Since it is my first message, please let me introduce myself. I am a medical doctor who recently crashes his hdd (probably after using an "optimising" tool under windows 7). I love (and hate) computers since 30 years (you know: commodore 64, Amiga, i386, windows 3.10, etc...).
I must say that I am stuck for a week now, having tried a lot of different things (probably too much
Here is the problem:
Internal WD7500BPVT "scorpio" SATA disk had a boot error either, probably after intempestive reboots.
Recovery from hidden Acer partition did not work (Acer Aspire 7750G, intel i5, windows 7, 64bit)
Recovery windows 7 disk wasn't able to finalize its restoration (either the first one I made soon after the purchase, nor a second one made on another i5 computer)
Creating a Windows 7 DVD after having downloaded the official iso from microsoft also failed.
I bought a USB2-SATA interface and connected it to a Sony Vaio VPCEB3L1E (sic!). Windows considered my disk unreadable and suggested I format it (which I did not!).
At that time, I discover TESTDISK.
A was please to see 3 partitions PQSERVICE, SYSTEM RESERVED, and ACER, the one I woud like to restore.
I followed the step by step guide, but I had to stop at several time points, especially because file operations lasted four days, only for 0.10% ...
I connected the device to a macbookpro. It easily read the drive without any soft, but was not able to copy the files on its own drive...
Then I heard about DDRESCUE. I therefore installed ubuntu on another partition of the above cited VAIO and started to use the soft in order to make an image. The problem was that the transfer rate was about 10 to 30 Kb (not Mb) per second, so that my 750 Gb would not have been backed up even after a year of work.
I also try NTFSFIX, which found and restore a problem... which didn't change anything
Now about the log (and the title of the topic, which may not have to do with the real problem...)
Disk /dev/sdc - 750 GB / 698 GiB - CHS 11400 255 63
Warning: Incorrect number of bytes per sector 512 (NTFS) != 4096 (HD)
1 * HPFS - NTFS 0 4 5 261 25 20 4194304 [PQSERVICE]
2 P HPFS - NTFS 261 25 21 262 176 42 25600 [SYSTEM RESERVED]
3 P HPFS - NTFS 262 176 43 11400 34 26 178923008 [Acer]
Impossible to set a "L" state on partition 3
Although the partition was correctly listed, only some of the directories were listed in the next steps...
Another error about boot sector:
Status: OK
Status: Bad
Sectors are not identical.
Ok, I guess that's enough for a first post.
My question is: "should I try to change the number of bytes per sector"?
Thank you very much for your help
Schwarznold
