Found partition...kind of
thesiege
#1 Post by thesiege »
It found my partition and I am able to see my files.
But the partition seems to start on the wrong sector and I am not sure if it knows the file type.
Its inside of WD my book duo so I am not sure what to do next
https://imgur.com/a/OYAf1Lz
Re: Found partition...kind of
Press 'p'. Does TestDisk lists your files ?
Can you copy/paste the testdisk.log file content and explain what your problem is ?
