old Windows Vista stuff and is unclear as to what is wanted??
Partition 1 image
Partition 1 image
Partition 2 image
Partition 2 image
Any further clues?
Many thanks
Steve
Mon Jul 9 18:35:47 2012
OS: Linux, kernel 3.0.0-12-generic (#20-Ubuntu SMP Fri Oct 7 14:50:42 UTC 2011) i686
Compiler: GCC 4.4
Compilation date: 2012-07-05T08:10:14
ext2fs lib: 1.41.12, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size 488397168 sectors
/dev/sda: user_max 488397168 sectors
/dev/sda: dco 488397168 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - SAMSUNG SP2504C, S/N:S09QJ1HLC42543, FW:VT100-49
Disk /dev/sdc - 8028 KB / 7840 KiB - CHS 245 2 32, sector size=512 - Generic USB CF Reader, FW:1.01
Disk /dev/sr0 - 729 MB / 695 MiB - CHS 355992 1 1 (RO), sector size=2048 - ATAPI DVD A DH16AYH, FW:YH13
Disk /dev/sda - 250 GB / 232 GiB - SAMSUNG SP2504C
Analyse Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63
1 * Linux 0 1 1 12 254 63 208782 [/boot]
2 E extended LBA 6170 1 40 30401 75 10 389275648
5 L Linux 6170 34 9 12857 247 62 107440128
X extended 13665 47 1 30401 75 10 268865614
6 L Linux 13665 48 16 30401 75 10 268865536 [DATA]
recover_EXT2: s_block_group_nr=0/12, s_mnt_count=10/4294967295, s_blocks_per_group=8192, s_inodes_per_group=2008
recover_EXT2: s_blocks_count 104388
recover_EXT2: part_size 208776
Linux 0 1 1 12 254 57 208776 [/boot]
ext3 blocksize=1024 Sparse superblock, 106 MB / 101 MiB
LVM2 magic value at 13/0/1
part_size 488183220
Linux LVM 13 0 1 30400 254 63 488183220
LVM2, 249 GB / 232 GiB
P Linux LVM 13 0 1 30400 254 63 488183220
2 P Linux LVM 13 0 1 30400 254 63 488183220
block_group_nr 3
recover_EXT2: "e2fsck -b 24577 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=3/12, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=2008
ext3 blocksize=1024 Sparse superblock Backup superblock, 106 MB / 101 MiB
part_size 488183220
BAD_RS LBA=1968055299 3122256
FAT16 <32M 122505 198 1 295059 218 13 2772081283
This partition ends after the disk limits. (start=1968055299, size=2772081283, end=445169285, disk end=488397168)
recover_EXT2: s_block_group_nr=0/283, s_mnt_count=1/30, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 9284096
recover_EXT2: part_size 74272768
Linux 2107 38 44 6730 106 32 74272768
ext4 blocksize=4096 Large file Sparse superblock Recover, 38 GB / 35 GiB
recover_EXT2: s_block_group_nr=0/283, s_mnt_count=29/30, s_blocks_per_group=32768, s_inodes_per_group=8176
Linux 2108 11 16 6731 79 4 74272768
Linux 2109 211 23 6733 24 11 74272768
FAT12 at 2725/112/12
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
FAT12 2725 112 12 2725 157 56 2880 [BOOTTEST]
recover_EXT2: s_block_group_nr=0/94, s_mnt_count=37/38, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 3105792
recover_EXT2: part_size 24846336
Linux 4623 100 22 6170 1 39 24846336
ext4 blocksize=4096 Large file Sparse superblock, 12 GB / 11 GiB
Linux Swap 6024 10 3 6803 248 21 12529648
SWAP2 version 1, 6415 MB / 6117 MiB
recover_EXT2: s_block_group_nr=0/409, s_mnt_count=24/31, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 13430016
recover_EXT2: part_size 107440128
ext4 blocksize=4096 Large file Sparse superblock, 55 GB / 51 GiB
BAD_RS LBA=2074729475 3122256
FAT16 <32M 129145 238 57 301700 4 6 2772081283
This partition ends after the disk limits. (start=2074729475, size=2772081283, end=551843461, disk end=488397168)
recover_EXT2: s_block_group_nr=0/409, s_mnt_count=20/31, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 9320 185 18 16008 144 8 107440128
ext4 blocksize=4096 Large file Sparse superblock Recover, 55 GB / 51 GiB
Linux 9322 32 55 16009 246 45 107440128
Linux Swap 12858 25 32 13665 15 30 12963824
SWAP2 version 1, 6637 MB / 6329 MiB
recover_EXT2: s_block_group_nr=0/1025, s_mnt_count=43/33, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 33608192
recover_EXT2: part_size 268865536
ext4 blocksize=4096 Large file Sparse superblock Recover, 137 GB / 128 GiB
Linux Swap 29625 46 54 30401 74 57 12468208
SWAP2 version 1, 6383 MB / 6087 MiB
Linux Swap 29636 135 4 30401 74 57 12285936
SWAP2 version 1, 6290 MB / 5998 MiB
NTFS at 29751/254/63
filesystem size 364883400
mftmirr_lcn 16
HPFS - NTFS 7039 15 1 29751 254 63 364883400
NTFS found using backup sector, blocksize=4096, 186 GB / 173 GiB
The harddisk (250 GB / 232 GiB) seems too small! (< 2481 GB / 2311 GiB)
get_geometry_from_list_part_aux head=8 nbr=3
FAT12 2725 112 12 2725 177 12 4096 [BOOTTEST]
FAT12, blocksize=512, 2097 KB / 2048 KiB
Linux Swap 6024 10 3 6803 248 37 12529664
SWAP2 version 1, 6415 MB / 6118 MiB
Linux Swap 12858 25 32 13665 15 46 12963840
SWAP2 version 1, 6637 MB / 6330 MiB
Linux Swap 29625 46 54 30401 75 10 12468224
SWAP2 version 1, 6383 MB / 6088 MiB
Linux Swap 29636 135 4 30401 75 10 12285952
SWAP2 version 1, 6290 MB / 5999 MiB
dir_partition inode=2
ext2fs_dir_iterate failed with error 1.
ext2fs_dir_iterate failed with error 2133571402.
2 drwxr-xr-x 0 0 4096 31-Jul-2011 08:41 .
2 drwxr-xr-x 0 0 4096 31-Jul-2011 08:41 ..
11 drwx------ 0 0 16384 2-May-2011 21:51 lost+found
2097153 drwxr-xr-x 1000 1000 4096 8-Jul-2012 17:56 [HOME FOLDER1 - NAME REMOVED]
131073 drwxr-xr-x 1001 1001 4096 28-Jun-2012 17:21 [HOME FOLDER2 - NAME REMOVED]
2883585 drwxr-xr-x 1002 1001 4096 30-Jun-2012 05:52 [HOME FOLDER3 - NAME REMOVED]
786433 drwx------ 0 0 4096 31-Jul-2011 08:41 .Trash-0
2 drwxr-xr-x 0 0 4096 10-Sep-2011 22:38 .
2 drwxr-xr-x 0 0 4096 10-Sep-2011 22:38 ..
130817 drwxr-xr-x 0 0 4096 10-Sep-2011 22:38 Adobe
392449 drwxr-xr-x 0 0 4096 19-Jul-2011 08:43 Adobe AIR
X 523273 -rw-r--r-- 0 0 710 24-Jun-2012 07:34 BBC iPlayer Desktop.dpkg-new
523271 drwxr-xr-x 0 0 4096 30-May-2011 11:35 google
dir_partition inode=0
2 -r-xr-xr-x 0 0 24810 7-Jan-1999 07:03 IBMBIO.COM
51 -r-xr-xr-x 0 0 30880 7-Jan-1999 07:03 IBMDOS.COM
112 -rwxr-xr-x 0 0 66785 7-Jan-1999 07:03 COMMAND.COM
245 drwxr-xr-x 0 0 0 24-Oct-2001 11:15 DRDOS
2844 drwxr-xr-x 0 0 0 30-Oct-2001 19:30 OAK
1379 drwxr-xr-x 0 0 0 24-Jun-2003 13:16 NR
1419 -rwxr-xr-x 0 0 267650 10-Oct-2002 13:08 WWBMU.EXE
389 -rwxr-xr-x 0 0 2888 24-Feb-2004 09:03 README.TXT
386 -rwxr-xr-x 0 0 1920 6-Jul-2005 13:26 DCONFIG.SYS
388 -rwxr-xr-x 0 0 582 6-Jul-2005 13:27 AUTODOS7.BAT
ext2fs_dir_iterate failed with error 2133571387.
2 drwxr-xr-x 0 0 1024 1-Jul-2012 07:21 .
2 drwxr-xr-x 0 0 1024 1-Jul-2012 07:21 ..
11 drwx------ 0 0 12288 1-Jul-2012 07:14 lost+found
2009 drwxr-xr-x 0 0 1024 1-Jul-2012 07:26 grub
X 12 -rw-r--r-- 0 0 80032 12-Mar-2009 19:06 message;4feff966
18 -rw------- 0 0 3376097 ntfs_mst_post_read_fixup_warn: magic: 0x8301671d size: 1024 usa_ofs: 605 usa_count: 12562: Invalid argument
Record 0 has no FILE magic (0x8301671d)
1-Jul-2012 07:21 initrd-2.6.18-238.el5.img
13 -rw-r--r-- 0 0 158 13-Jan-2011 21:59 .vmlinuz-2.6.18-238.el5.hmac
14 -rw-r--r-- 0 0 979708 13-Jan-2011 21:59 System.map-2.6.18-238.el5
15 -rw-r--r-- 0 0 69815 13-Jan-2011 21:59 config-2.6.18-238.el5
16 -rw-r--r-- 0 0 112421 13-Jan-2011 22:00 symvers-2.6.18-238.el5.gz
17 -rw-r--r-- 0 0 1888052 13-Jan-2011 21:59 vmlinuz-2.6.18-238.el5
Not an exFAT boot sector.
dir_partition inode=523271
Directory /google
523271 drwxr-xr-x 0 0 4096 30-May-2011 11:35 .
X 523272 drwxr-xr-x 0 0 4096 28-Jun-2012 05:30 chrome.dpkg-new
18 -rw------- 0 0 3376097 1-Jul-2012 07:21 initrd-2.6.18-238.el5.img
New options :
Dump : No
Align partition: Yes
Expert mode : No
Backup partition structure
partition_save
part_size 488183220
block_group_nr 3
part_size 488183220
