Partition write error?
PassNGrin
#1 Post by PassNGrin »
Initial context:
viewtopic.php?f=5&t=10145
viewtopic.php?f=5&t=10135
ok, so, I tried to write the partition since I didn't get an answer, then tried analysing again to see the file system type, then I finally notice the sector size mismatch warning.
after I noticed, I set the geometry setting to 512.
Turns out there were a bunch of partitions that actually counted as deleted.
I set the ones without damaged file systems to primary (whoops! checked the step by step again, should've set them to logical!) that ended up causing a write error, and the disk drive temporarily disconnected.
When it reconnected, I tried analyse again, but it didn't find anything. The Windows disk manager did list a correct partition size though.
Stay tuned for more. I'm going to try safely restarting testdisk
PassNGrin
Re: Partition write error?
#2 Post by PassNGrin »
Oh yeah, bad GPT partition entries, invalid checksum was also mentioned when I set the sector size to 512
PassNGrin
#3 Post by PassNGrin »
hm, I can't seem to set it to logical, but the files still seem to be there
maybe I'll see what I can find in the new E and F drives
PassNGrin
#4 Post by PassNGrin »
Testdisk detected a none partition type in the two new drives.
The E: drive contained my files, but the F: drive contained the recovery partition
Windows has detected these drives, but is telling me to format them.
what do I do to get these files into my computer?
PassNGrin
#5 Post by PassNGrin »
Dunno whether to use chkdsk, copy the disk, or do testdisk undelete.
I'll keep looking
PassNGrin
#6 Post by PassNGrin »
and by chkdsk I nean chkdsk /f?
PassNGrin
#7 Post by PassNGrin »
First I'll try advice from these links...
viewtopic.php?t=8067
viewtopic.php?t=5934
So chkdsk /f e: does not work on RAW drives...
PassNGrin
#8 Post by PassNGrin »
Decided to use testdisk again, and selected Intel instead of None this time:
viewtopic.php?t=50
There's a bad relative sector and a space conflict between two partitions?
Proceeding to quick search...
PassNGrin
#9 Post by PassNGrin »
The Quick Search is taking a while, but I have a question to ask:
Should I have selected the intel partition type in the beginning, even when the disk manager listed the disk as GPT? I get the feeling that I've been going about this problem wrong from the beginning...
PassNGrin
#10 Post by PassNGrin »
the quick scan listed a... Linux partition? My old drive was on a Windows computer though...
was this a result of the earlier GPT write that had an error?
Quick scan still ongoing... 10%
