Back down the rabbit hole
skitsnygg
#1 Post by skitsnygg »
I have a 3TB WD external drive that my girlfriend knocked off a table (and likely disconnected) from the computer (os x) about three years ago. I have dove in to trying to recover the contents unsuccessfully a number of times so before starting again, I'd like to take a different approach and ask here. I''ve scoured the boards and read a plethora of information but wanted to confirm if I should be using intel (which was detected) or EFI? I know mac uses EFI for partition type and the log lists 1 EFI partition but I don't want to cancel this scan (intel) if it's not necessary as it's at 90% and it's taken me about a week to get this far as my roommates are blasting air conditioners and my building is old so the breaker keeps flipping off. If I remember correctly, the drive had 3 partitions, one was about 2TB and encrypted, a CCC backup partition (which would definitely explain the EFI) and I believe one other but I can't remember what was on it. I believe all three partitions should have been formatted HFS+. I just ran drivedx and it's showing the drive is failing with 24 pending sectors, when I ran it the other day it said status was OK. While I would love to have all the files off of this drive (it contains ~15 years of my life and I have no backup) I simply cannot wait for a ddrescue clone as the last time I tried while the partitions were still being recognized about a year and a half ago it was estimated to take over a year (I want to say three). Please advise what my best option is here, is this a pointless endeavor? Should I cancel the current scan and re-run using EFI? I'm attaching screenshots of drivedx as well as the current testdisk output. Log is below:
Wed Jun 24 15:10:06 2020
OS: Darwin, kernel 19.5.0 (Darwin Kernel Version 19.5.0: Tue May 26 20:41:44 PDT 2020; root:xnu-6153.121.2~2/RELEASE_X86_64) x86_64
Compiler: GCC 4.2
ext2fs lib: none, ntfs lib: none, reiserfs lib: none, ewf lib: none, curses lib: ncurses 5.7
Disk /dev/disk0 - 250 GB / 232 GiB - 488397168 sectors (RO), sector size=512
Disk /dev/disk1 - 240 GB / 223 GiB - 468862128 sectors (RO), sector size=512
Disk /dev/disk4 - 3000 GB / 2794 GiB - 5860467633 sectors, sector size=512
Disk /dev/rdisk0 - 250 GB / 232 GiB - 488397168 sectors (RO), sector size=512
Disk /dev/rdisk1 - 240 GB / 223 GiB - 468862128 sectors (RO), sector size=512
Disk /dev/rdisk2 - 249 GB / 232 GiB - 60998436 sectors (RO), sector size=4096
Disk /dev/rdisk3 - 239 GB / 222 GiB - 58397831 sectors (RO), sector size=4096
Disk /dev/rdisk4 - 3000 GB / 2794 GiB - 5860467633 sectors, sector size=512
Analyse Disk /dev/rdisk4 - 3000 GB / 2794 GiB - 5860467633 sectors
BAD_RS LBA=1 1339
get_geometry_from_list_part_aux head=1 nbr=2
 1 P EFI GPT                        1  732558335  732558335
BAD_RS LBA=3899900526 487
     FAT12                 3899900526 4045672820  145772295
BAD_RS LBA=7289034735 868
     HPFS - NTFS           7289034735 7697615422  408580688
This partition ends after the disk limits. (start=7289034735, size=408580688, end=7697615422, disk end=5860467633)
BAD_RS LBA=7877319339 1109
     FAT16 >32M            7877319339 10214629774 2337310436
This partition ends after the disk limits. (start=7877319339, size=2337310436, end=10214629774, disk end=5860467633)
BAD_RS LBA=7786237794 805
     FAT12                 7786237794 11854746134 4068508341
This partition ends after the disk limits. (start=7786237794, size=4068508341, end=11854746134, disk end=5860467633)
BAD_RS LBA=8233355776 289
     FAT32 LBA             8233355776 11100731871 2867376096
This partition ends after the disk limits. (start=8233355776, size=2867376096, end=11100731871, disk end=5860467633)
BAD_RS LBA=7090313893 445
     FAT16 LBA             7090313893 9543457839 2453143947
This partition ends after the disk limits. (start=7090313893, size=2453143947, end=9543457839, disk end=5860467633)
BAD_RS LBA=4270013704 822
     FAT12                 4270013704 8502432883 4232419180
This partition ends after the disk limits. (start=4270013704, size=4232419180, end=8502432883, disk end=5860467633)
BAD_RS LBA=4687949076 268
     FAT16 LBA             4687949076 4761448502   73499427
BAD_RS LBA=6642142478 612
     FAT12                 6642142478 9103067482 2460925005
This partition ends after the disk limits. (start=6642142478, size=2460925005, end=9103067482, disk end=5860467633)
BAD_RS LBA=8198211103 693
     HPFS - NTFS           8198211103 11509242939 3311031837
This partition ends after the disk limits. (start=8198211103, size=3311031837, end=11509242939, disk end=5860467633)
BAD_RS LBA=8951926337 1169
     FAT16 LBA             8951926337 10593035981 1641109645
This partition ends after the disk limits. (start=8951926337, size=1641109645, end=10593035981, disk end=5860467633)
BAD_RS LBA=6794221398 338
     HPFS - NTFS           6794221398 10937552566 4143331169
This partition ends after the disk limits. (start=6794221398, size=4143331169, end=10937552566, disk end=5860467633)
BAD_RS LBA=8355091735 588
     FAT12                 8355091735 11716184430 3361092696
This partition ends after the disk limits. (start=8355091735, size=3361092696, end=11716184430, disk end=5860467633)
BAD_RS LBA=5697254494 627
     FAT32                 5697254494 8843229160 3145974667
This partition ends after the disk limits. (start=5697254494, size=3145974667, end=8843229160, disk end=5860467633)
BAD_RS LBA=5209364167 696
     FAT32                 5209364167 7906636606 2697272440
This partition ends after the disk limits. (start=5209364167, size=2697272440, end=7906636606, disk end=5860467633)
BAD_RS LBA=8695842268 634
     FAT16 >32M            8695842268 8877981406  182139139
This partition ends after the disk limits. (start=8695842268, size=182139139, end=8877981406, disk
Re: Back down the rabbit hole
As your disk has bad sectors, you should clone your disk to a new empty disk using ddrescue.
It's really not a good idea to work on this damaged disk.
Once it's done, remove the original disk and try to recover your data from the clone.
