Copying, please wait... What's going on?
peter22
#1 Post by peter22 »
Computer with Windows 7 64 bit
Boot drive is a Samsung SSD 840 with 240GB, NTFS formatted
Due to an poorly written disk imaging program. the image of
a floppy disk was not written on A: as requested but on C: and,
according to tha program, had failed.
However, next morning the PC had crashed and reboot failed due to a not
accessible boot device.
To recover I did the following:
- Attach an USB3 external 4 TB hard disk
- Boot Knoppix Live DVD
- Examining /dev/sda with GParted I found a FAT partition which contained the floppy content
Partition size was 232.89GiB. Used space was 1.35MiB, unused 52.50 KiB
- copied /dev/sda to a file 'corruptssd'
- used TestDisk on the image file of the SSD
I could find my NTFS partition of drive C and started copying files, each
directory in root separately. This worked well and the resulting files
are usable (at least the pictures and text files I looked at).
The I started to copy the directory 'Users' .
Its now copying for over 12 hours, at the moment it
displays "Copying, please wait... 74622 ok, 0 failed"
The number increases by one about every 10 minutes.
When using lsof to check which file is processed in my recovery directory,
I can see its always the same big file.
Using the file manager of Knoppix I see that the
recovered "Users" directory contains 79579 files but
TestDisk shows only 74622 as copied.
Why is there a difference?
TestDisk increases the number of copied files but the
number of files in "Users" remains the same.
What is TestDisk doing here?
Is there a way to have TestDisk show the file name, size and
already copied bytes of the file currentlz recovering_
Re: Copying, please wait... What's going on?
It will be faster to use TestDisk to fix the NTFS boot sector (Advanced, Boot, RebuildBS, List and if you see your files, Write and confirm).
