MyBook salvage, newbie questions Topic is solved
horomancer
#1 Post by horomancer »
Hello! I have a MyBook external HD that crapped out on me, and I was hoping to salvage it. I've been reading through the testdisk.pdf and currently have a ddrescue disk-to-disk copy of the HD on a dedicated partition on a new drive
[horo@recovery ~]$ sudo fdisk -l
[sudo] password for horo:
Disk /dev/sda: 465.78 GiB, 500107862016 bytes, 976773168 sectors
Disk model: WDC WD5000AVDS-6
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: dos
Disk identifier: 0xdb2203ee
Device     Boot     Start       End   Sectors   Size Id Type
/dev/sda1  *         2048 209717247 209715200   100G 83 Linux
/dev/sda2       209717248 230688767  20971520    10G 82 Linux swap / Solaris
/dev/sda3       230688768 587204607 356515840   170G 83 Linux
/dev/sda4       587204608 976773167 389568560 185.8G 83 Linux
Disk /dev/sdb: 149.1 GiB, 160000000000 bytes, 312500000 sectors
Disk model: ST3160815AS
[horo@recovery ~]$ sudo ddrescue -f -n /dev/sdb /dev/sda3 rescue.map
GNU ddrescue 1.25
Press Ctrl-C to interrupt
     ipos:   33710 MB, non-trimmed:        0 B,  current rate:    6656 B/s
     opos:   33710 MB, non-scraped:     3072 B,  average rate:  55096 kB/s
non-tried:        0 B,  bad-sector:     1024 B,    error rate:     170 B/s
  rescued:  159999 MB,   bad areas:        2,        run time:     48m 24s
pct rescued:   99.99%, read errors:        3,  remaining time:          1s
                              time since last successful read:          0s
Finished
[horo@recovery ~]$ sudo ddrescue -d -f -r3 /dev/sdb /dev/sda3 rescue.map
GNU ddrescue 1.25
Initial status (read from mapfile)
rescued: 159999 MB, tried: 4096 B, bad-sector: 1024 B, bad areas: 2
Current status
     ipos:   33710 MB, non-trimmed:        0 B,  current rate:       0 B/s
     opos:   33710 MB, non-scraped:        0 B,  average rate:     256 B/s
non-tried:        0 B,  bad-sector:      512 B,    error rate:     170 B/s
  rescued:  159999 MB,   bad areas:        1,        run time:         14s
pct rescued:   99.99%, read errors:        4,  remaining time:         n/a
                              time since last successful read:          6s
Finished
I'm also currently making an .img file in it's own separate partition.
When running TestDisk, do I indicate the partition the clonded disk is on (/dev/sda3)? or the whole sda drive then look for missing partitions?
Re: MyBook salvage, newbie questions
horomancer wrote: 29 Aug 2020, 08:06 Hello! I have a MyBook external HD that crapped out on me, and I was hoping to salvage it. I've been reading through the testdisk.pdf and currently have a ddrescue disk-to-disk copy of the HD on a dedicated partition on a new drive
Disklabel type: dos
GNU ddrescue 1.25
Finished
GNU ddrescue 1.25
Current status
Finished
That is not necessary. Keep your map-file, it tells you where your broken sectors are!
Neither sda3 nor the whole drive!
As the main Testdisk menu does not allow file selection you would need to integrate your file-based ddrescue copy as a device in Linux.
horomancer
#3 Post by horomancer »
I ran Testdisk on the original faulty drive. After a Quick search and Deep search I did not detect any partition. At this point do i try the MBR Code option? Do I move to Photorec?
horomancer wrote: 29 Aug 2020, 16:32 I ran Testdisk on the original faulty drive. After a Quick search and Deep search I did not detect any partition. At this point do i try the MBR Code option?
That won't affect the findings.
Yes.
horomancer
#5 Post by horomancer »
Thank you. I'll move to Photorec and cross my fingers. Do partitions need to be mounted for Photorec to do it's thing?
#6 Post by recuperation »
horomancer wrote: 30 Aug 2020, 03:43 Thank you. I'll move to Photorec and cross my fingers. Do partitions need to be mounted for Photorec to do it's thing?
No.
horomancer
#7 Post by horomancer »
Thank you, I have managed to salvage many thousands of image files.
