Recovery of Intel RST Raid5 fault
KotoriAbe
#1 Post by KotoriAbe »
Hi all, this is Kotori from Hong Kong.
I have an Intel C246 chipset Motherboard connected with 6 qty. of 4TB Enterprise HDD build with Raid5 system on motherboard RST.
Reference by: viewtopic.php?f=5&t=5947&p=19546&hilit= ... id5#p19546
i just follow the reference post to do the rescuise procedure. unfortunately, testdisk said some partition can not be recovery.
is it correct and no any method to recovery the data?
https://drive.google.com/file/d/103mlhr ... wg-TN/view
https://drive.google.com/drive/u/2/fold ... 6SVIgO_b7y
Re: Recovery of Intel RST Raid5 fault
KotoriAbe wrote: 06 Sep 2020, 03:09 Hi all, this is Kotori from Hong Kong.
Did you let Testdisk finish the deep seach? Did you tried to look into each partition found?
You can use Photorec or any other commercial software. Read the manual to learn about the disadvantages of Photorec.
Please remove the external links (one is broken) and use the attachment function on the bottom of your page.
