PhotoRec on TS-419p - cannot execute binary file Topic is solved
badmax0815
#1 Post by badmax0815 »
I'll tried to use PhotoRec on my NAS to recover deleted files.
I used a procedure described at page:
http://qnapsupport.net/teknik-destek/ra ... -kurtarma/
I logged into my NAS using Putty, what worked well.
But when I tried to execute PhotoRec I've got the error "cannot execute binary file" :oops:
same error with both linux versions:
- Linux, kernel 2.6.18 or later i386
- Linux, kernel 2.6.18 or later x86_64
I found a hint in another forum, stating that QNAP TS-419p is using an ARM-processor and so SW compiled for Intel-processors will not work.
Is there any chance to compile an ARM-version of PhotoRec or can I compile PhotoRec for ARM-processor myself?
thanks for any comment or support.
BR Hilmar
Re: PhotoRec on TS-419p - cannot execute binary file
How did you configure the drives? Single,JBOD, Raidx?
badmax0815
#3 Post by badmax0815 »
Raid1, but I have removed one of the mirrored hard disks to have a second chance for an recovery attempt, just in case I mess up something. ;)
Thank and BR
Hilmar
If you are dealing with a plain vanilla simple single drive you would simply remove the drive and connect it to a linux machine.
On that linux machine you would run testdisk.
When you stated that you removed it from a RAID 1 configuration I don't know if the removal changed the RAID specific layout changes back to regular MBR/GPT standards that Testdisk understands Will have to ask Christophe here.
#5 Post by cgrenier »
You can connect one of the disk to a computer running Windows or Linux and use PhotoRec from here.
It's easier than using PhotoRec in the NAS itself.
badmax0815
#6 Post by badmax0815 »
Hi, many thanks to cgrenier and recuperation for your direct feedback.
I've just recieved the USB3.0 - SATA adapter and I'am installing now photorec for Windows on my Notebook. I'll keep you updated.
BR Hilmar
badmax0815
#7 Post by badmax0815 »
Brief update,
Recovery started.
Estimated time to completion currently 7h but permanently increasing. ;)
I count with several days to restore roughly 1TB.
Thanks for your support
badmax0815
#8 Post by badmax0815 »
Hi to all and thanks for your Support.
Recovery worked well has taken roughly 140 hours.
