No partition found or selected for recovery/Filesystem may be damaged
mjohn911
#1 Post by mjohn911 »
Good morning. Running testdisk from UBCD on a 1 TB mechanical drive. C drive shows as RAW in second computer. Win7 shows boot sector error.
Drive is not clicking or headcrashing.
Selecting drive:
Selected Intel:
NTFS partitions are detected:
Upon pressing enter for Quick Search, it finds a FAT32 partition (odd):
I press enter to continue. It only finds a FAT32 LBA parition (maybe this is the 100 mb reserved?)
I do a Deeper Search.
Now it finds the RAW NTFS partition, but takes a very long time to scan. I abort scanning since it has found it. (It finds it immediately).
I select the 12 223 partition. I get No Partition Found. (Should I Add partition???)
I cannot view files on the partition. I can only choose Quit.
I try the utilities under Advanced.
I select Boot Utilities.
I see this:
If I select List, I see this:
I tried Rebuild BS. It went through a long scan which took several hours and did nothing.
I tried Repair MFT. It says MFT and MFT mirror are bad. Failed to repair them.
Tue Jun  9 10:15:29 2020
TestDisk 6.12, Data Recovery Utility, May 2011
OS: Linux, kernel 3.0.0-pmagic (#1 SMP Fri Jul 29 19:06:18 CDT 2011) i686
Compiler: GCC 4.5
Compilation date: 2011-05-15T12:36:01
ext2fs lib: 1.41.14, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size       1953525168 sectors
/dev/sda: user_max   1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco        1953525168 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ATA Hitachi HDS72101
Disk /dev/sr0 - 377 MB / 359 MiB - CHS 184212 1 1 (RO), sector size=2048 - Optiarc DVD RW AD-7240S
Disk /dev/sda - 1000 GB / 931 GiB - ATA Hitachi HDS72101
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
NTFS at 12/223/20
 1 * HPFS - NTFS              0  32 33    12 223 19     204800 [System Reserved]
 2 P HPFS - NTFS             12 223 20 121601  25 24 1953314816
Computes LBA from CHS for Disk /dev/sda - 1000 GB / 931 GiB - CHS 121602 255 63
search_vista_part: 1
FAT32 at 0/1/1
FAT1 : 38-238446
FAT2 : 238447-476855
start_rootdir : 476856 root cluster : 2
Data : 476856-1953519991
sectors : 1953520002
cluster_size : 64
no_of_cluster : 30516299 (2 - 30516300)
fat_length 238409 calculated 238409
FAT differs, FAT sectors=0-16/238409
FAT32 at 0/1/1
     FAT32 LBA                0   1  1 121600 254 63 1953520002 [NO NAME]
     FAT32, 1000 GB / 931 GiB
   * FAT32 LBA                0   1  1 121600 254 63 1953520002 [NO NAME]
 1 * FAT32 LBA                0   1  1 121600 254 63 1953520002 [NO NAME]
FAT32 at 0/1/1
FAT1 : 38-238446
cluster_size : 64
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 38-238446
cluster_size : 64
FAT32 at 0/1/7
     FAT found using backup sector!, 1000 GB / 931 GiB
NTFS at 0/32/33
filesystem size           204800
sectors_per_cluster       8
mft_lcn                   8533
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS, 104 MB / 100 MiB
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
     NTFS found using backup sector!, 104 MB / 100 MiB
NTFS at 12/223/20
filesystem size           1953314816
mftmirr_lcn               2
     NTFS, 1000 GB / 931 GiB
NTFS at 0/32/33
NTFS at 12/223/20
ntfs_boot_sector
NTFS at 12/223/20
NTFS at 12/223/20
mftmirr_lcn               2
Status: OK
Status: OK
Sectors are identical.
Incomplete multi-sector transfer: magic: 0xffffffff  size: 1024  usa_ofs: 48  usa_count: 1  data: 0  usn: 56927: Input/output error
Record 0 has no FILE magic (0x44414142)
ntfs_boot_sector
NTFS at 12/223/20
NTFS at 12/223/20
mftmirr_lcn               2
Status: OK
Status: OK
repair_MFT
NTFS at 12/223/20
ntfs_boot_sector
NTFS at 12/223/20
NTFS at 12/223/20
mftmirr_lcn               2
Status: OK
Status: OK
Ideas?
Re: No partition found or selected for recovery/Filesystem may be damaged
Can you try to list your files using testdisk 7.1 or 7.2-WIP (Advanced, Boot, List) ?
mjohn911
#3 Post by mjohn911 »
Thank you for the reply. I can try the new version, but was able to recover data using Photorec, and then my customer informed me that he found a backup of the information. This is good to know though.
