Lost partition not written after reboot Topic is solved
Legionella
#1 Post by Legionella »
Greetings,
As I'm sure many people do here, I come asking for help repairing an HDD whose only partition became "unallocated space" without a clear reason. I have been able to list the files with testdisk and the ones i have extracted appear to have sufficient integrity. Unfortunately this was a 1 TB drive and I do not currently own any other drives of that size to which I can offload the data, so before I went and spent money on one I wanted to try and repair the partition if it's possible. TestDisk successfully finds it in quick search, and when I ask to write partition it simply says the drive must be rebooted for the change to take effect. The space remains unallocated however. The log is below
Fri Jul 31 20:42:01 2020
TestDisk 7.2-WIP, Data Recovery Utility, May 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000204881920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=92613025792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000204881920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=92613025792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=494586036224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - PNY CS900 500GB SSD, S/N:PNY09202280040408798, FW:CS900613
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - Seagate Expansion Desk, S/N:16CC4256B1NA, FW:0604
Disk /dev/sdc - 92 GB / 86 GiB - CHS 1407 255 63, sector size=4096 - MSFT XVDD, FW:1.0
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - Seagate Expansion Desk, S/N:16CC4256B1NA, FW:0604
Disk \\.\PhysicalDrive2 - 92 GB / 86 GiB - CHS 1407 255 63, sector size=4096 - MSFT XVDD, FW:1.0
Drive D: - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - Seagate Expansion Desk, S/N:16CC4256B1NA, FW:0604
Disk /dev/sdb - 1000 GB / 931 GiB - Seagate Expansion Desk
Analyse Disk /dev/sdb - 1000 GB / 931 GiB - CHS 15200 255 63
NTFS at 0/4/5
Info: size boot_sector 1953519616, partition 244189952
 1 * HPFS - NTFS              0   4  5 15200  35  3  244189952 [Noah's Ark]
NTFS at 0/4/5
filesystem size           1953519616
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
file_pread(5,1,buffer,244190719(15200/43/11)) lseek err Invalid argument
file_pread(5,1,buffer,244190720(15200/43/12)) lseek err Invalid argument
file_pread(5,1,buffer,244190656(15200/42/11)) lseek err Invalid argument
file_pread(5,1,buffer,244190672(15200/42/27)) lseek err Invalid argument
file_pread(5,1,buffer,244190688(15200/42/43)) lseek err Invalid argument
file_pread(5,1,buffer,244190704(15200/42/59)) lseek err Invalid argument
file_pread(5,1,buffer,244190721(15200/43/13)) lseek err Invalid argument
file_pread(5,1,buffer,244190722(15200/43/14)) lseek err Invalid argument
file_pread(5,2,buffer,244190727(15200/43/19)) lseek err Invalid argument
file_pread(5,2,buffer,244190729(15200/43/21)) lseek err Invalid argument
file_pread(5,3,buffer,244190735(15200/43/27)) lseek err Invalid argument
file_pread(5,1,buffer,244190976(15200/47/16)) lseek err Invalid argument
As of right now, I'm in a new computer which I'm certain has no running antiviruses and I have so far failed to find a similar log error in posts about similar issues. Is there something I'm missing?
Thank you for your time and your excellent software!
Re: Lost partition not written after reboot
Relying on a repair of a faulty drive is too risky to be recommended!
In your case it looks like the sector size of 4096 is not reflected in the boot sector.
Usually drives with a sector size of 4096 come with an emulation of 512 byte.
Did you duplicate this drive from another one?
#3 Post by cgrenier »
As reparation asks, do you clone your disk, move this disk from another computer or replace your computer motherboard ?
Assuming the disk will not move to another computer, the partition is correctly listed in the partition table.
Run TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files,
- choose Write, confirm, Quit
- Restart your computer.
- Run "cmd" (right click "Run as Administrator" and type "chkdsk /f d:" (replace d: by the correct drive letter)
Legionella
#4 Post by Legionella »
I understand, I was hoping the drive itself would be repairable. It is not duplicated and I'm not sure about the sector size or why it might not be reflected in the boot sector. Is this something I have any capacity to change?
I am moving this disk, which was my former second hard drive (not for booting, just file storage) to a second computer with a smaller SSD.
I tried doing the chkdsk but it says this is not possible for RAW drives.
Thank you both again for all your kind help.
#5 Post by recuperation »
Legionella wrote: 01 Aug 2020, 23:41
Yes, by following the advice given by cgrenier.
Duplicated drives need certain adjustments to run properly when the sector size on the target is different from the source.
Do you mean physically moving or duplicating as you are talking about a "second computer with a smaller SSD"?
Have you followed the proposal of cgrenier?
Legionella
#6 Post by Legionella »
Legionella wrote: 01 Aug 2020, 03:00 Greetings,
NTFS at 0/4/5
NTFS at 0/4/5
mftmirr_lcn               2
cgrenier wrote: 01 Aug 2020, 08:33 As reparation asks, do you clone your disk, move this disk from another computer or replace your computer motherboard ?
I tried to unplug instead of restarting the system before the last post, sorry for taking your time. The steps outlined by cgrenier did the job! Thank you both so much! :D
