Recover Single Partition of Working Drive
DonRon
#1 Post by DonRon »
I have a 4TB HDD on it is 3.5+TB of data. The HDD had a single partition on it. This drive is in working condition and was working up until the moment I had deleted the volume. Earlier today using windows diskpart I accidentally deleted the volume using windows diskpart. It was a dumb mistake caused by lack of attention. Using various software I'm still able to see data on the drive. It seems only the partition is damaged. Here is a list of the actions I took to the best of my memory. I panicked a bit which didn't help the situation.
1. Deleted volume on 4TB drive
2. Ran EaseUS data recovery to make sure data was still on the drive. The files were still prevent with the correct name and size. I only let it go to 1% which that only took a few minutes.
3. Ran testdisk, followed instructions in PDF to recover a partition. Test disk correctly found 1 partition. I selected the option to write the partition and followed the instructions to reboot. Upon reboot the drive was not mounted by windows.
4. Tried to map the drive to windows using partition manager. I made such to NOT format the drive. Windows saw the drive as RAW format.
5. Ran EaseUS data recovery to make sure data was still on the drive. Files are still prevent with the correct name and size. I only let it go to 1% which that only took a few minutes.
6. Ran testdisk, testdisk again. This time it was several partitions. I selected analyze and waited. The analyze process was taking an extremely long time It took a bit over 10 minutes to 1000/484000~ progress. Cancelled testdisk as I'm not sure if this is normal.
6. Finally determined I should seek assistance so now I'm posting here.
I'm not sure what my options are for next steps in recovering the partition and data.
Output from testdisk from action 2 above. I snipped from of the lseek err Invalid argument lines due to post size limit. The complete log has been uploaded to pastebin.
Thu Jun  4 15:14:56 2020
TestDisk 7.2-WIP, Data Recovery Utility, May 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=31876710400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=31876710400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249415690752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=31351373824
Disk /dev/sda - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD40EFRX-68N32N0, S/N:WD-WCC7K3ZJ0FJ6, FW:82.00A82
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 850 EVO 250GB, S/N:S2R5NX0H687756R, FW:EMT02B6Q
Disk /dev/sdc - 31 GB / 29 GiB - CHS 3875 255 63, sector size=512 - ADATA USB Flash Drive, S/N:AA00000000000489, FW:1100
Disk /dev/sda - 4000 GB / 3726 GiB - WDC WD40EFRX-68N32N0
Partition table type: EFI GPT
Analyse Disk /dev/sda - 4000 GB / 3726 GiB - CHS 486401 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7814037167 (expected 7814037167)
hdr_lba_start=34
hdr_lba_end=7814037134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
NTFS at 16/113/34
filesystem size           7813771264
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=135266304, part_size=4000650887168, sector_size=512
NTFS at 16/113/34
mftmirr_lcn               2
     MS Data                   264192 7814035455 7813771264
     NTFS, blocksize=4096, 4000 GB / 3725 GiB
file_pread(4,2,buffer,3519070208(486401/86/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519070208(486401/86/22)) lseek err Invalid argument
file_pread(4,2,buffer,3519070209(486401/86/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519070211(486401/86/25)) lseek err Invalid argument
file_pread(4,1,buffer,3519070212(486401/86/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519070213(486401/86/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519070214(486401/86/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519070215(486401/86/29)) lseek err Invalid argument
file_pread(4,1,buffer,3519070216(486401/86/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519070217(486401/86/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519070218(486401/86/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519070219(486401/86/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519070220(486401/86/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519070221(486401/86/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519070222(486401/86/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519070223(486401/86/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519070224(486401/86/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519070225(486401/86/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519070226(486401/86/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519070227(486401/86/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519070228(486401/86/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519070229(486401/86/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519070230(486401/86/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519070231(486401/86/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519070232(486401/86/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519070233(486401/86/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519070234(486401/86/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519070235(486401/86/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519070236(486401/86/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519070237(486401/86/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519070238(486401/86/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519070239(486401/86/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519070240(486401/86/54)) lseek err Invalid argument
file_pread(4,1,buffer,3519070241(486401/86/55)) lseek err Invalid argument
file_pread(4,1,buffer,3519070242(486401/86/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519070243(486401/86/57)) lseek err Invalid argument
file_pread(4,1,buffer,3519070244(486401/86/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519070245(486401/86/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519070246(486401/86/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519070247(486401/86/61)) lseek err Invalid argument
file_pread(4,1,buffer,3519070248(486401/86/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519070249(486401/86/63)) lseek err Invalid argument
file_pread(4,1,buffer,3519070250(486401/87/1)) lseek err Invalid argument
file_pread(4,1,buffer,3519070251(486401/87/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519070252(486401/87/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519070253(486401/87/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519070254(486401/87/5)) lseek err Invalid argument
file_pread(4,1,buffer,3519070255(486401/87/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519070256(486401/87/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519070257(486401/87/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519070258(486401/87/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519070259(486401/87/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519070260(486401/87/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519070261(486401/87/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519070262(486401/87/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519070263(486401/87/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519070264(486401/87/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519070265(486401/87/16)) lseek err Invalid argument
file_pread(4,1,buffer,3519070266(486401/87/17)) lseek err Invalid argument
file_pread(4,1,buffer,3519070267(486401/87/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519070268(486401/87/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519070269(486401/87/20)) lseek err Invalid argument
file_pread(4,1,buffer,3519070270(486401/87/21)) lseek err Invalid argument
file_pread(4,1,buffer,3519070271(486401/87/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519070272(486401/87/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519070273(486401/87/24)) lseek err Invalid argument
file_pread(4,1,buffer,3519070274(486401/87/25)) lseek err Invalid argument
file_pread(4,1,buffer,3519070275(486401/87/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519070276(486401/87/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519070277(486401/87/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519070278(486401/87/29)) lseek err Invalid argument
file_pread(4,1,buffer,3519070279(486401/87/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519070280(486401/87/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519070281(486401/87/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519070282(486401/87/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519070283(486401/87/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519070284(486401/87/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519070285(486401/87/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519070286(486401/87/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519070287(486401/87/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519070288(486401/87/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519070289(486401/87/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519070290(486401/87/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519070291(486401/87/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519070292(486401/87/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519070293(486401/87/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519070294(486401/87/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519070295(486401/87/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519070296(486401/87/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519070297(486401/87/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519070298(486401/87/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519070299(486401/87/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519070300(486401/87/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519070301(486401/87/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519070302(486401/87/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519070303(486401/87/54)) lseek err Invalid argument
file_pread(4,1,buffer,3519070304(486401/87/55)) lseek err Invalid argument
file_pread(4,1,buffer,3519070305(486401/87/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519070306(486401/87/57)) lseek err Invalid argument
file_pread(4,1,buffer,3519070307(486401/87/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519070308(486401/87/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519070309(486401/87/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519070310(486401/87/61)) lseek err Invalid argument
file_pread(4,1,buffer,3519070311(486401/87/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519070312(486401/87/63)) lseek err Invalid argument
file_pread(4,1,buffer,3519070313(486401/88/1)) lseek err Invalid argument
file_pread(4,1,buffer,3519070314(486401/88/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519070315(486401/88/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519070316(486401/88/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519070317(486401/88/5)) lseek err Invalid argument
file_pread(4,1,buffer,3519070318(486401/88/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519070319(486401/88/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519070320(486401/88/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519070321(486401/88/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519070322(486401/88/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519070323(486401/88/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519070324(486401/88/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519070325(486401/88/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519070326(486401/88/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519070327(486401/88/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519070328(486401/88/16)) lseek err Invalid argument
file_pread(4,1,buffer,3519070329(486401/88/17)) lseek err Invalid argument
file_pread(4,1,buffer,3519070330(486401/88/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519070331(486401/88/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519070332(486401/88/20)) lseek err Invalid argument
file_pread(4,1,buffer,3519070333(486401/88/21)) lseek err Invalid argument
file_pread(4,1,buffer,3519070334(486401/88/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519070335(486401/88/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519070336(486401/88/24)) lseek err Invalid argument
file_pread(4,1,buffer,3519070337(486401/88/25)) lseek err Invalid argument
file_pread(4,1,buffer,3519070338(486401/88/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519070339(486401/88/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519070340(486401/88/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519070341(486401/88/29)) lseek err Invalid argument
file_pread(4,1,buffer,3519070342(486401/88/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519070343(486401/88/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519070344(486401/88/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519070345(486401/88/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519070346(486401/88/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519070347(486401/88/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519070348(486401/88/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519070349(486401/88/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519070350(486401/88/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519070351(486401/88/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519070352(486401/88/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519070353(486401/88/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519070354(486401/88/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519070355(486401/88/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519070356(486401/88/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519070357(486401/88/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519070358(486401/88/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519070359(486401/88/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519070360(486401/88/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519070361(486401/88/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519070362(486401/88/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519070363(486401/88/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519070364(486401/88/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519070365(486401/88/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519070366(486401/88/54)) lseek err Invalid argument
file_pread(4,1,buffer,3519070367(486401/88/55)) lseek err Invalid argument
file_pread(4,1,buffer,3519070368(486401/88/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519070369(486401/88/57)) lseek err Invalid argument
file_pread(4,1,buffer,3519070370(486401/88/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519070371(486401/88/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519070372(486401/88/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519070373(486401/88/61)) lseek err Invalid argument
file_pread(4,1,buffer,3519070374(486401/88/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519070375(486401/88/63)) lseek err Invalid argument
file_pread(4,1,buffer,3519070376(486401/89/1)) lseek err Invalid argument
file_pread(4,1,buffer,3519070377(486401/89/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519070378(486401/89/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519070379(486401/89/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519070380(486401/89/5)) lseek err Invalid argument
file_pread(4,1,buffer,3519070381(486401/89/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519070382(486401/89/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519070383(486401/89/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519070384(486401/89/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519070385(486401/89/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519070386(486401/89/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519070387(486401/89/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519070388(486401/89/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519070389(486401/89/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519070390(486401/89/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519070391(486401/89/16)) lseek err Invalid argument
file_pread(4,1,buffer,3519070392(486401/89/17)) lseek err Invalid argument
file_pread(4,1,buffer,3519070393(486401/89/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519070394(486401/89/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519070395(486401/89/20)) lseek err Invalid argument
file_pread(4,1,buffer,3519070396(486401/89/21)) lseek err Invalid argument
file_pread(4,1,buffer,3519070397(486401/89/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519070398(486401/89/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519070399(486401/89/24)) lseek err Invalid argument
file_pread(4,1,buffer,3519070400(486401/89/25)) lseek err Invalid argument
file_pread(4,1,buffer,3519070401(486401/89/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519070402(486401/89/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519070403(486401/89/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519070404(486401/89/29)) lseek err Invalid argument
file_pread(4,1,buffer,3519070405(486401/89/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519070406(486401/89/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519070407(486401/89/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519070408(486401/89/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519070409(486401/89/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519070410(486401/89/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519070411(486401/89/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519070412(486401/89/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519070413(486401/89/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519070414(486401/89/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519070415(486401/89/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519070416(486401/89/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519070417(486401/89/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519070418(486401/89/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519070419(486401/89/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519070420(486401/89/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519070421(486401/89/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519070422(486401/89/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519070423(486401/89/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519070424(486401/89/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519070425(486401/89/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519070426(486401/89/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519070427(486401/89/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519070428(486401/89/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519070429(486401/89/54)) lseek err Invalid argument
file_pread(4,1,buffer,3519070430(486401/89/55)) lseek err Invalid argument
file_pread(4,1,buffer,3519070431(486401/89/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519070432(486401/89/57)) lseek err Invalid argument
file_pread(4,1,buffer,3519070433(486401/89/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519070434(486401/89/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519070435(486401/89/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519070436(486401/89/61)) lseek err Invalid argument
file_pread(4,1,buffer,3519070437(486401/89/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519070438(486401/89/63)) lseek err Invalid argument
file_pread(4,1,buffer,3519070439(486401/90/1)) lseek err Invalid argument
file_pread(4,1,buffer,3519070440(486401/90/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519070441(486401/90/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519070442(486401/90/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519070443(486401/90/5)) lseek err Invalid argument
file_pread(4,1,buffer,3519070444(486401/90/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519070445(486401/90/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519070446(486401/90/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519070447(486401/90/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519070448(486401/90/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519070449(486401/90/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519070450(486401/90/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519070451(486401/90/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519070452(486401/90/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519070453(486401/90/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519070454(486401/90/16)) lseek err Invalid argument
file_pread(4,1,buffer,3519070455(486401/90/17)) lseek err Invalid argument
file_pread(4,1,buffer,3519070456(486401/90/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519070457(486401/90/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519070458(486401/90/20)) lseek err Invalid argument
file_pread(4,1,buffer,3519070459(486401/90/21)) lseek err Invalid argument
file_pread(4,1,buffer,3519070460(486401/90/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519070461(486401/90/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519070462(486401/90/24)) lseek err Invalid argument
file_pread(4,1,buffer,3519070463(486401/90/25)) lseek err Invalid argument
file_pread(4,1,buffer,3519070464(486401/90/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519070465(486401/90/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519070466(486401/90/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519070467(486401/90/29)) lseek err Invalid argument
file_pread(4,1,buffer,3519070468(486401/90/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519070469(486401/90/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519070470(486401/90/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519070471(486401/90/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519070472(486401/90/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519070473(486401/90/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519070474(486401/90/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519070475(486401/90/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519070476(486401/90/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519070477(486401/90/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519070478(486401/90/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519070479(486401/90/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519070480(486401/90/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519070481(486401/90/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519070482(486401/90/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519070483(486401/90/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519070484(486401/90/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519070485(486401/90/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519070486(486401/90/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519070487(486401/90/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519070488(486401/90/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519070489(486401/90/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519070490(486401/90/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519070491(486401/90/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519070492(486401/90/54)) lseek err Invalid argument
file_pread(4,1,buffer,3519070493(486401/90/55)) lseek err Invalid argument
file_pread(4,1,buffer,3519070494(486401/90/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519070495(486401/90/57)) lseek err Invalid argument
file_pread(4,1,buffer,3519070496(486401/90/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519070497(486401/90/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519070498(486401/90/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519070499(486401/90/61)) lseek err Invalid argument
file_pread(4,1,buffer,3519070500(486401/90/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519070501(486401/90/63)) lseek err Invalid argument
file_pread(4,1,buffer,3519070502(486401/91/1)) lseek err Invalid argument
file_pread(4,1,buffer,3519070503(486401/91/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519070504(486401/91/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519070505(486401/91/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519070506(486401/91/5)) lseek err Invalid argument
file_pread(4,1,buffer,3519070507(486401/91/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519070508(486401/91/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519070509(486401/91/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519070510(486401/91/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519070511(486401/91/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519070512(486401/91/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519070513(486401/91/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519070514(486401/91/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519070515(486401/91/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519070516(486401/91/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519070517(486401/91/16)) lseek err Invalid argument
file_pread(4,1,buffer,3519070518(486401/91/17)) lseek err Invalid argument
file_pread(4,1,buffer,3519070519(486401/91/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519070520(486401/91/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519070521(486401/91/20)) lseek err Invalid argument
file_pread(4,1,buffer,3519070522(486401/91/21)) lseek err Invalid argument
file_pread(4,1,buffer,3519070523(486401/91/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519070524(486401/91/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519070525(486401/91/24)) lseek err Invalid argument
file_pread(4,1,buffer,3519070526(486401/91/25)) lseek err Invalid argument
file_pread(4,1,buffer,3519070527(486401/91/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519070528(486401/91/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519070529(486401/91/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519070530(486401/91/29)) lseek err Invalid argument
file_pread(4,1,buffer,3519070531(486401/91/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519070532(486401/91/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519070533(486401/91/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519070534(486401/91/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519070535(486401/91/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519070536(486401/91/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519070537(486401/91/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519070538(486401/91/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519070539(486401/91/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519070540(486401/91/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519070541(486401/91/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519070542(486401/91/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519070543(486401/91/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519070544(486401/91/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519070545(486401/91/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519070546(486401/91/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519070547(486401/91/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519070548(486401/91/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519070549(486401/91/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519070550(486401/91/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519070551(486401/91/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519070552(486401/91/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519070553(486401/91/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519070554(486401/91/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519070555(486401/91/54)) lseek err Invalid argument
file_pread(4,1,buffer,3519070556(486401/91/55)) lseek err Invalid argument
SNIPPED DUE TO POST SIZE LIMIT
file_pread(4,1,buffer,3519071850(486401/112/26)) lseek err Invalid argument
file_pread(4,8,buffer,3519069881(486401/81/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519069881(486401/81/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519069938(486401/82/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519071851(486401/112/27)) lseek err Invalid argument
file_pread(4,8,buffer,3519069882(486401/81/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519069882(486401/81/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519069939(486401/82/5)) lseek err Invalid argument
file_pread(4,1,buffer,3519071852(486401/112/28)) lseek err Invalid argument
file_pread(4,8,buffer,3519069883(486401/81/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519069883(486401/81/12)) lseek err Invalid argument
file_pread(4,11,buffer,3519069930(486401/81/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519071853(486401/112/29)) lseek err Invalid argument
file_pread(4,8,buffer,3519069884(486401/81/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519069884(486401/81/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519069941(486401/82/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519071854(486401/112/30)) lseek err Invalid argument
file_pread(4,8,buffer,3519069885(486401/81/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519069885(486401/81/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519069942(486401/82/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519071855(486401/112/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519069872(486401/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(4,8,buffer,3519069886(486401/81/15)) lseek err Invalid argument
file_pread(4,11,buffer,3519069933(486401/81/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519071856(486401/112/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519069894(486401/81/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519069944(486401/82/10)) lseek err Invalid argument
file_pread(4,1,buffer,3519071857(486401/112/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519069895(486401/81/24)) lseek err Invalid argument
file_pread(4,1,buffer,3519069945(486401/82/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519071858(486401/112/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519069875(486401/81/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519069896(486401/81/25)) lseek err Invalid argument
file_pread(4,1,buffer,3519069946(486401/82/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519071859(486401/112/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519069876(486401/81/5)) lseek err Invalid argument
file_pread(4,8,buffer,3519069890(486401/81/19)) lseek err Invalid argument
file_pread(4,11,buffer,3519069937(486401/82/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519071860(486401/112/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519069877(486401/81/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519069898(486401/81/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519069948(486401/82/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519071861(486401/112/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519069878(486401/81/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519069899(486401/81/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519069949(486401/82/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519071862(486401/112/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519069879(486401/81/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519069900(486401/81/29)) lseek err Invalid argument
file_pread(4,1,buffer,3519069950(486401/82/16)) lseek err Invalid argument
file_pread(4,1,buffer,3519071863(486401/112/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519069880(486401/81/9)) lseek err Invalid argument
file_pread(4,8,buffer,3519069894(486401/81/23)) lseek err Invalid argument
file_pread(4,11,buffer,3519069941(486401/82/7)) lseek err Invalid argument
file_pread(4,1,buffer,3519071864(486401/112/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519069902(486401/81/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519069952(486401/82/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519071865(486401/112/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519069903(486401/81/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519069953(486401/82/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519071866(486401/112/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519069904(486401/81/33)) lseek err Invalid argument
file_pread(4,1,buffer,3519069954(486401/82/20)) lseek err Invalid argument
file_pread(4,1,buffer,3519071867(486401/112/43)) lseek err Invalid argument
file_pread(4,8,buffer,3519069898(486401/81/27)) lseek err Invalid argument
file_pread(4,11,buffer,3519069945(486401/82/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519071868(486401/112/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519069906(486401/81/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519069956(486401/82/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519071869(486401/112/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519069886(486401/81/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519069907(486401/81/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519069957(486401/82/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519071870(486401/112/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519069887(486401/81/16)) lseek err Invalid argument
file_pread(4,1,buffer,3519069908(486401/81/37)) lseek err Invalid argument
file_pread(4,1,buffer,3519069958(486401/82/24)) lseek err Invalid argument
file_pread(4,1,buffer,3519071871(486401/112/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519069888(486401/81/17)) lseek err Invalid argument
file_pread(4,8,buffer,3519069902(486401/81/31)) lseek err Invalid argument
file_pread(4,11,buffer,3519069949(486401/82/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519071872(486401/112/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519069889(486401/81/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519069910(486401/81/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519069960(486401/82/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519071873(486401/112/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519069890(486401/81/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519069911(486401/81/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519069961(486401/82/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519071874(486401/112/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519069891(486401/81/20)) lseek err Invalid argument
file_pread(4,1,buffer,3519069912(486401/81/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519069962(486401/82/28)) lseek err Invalid argument
file_pread(4,1,buffer,3519071875(486401/112/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519069892(486401/81/21)) lseek err Invalid argument
file_pread(4,8,buffer,3519069906(486401/81/35)) lseek err Invalid argument
file_pread(4,11,buffer,3519069953(486401/82/19)) lseek err Invalid argument
file_pread(4,1,buffer,3519071876(486401/112/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519069893(486401/81/22)) lseek err Invalid argument
file_pread(4,1,buffer,3519069914(486401/81/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519069964(486401/82/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519071877(486401/112/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519069915(486401/81/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519069965(486401/82/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519071878(486401/112/54)) lseek err Invalid argument
file_pread(4,1,buffer,3519069916(486401/81/45)) lseek err Invalid argument
file_pread(4,1,buffer,3519069966(486401/82/32)) lseek err Invalid argument
file_pread(4,1,buffer,3519071879(486401/112/55)) lseek err Invalid argument
file_pread(4,8,buffer,3519069910(486401/81/39)) lseek err Invalid argument
file_pread(4,11,buffer,3519069957(486401/82/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519071880(486401/112/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519069897(486401/81/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519069918(486401/81/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519069968(486401/82/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519071881(486401/112/57)) lseek err Invalid argument
file_pread(4,1,buffer,3519069919(486401/81/48)) lseek err Invalid argument
file_pread(4,1,buffer,3519069969(486401/82/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519071882(486401/112/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519069920(486401/81/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519069970(486401/82/36)) lseek err Invalid argument
file_pread(4,1,buffer,3519071883(486401/112/59)) lseek err Invalid argument
file_pread(4,8,buffer,3519069914(486401/81/43)) lseek err Invalid argument
file_pread(4,11,buffer,3519069961(486401/82/27)) lseek err Invalid argument
file_pread(4,1,buffer,3519071884(486401/112/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519069901(486401/81/30)) lseek err Invalid argument
file_pread(4,1,buffer,3519069922(486401/81/51)) lseek err Invalid argument
file_pread(4,1,buffer,3519069972(486401/82/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519071885(486401/112/61)) lseek err Invalid argument
file_pread(4,1,buffer,3519069923(486401/81/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519069973(486401/82/39)) lseek err Invalid argument
file_pread(4,1,buffer,3519071886(486401/112/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519069924(486401/81/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519069974(486401/82/40)) lseek err Invalid argument
file_pread(4,1,buffer,3519071887(486401/112/63)) lseek err Invalid argument
file_pread(4,8,buffer,3519069918(486401/81/47)) lseek err Invalid argument
file_pread(4,11,buffer,3519069965(486401/82/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519071888(486401/113/1)) lseek err Invalid argument
file_pread(4,1,buffer,3519069905(486401/81/34)) lseek err Invalid argument
file_pread(4,1,buffer,3519069926(486401/81/55)) lseek err Invalid argument
file_pread(4,1,buffer,3519069976(486401/82/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519071889(486401/113/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519069927(486401/81/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519069977(486401/82/43)) lseek err Invalid argument
file_pread(4,1,buffer,3519071890(486401/113/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519069928(486401/81/57)) lseek err Invalid argument
file_pread(4,1,buffer,3519069978(486401/82/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519071891(486401/113/4)) lseek err Invalid argument
file_pread(4,8,buffer,3519069922(486401/81/51)) lseek err Invalid argument
file_pread(4,11,buffer,3519069969(486401/82/35)) lseek err Invalid argument
file_pread(4,1,buffer,3519071892(486401/113/5)) lseek err Invalid argument
file_pread(4,1,buffer,3519069909(486401/81/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519069930(486401/81/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519069980(486401/82/46)) lseek err Invalid argument
file_pread(4,1,buffer,3519071893(486401/113/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519069931(486401/81/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519069981(486401/82/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519071894(486401/113/7)) lseek err Invalid argument
file_pread(4,8,buffer,3519069925(486401/81/54)) lseek err Invalid argument
file_pread(4,11,buffer,3519069972(486401/82/38)) lseek err Invalid argument
file_pread(4,1,buffer,3519071895(486401/113/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519069933(486401/81/62)) lseek err Invalid argument
file_pread(4,1,buffer,3519069983(486401/82/49)) lseek err Invalid argument
file_pread(4,1,buffer,3519071896(486401/113/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519069913(486401/81/42)) lseek err Invalid argument
file_pread(4,1,buffer,3519069934(486401/81/63)) lseek err Invalid argument
file_pread(4,1,buffer,3519069984(486401/82/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519071897(486401/113/10)) lseek err Invalid argument
file_pread(4,8,buffer,3519069928(486401/81/57)) lseek err Invalid argument
file_pread(4,11,buffer,3519069975(486401/82/41)) lseek err Invalid argument
file_pread(4,1,buffer,3519071898(486401/113/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519069936(486401/82/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519069986(486401/82/52)) lseek err Invalid argument
file_pread(4,1,buffer,3519071899(486401/113/12)) lseek err Invalid argument
file_pread(4,1,buffer,3519069937(486401/82/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519069987(486401/82/53)) lseek err Invalid argument
file_pread(4,1,buffer,3519071900(486401/113/13)) lseek err Invalid argument
file_pread(4,1,buffer,3519069917(486401/81/46)) lseek err Invalid argument
file_pread(4,8,buffer,3519069931(486401/81/60)) lseek err Invalid argument
file_pread(4,11,buffer,3519069978(486401/82/44)) lseek err Invalid argument
file_pread(4,1,buffer,3519071901(486401/113/14)) lseek err Invalid argument
file_pread(4,1,buffer,3519069989(486401/82/55)) lseek err Invalid argument
file_pread(4,1,buffer,3519071902(486401/113/15)) lseek err Invalid argument
file_pread(4,1,buffer,3519069940(486401/82/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519069990(486401/82/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519071903(486401/113/16)) lseek err Invalid argument
file_pread(4,8,buffer,3519069934(486401/81/63)) lseek err Invalid argument
file_pread(4,11,buffer,3519069981(486401/82/47)) lseek err Invalid argument
file_pread(4,1,buffer,3519071904(486401/113/17)) lseek err Invalid argument
file_pread(4,1,buffer,3519069921(486401/81/50)) lseek err Invalid argument
file_pread(4,1,buffer,3519069992(486401/82/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519071905(486401/113/18)) lseek err Invalid argument
file_pread(4,1,buffer,3519069943(486401/82/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519069993(486401/82/59)) lseek err Invalid argument
file_pread(4,1,buffer,3519071906(486401/113/19)) lseek err Invalid argument
file_pread(4,14,buffer,3519069860(486401/80/52)) ReadFile The drive cannot find the sector requested.
file_pread(4,3,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(4,3,buffer,3519069921(486401/81/50)) lseek err Invalid argument
file_pread(4,8,buffer,3519069937(486401/82/3)) lseek err Invalid argument
file_pread(4,11,buffer,3519069984(486401/82/50)) lseek err Invalid argument
file_pread(4,2,buffer,3519071906(486401/113/19)) lseek err Invalid argument
file_pread(4,14,buffer,3519069861(486401/80/53)) ReadFile The drive cannot find the sector requested.
file_pread(4,2,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,3,buffer,3519069875(486401/81/4)) lseek err Invalid argument
file_pread(4,3,buffer,3519069922(486401/81/51)) lseek err Invalid argument
file_pread(4,8,buffer,3519069938(486401/82/4)) lseek err Invalid argument
file_pread(4,11,buffer,3519069985(486401/82/51)) lseek err Invalid argument
file_pread(4,2,buffer,3519071907(486401/113/20)) lseek err Invalid argument
file_pread(4,14,buffer,3519069862(486401/80/54)) ReadFile The drive cannot find the sector requested.
file_pread(4,3,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,3,buffer,3519069876(486401/81/5)) lseek err Invalid argument
file_pread(4,3,buffer,3519069923(486401/81/52)) lseek err Invalid argument
file_pread(4,8,buffer,3519069939(486401/82/5)) lseek err Invalid argument
file_pread(4,11,buffer,3519069986(486401/82/52)) lseek err Invalid argument
file_pread(4,2,buffer,3519071908(486401/113/21)) lseek err Invalid argument
file_pread(4,14,buffer,3519069863(486401/80/55)) ReadFile The drive cannot find the sector requested.
file_pread(4,4,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,3,buffer,3519069877(486401/81/6)) lseek err Invalid argument
file_pread(4,3,buffer,3519069924(486401/81/53)) lseek err Invalid argument
file_pread(4,8,buffer,3519069940(486401/82/6)) lseek err Invalid argument
file_pread(4,11,buffer,3519069987(486401/82/53)) lseek err Invalid argument
file_pread(4,2,buffer,3519071909(486401/113/22)) lseek err Invalid argument
file_pread(4,14,buffer,3519069864(486401/80/56)) ReadFile The drive cannot find the sector requested.
file_pread(4,5,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,3,buffer,3519069878(486401/81/7)) lseek err Invalid argument
file_pread(4,3,buffer,3519069925(486401/81/54)) lseek err Invalid argument
file_pread(4,8,buffer,3519069941(486401/82/7)) lseek err Invalid argument
file_pread(4,11,buffer,3519069988(486401/82/54)) lseek err Invalid argument
file_pread(4,2,buffer,3519071910(486401/113/23)) lseek err Invalid argument
file_pread(4,1,buffer,3519069999(486401/83/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519071912(486401/113/25)) lseek err Invalid argument
file_pread(4,14,buffer,3519069866(486401/80/58)) ReadFile The drive cannot find the sector requested.
file_pread(4,7,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,3,buffer,3519069880(486401/81/9)) lseek err Invalid argument
file_pread(4,3,buffer,3519069927(486401/81/56)) lseek err Invalid argument
file_pread(4,8,buffer,3519069943(486401/82/9)) lseek err Invalid argument
file_pread(4,11,buffer,3519069990(486401/82/56)) lseek err Invalid argument
file_pread(4,1,buffer,3519071913(486401/113/26)) lseek err Invalid argument
file_pread(4,1,buffer,3519069951(486401/82/17)) lseek err Invalid argument
file_pread(4,1,buffer,3519070001(486401/83/4)) lseek err Invalid argument
file_pread(4,1,buffer,3519071914(486401/113/27)) lseek err Invalid argument
file_pread(4,14,buffer,3519069868(486401/80/60)) ReadFile The drive cannot find the sector requested.
file_pread(4,8,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(4,3,buffer,3519069882(486401/81/11)) lseek err Invalid argument
file_pread(4,3,buffer,3519069929(486401/81/58)) lseek err Invalid argument
file_pread(4,8,buffer,3519069945(486401/82/11)) lseek err Invalid argument
file_pread(4,11,buffer,3519069992(486401/82/58)) lseek err Invalid argument
file_pread(4,1,buffer,3519071915(486401/113/28)) lseek err Invalid argument
file_pread(4,10,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519069932(486401/81/61)) lseek err Invalid argument
file_pread(4,1,buffer,3519070003(486401/83/6)) lseek err Invalid argument
file_pread(4,1,buffer,3519071916(486401/113/29)) lseek err Invalid argument
file_pread(4,14,buffer,3519069870(486401/80/62)) ReadFile The drive cannot find the sector requested.
file_pread(4,3,buffer,3519069884(486401/81/13)) lseek err Invalid argument
file_pread(4,3,buffer,3519069931(486401/81/60)) lseek err Invalid argument
file_pread(4,8,buffer,3519069947(486401/82/13)) lseek err Invalid argument
file_pread(4,11,buffer,3519069994(486401/82/60)) lseek err Invalid argument
file_pread(4,1,buffer,3519071917(486401/113/30)) lseek err Invalid argument
file_pread(4,12,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(4,1,buffer,3519069955(486401/82/21)) lseek err Invalid argument
file_pread(4,1,buffer,3519070005(486401/83/8)) lseek err Invalid argument
file_pread(4,1,buffer,3519071918(486401/113/31)) lseek err Invalid argument
file_pread(4,1,buffer,3519069935(486401/82/1)) lseek err Invalid argument
file_pread(4,1,buffer,3519070006(486401/83/9)) lseek err Invalid argument
file_pread(4,1,buffer,3519071919(486401/113/32)) lseek err Invalid argument
file_pread(4,2,buffer,3519069885(486401/81/14)) lseek err Invalid argument
file_pread(4,8,buffer,3519069950(486401/82/16)) lseek err Invalid argument
file_pread(4,11,buffer,3519069997(486401/82/63)) lseek err Invalid argument
file_pread(4,1,buffer,3519071920(486401/113/33)) lseek err Invalid argument
file_pread(4,14,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(4,1,buffer,3519070008(486401/83/11)) lseek err Invalid argument
file_pread(4,1,buffer,3519071921(486401/113/34)) lseek err Invalid argument
   P MS Data                   264192 7814035455 7813771264
 1 P MS Data                   264192 7814035455 7813771264
write!
file_pwrite(4,1,buffer,0(0/0/1)) write err Permission denied
Re: Recover Single Partition of Working Drive
Something prevents TestDisk rewriting the partition table. Try disabling your antivirus before starting testdisk.
DonRon
#3 Post by DonRon »
cgrenier wrote: 06 Jun 2020, 07:23
Thanks for taking the time to respond. The only AV on this PC is windows defender. I may of had diskpart open at the time testdisk was running. It is possible diskpart had a lock on the disk. Based on your comments it seems like I would be okay trying to run testdisk again. When I run testdisk now it is taking any extremely long time during the analyzes step. Do I need to wait for it to complete? At this rate it will take about 2.5 days. I'm not opposed to waiting I just want to relay the behavior I'm seeing and confirm what to do.
