Custom Signature for .pln files Topic is solved
FFmaster
#1 Post by FFmaster »
Hi Everyone.
I'm trying to recover some job files by a formatted hard disk. The software works perfectly with the avaibles signatures, as .dwg, .3ds or even .3dm ( I'm an Architect ).
However, I must manage to recover any Archicad projects, the extensions are : .pln, .pla
I checked in the forum, and didn't find anything. Maybe you could say to follow the instrucions to add a custom signature but the problem is... I' m Italian, and even if I understand pretty well the english in general, I really have problems to understand this technical issues, sorry...
I hope that this issue could also help the development of the software, considering that pln are some of the essential signatures in Architecture.
Link to a Sample file :
https://drive.google.com/file/d/1FgIbS_ ... Rkp7w/view
Re: Custom Signature for .pln files
I haven't been able to access your sample files but you should be able to use the following signature
pln 0 "ROF FDB "
FFmaster
#3 Post by FFmaster »
It works! Thank you so much!
