HDD has RAW format
raz77
HDD has RAW format
#1 Post by raz77 »
Hello my current problem is an HDD that I can't recover anything from.
Its sitting in RAW format, I've already backed up all the good files with Recuva and PhotoRec. They found a massive amount of the lost data, but I'm still trying my best to recover the whole drive if possible.
Thats what it looks like when mounting it as an NTFS drive:
Testdisk even finds the right partitions!
But unfortunately, when writing these found partitions it says:
Partition: Write error
Running checkdisk on that drive
an unspecified error occurred (726166696c652e63 1b3).
an unspecified error occurred (6e74667363686b2e 1729).
Opening the file browser always shows no files at the main partition, but showing files inside the other two. Is there anything I can do, except trying to accept my situatuon? :D
Re: HDD has RAW format
There are no unused sectors between your partitions.
If your partition table is correct you will have to use a GPT type partition instead of the Intel one.
raz77
#3 Post by raz77 »
Here are the logs, the faulty drive is H: or /dev/sde
Wed Jul 15 19:49:00 2020
TestDisk 7.2-WIP, Data Recovery Utility, May 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=8589934592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=480103981056
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=8589934592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=479426772992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=748583711744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
filewin32_getfilesize(\\.\F:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=499441991680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=557842432
Disk /dev/sda - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SSD PLUS 480GB, S/N:1941B7800923, FW:UG2204RL
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - TOSHIBA MQ01ABD075, S/N:Z3K9C1PRT, FW:AX002K
Disk /dev/sdd - 8589 MB / 8192 MiB - CHS 1044 255 63, sector size=512 - Msft Virtual Disk, FW:1.0
Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512, S/N:0000000047AE, FW:0101
Drive D: - 748 GB / 697 GiB - CHS 91010 255 63, sector size=512
Drive G: - 104 MB / 100 MiB - CHS 12 255 63, sector size=512, S/N:0000000047AE, FW:0101
Drive H: - 499 GB / 465 GiB - CHS 60720 255 63, sector size=512, S/N:0000000047AE, FW:0101
Drive I: - 557 MB / 532 MiB - CHS 67 255 63, sector size=512, S/N:0000000047AE, FW:0101
Analyse Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/32/33
NTFS at 12/223/20
Info: size boot_sector 975472092, partition 975472640
NTFS at 60733/61/1
1 * HPFS - NTFS 0 32 33 12 223 19 204800 [System-reserviert]
2 P HPFS - NTFS 12 223 20 60733 60 63 975472640
3 P HPFS - NTFS 60733 61 1 60801 15 14 1089536
NTFS at 0/32/33
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
filesystem size 975472092
mftmirr_lcn 2
HPFS - NTFS 12 223 20 60733 52 19 975472092
NTFS, blocksize=4096, 499 GB / 465 GiB
NTFS at 60733/61/1
filesystem size 1089536
mft_lcn 45397
mftmirr_lcn 2
NTFS, blocksize=4096, 557 MB / 532 MiB
file_pread(7,3,buffer,976773182(60801/81/15)) lseek err Invalid argument
file_pread(7,1,buffer,976773182(60801/81/15)) lseek err Invalid argument
file_pread(7,8,buffer,976773198(60801/81/31)) lseek err Invalid argument
file_pread(7,11,buffer,976773245(60801/82/15)) lseek err Invalid argument
file_pread(7,2,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(7,3,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(7,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(7,1,buffer,976773206(60801/81/39)) lseek err Invalid argument
file_pread(7,1,buffer,976773256(60801/82/26)) lseek err Invalid argument
file_pread(7,1,buffer,976775169(60801/112/49)) lseek err Invalid argument
file_pread(7,8,buffer,976773376(60801/84/20)) lseek err Invalid argument
file_pread(7,8,buffer,976773504(60801/86/22)) lseek err Invalid argument
file_pread(7,8,buffer,976773632(60801/88/24)) lseek err Invalid argument
file_pread(7,8,buffer,976773760(60801/90/26)) lseek err Invalid argument
file_pread(7,8,buffer,976773888(60801/92/28)) lseek err Invalid argument
file_pread(7,8,buffer,976774016(60801/94/30)) lseek err Invalid argument
file_pread(7,8,buffer,976774144(60801/96/32)) lseek err Invalid argument
file_pread(7,8,buffer,976774272(60801/98/34)) lseek err Invalid argument
file_pread(7,8,buffer,976774400(60801/100/36)) lseek err Invalid argument
file_pread(7,8,buffer,976774528(60801/102/38)) lseek err Invalid argument
file_pread(7,8,buffer,976774656(60801/104/40)) lseek err Invalid argument
file_pread(7,8,buffer,976774784(60801/106/42)) lseek err Invalid argument
file_pread(7,8,buffer,976774912(60801/108/44)) lseek err Invalid argument
file_pread(7,8,buffer,976775040(60801/110/46)) lseek err Invalid argument
file_pread(7,8,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(7,8,buffer,976775176(60801/112/56)) lseek err Invalid argument
file_pread(7,3,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(7,3,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(7,8,buffer,976775247(60801/114/1)) lseek err Invalid argument
file_pread(7,11,buffer,976775294(60801/114/48)) lseek err Invalid argument
file_pread(7,2,buffer,976777216(60801/145/17)) lseek err Invalid argument
Warning: the current number of heads per cylinder is 255 but the correct value may be 128.
write!
file_pwrite(7,1,buffer,0(0/0/1)) write err File truncated
NTFS at 0/32/33
NTFS at 12/223/20
NTFS at 60733/61/1
Backup partition structure
partition_save
NTFS at 0/32/33
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
mftmirr_lcn 2
NTFS at 60733/61/1
mft_lcn 45397
mftmirr_lcn 2
Die Logdatei bringt mir keine neuen Erkenntnisse.
Der letzte Ratschlag von mir wurde offensichtlich nicht umgesetzt.
raz77
#5 Post by raz77 »
Fired up that hard drive and ran the tool with GPT, the following pictures are the results of a quick search:
Thanks for your effort.
#6 Post by recuperation »
Use the "p" key to look into each partition to see if you can find valid content within.
#7 Post by cgrenier »
The current partition table looks OK. Try TestDisk, Advanced, select the partition, Boot, List and try to copy the files you want.
raz77
#8 Post by raz77 »
It didn't work, I have tried everything you guys told me. TestDisk couldn't read the data.
In the end I've managed to recover enough files with Recuva and a combination of some other tools and bought a new SSD and transferred the files. Thanks for your help anyway.
