Sillily deleted partitions
scott14521345
#1 Post by scott14521345 »
Hi there,
I installed a new drive, and was changing the drive letters to match what I was used to.
I noticed my 2 TB HHD had a windows recovery partition from my previous install, I went to remove it and expand the partition on this HDD, and I somehow failed.
The entire drive is marked as RAW in disk management.
I am 90% certain it was an NTFS drive.
When I run testdisk, it finds the partition, but tells me The harddisk (2000 GB / 1863 GiB) seems too small! (< 2000 GB / 1863 GiB) and that it thus can't be recovered.
See log below:
Mon Aug 24 20:23:23 2020
TestDisk 7.2-WIP, Data Recovery Utility, August 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=16170196480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=16170196480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999610183168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=499608354816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500104691712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=16169041920
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM006-2DM164, S/N:Z4Z7W340, FW:CC26
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 850 EVO 500GB, S/N:S2RBNX0HA47506X, FW:EMT02B6Q
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 860 EVO 500GB, S/N:S3Z2NB1K778095P, FW:RVT01B6Q
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 970 EVO 1TB, S/N:0025_3854_0141_5FCF., FW:2B2QEXE7
Disk /dev/sde - 16 GB / 15 GiB - CHS 1965 255 63, sector size=512, S/N:0912241409377a, FW:0.00
Drive H: - 16 GB / 15 GiB - CHS 1965 255 63, sector size=512, S/N:0912241409377a, FW:0.00
Disk /dev/sda - 2000 GB / 1863 GiB - ST2000DM006-2DM164
Analyse Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
test_FAT()
 1 * FAT16 >32M               0  32 33 243201  45 44 3907024896
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
Invalid FAT boot sector
NTFS at 70/29/24
filesystem size           3907020800
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS             70  29 24 243270 232 34 3907020800 [Bulk Storage]
This partition ends after the disk limits. (start=1126400, size=3907020800, end=3908147199, disk end=3907029168)
file_pread(4,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(4,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
Any help would be very much appreciated.
Re: Sillily deleted partitions
Did you stop with the simple analysis or did you run deep search?
Your logfile seems so short.
