Copying files creates directories but no files are copied
bobprolancer
#1 Post by bobprolancer »
Hi All,
I am trying to get some important files from a HDD with a damaged partition table.
I was able to copy some file and directories from from NTFS and FAT partitions without any problem.
But when I try to copy the files from EXT4 Ubuntu boot partition from Directory "/home/b/.mozilla/firefox/y8ql0o1j.default" Testdisk creates directories in destination drive without any files in it although I get a message in Testdisk Copied XXXX files successfully.
But, I was able to copy some other files in /bob/misc without any issues.
What seems to be the problem. Can anyone help me with this.
I am using Ubuntu 18 LTS
Added by moderator
I am trying to recover my firefox profile folder from the EXT4 partition which used to be my primary ubuntu installation in a 320 GB WD0 HDD which recently broke up with me by throwing away all the partitions out the windows :(
Ran Testdisk from root and found the bootable EXT4 Ubuntu partition by analyzing, found the Firefox profiles folder and copied files to a backup folder. But after the copying the destination backup folder is showing empy with just the directory structure created and not even a single file.
What seems to be the problem? I am in a terrible situation where I need those bookmarks and stuff from that profile for my work.
Can somebody help me with this issue
Re: Copying files creates directories but no files are copied
Try using Testdisk as admin. Do you have access rights to the target folder?
