Recuperar Partición sin eliminar archivos / Recover Partition without deleting files
Sorry Agrego log / I add log
Thu Sep 10 13:28:22 2020
TestDisk 7.2-WIP, Data Recovery Utility, August 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000592982016
filewin32_getfilesize(/dev/sdd) GetFileSize err Función incorrecta.
filewin32_setfilepointer(/dev/sdd) SetFilePointer err Función incorrecta.
Warning: can't get size for Disk /dev/sdd - 0 B - 0 sectors, sector size=512
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=4000752599040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=1966080000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=8589934592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=4000752599040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=1966080000
filewin32_getfilesize(\\.\PhysicalDrive6) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive6) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=8589934592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=238581885952
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4000750501888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000457232384
filewin32_getfilesize(\\.\F:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=1966080000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=0
Warning: can't get size for \\.\M:
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - KINGSTON SHFS37A240G, S/N:50026B7255052006, FW:603ABBF0
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00DC0B0, S/N:WD-WCC1T1339600, FW:80.00A80
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00SPEB0, S/N:WD-WCC4E1KRNJ8Z, FW:80.00A80
Disk /dev/sde - 4000 GB / 3725 GiB - CHS 486397 255 63, sector size=512 - WD Elements 2620, S/N:WX81EB91H9N6, FW:1018
Disk /dev/sdf - 1966 MB / 1875 MiB - CHS 239 255 63, sector size=512 - TS-RDF5 SD Transcend, S/N:00000000TS3A, FW:TS3A
Disk /dev/sdh - 8589 MB / 8192 MiB - CHS 1044 255 63, sector size=512 - Msft Virtual Disk, FW:1.0
Disk /dev/sdb - 3000 GB / 2794 GiB - WDC WD30EZRX-00DC0B0
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Reserved 34 262177 262144 [Mi]
2 P MS Data 262178 5860533133 5860270956 [Almacen ]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Re: Recuperar Partición sin eliminar archivos / Recover Partition without deleting files
I refused your second posting.
You can modify the first one that I accepted.
Invest some time reading:
Please provide all information in one posting:
1. Start with an error description. Please state how your drive had been before something bad happened, describe if there is any particular event how your drive went bad. Your description should be detailed enough to enable others to identify your failing drive/partition in the log file.
2. Post the log file
Please consider:
I have no crystal ball. If you do not care about your posting why should I care?
Please consider:
Re: Recuperar Partición sin eliminar archivos / Recuperar partición sin eliminar archivos
Hola, en la primera parte había descrito el problema y se me había olvidado agregar el log, que es de donde empieza la consulta
Explico: Por un error mío hice desaparecer la detección del disco denominado "Almacén" del sistema W10, el cual ahora no lo muestra, mi intención es recurerar la partición sin que se eliminen los archivos, y mi problema al usar TestDisk, es que no detectó una partición NTFS sino que una EFI GPT y no encuentro instrucciones de como proceder en esta situación para poder recuperar la partición, por eso recurro a ustedes, para que me instruyan a fin de hacerlo bien. Copio un nuevo log hasta el paso en que no sé que hacer. Gracias / Hello, in the first part I had described the problem and I had forgotten to add the log, which is where the query begins
I explain: Due to a mistake of mine I made the detection of the disk called "Warehouse" disappear from the W10 system, which now does not show it, my intention is to restore the partition without deleting the files, and my problem when using TestDisk, is that it does not it detected an NTFS partition but rather an EFI GPT and I cannot find instructions on how to proceed in this situation to be able to recover the partition, so I turn to you, so that you instruct me in order to do it right. I copy a new log until the step where I don't know what to do. Thank you
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/81/36
filesystem size 5860270956
mft_lcn 3
mftmirr_lcn 366266934
NTFS part_offset=134235136, part_size=3000458729472, sector_size=512
NTFS at 16/81/36
mft_lcn 3
file_pread(5,3,buffer,1565565901(364801/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565565901(364801/81/30)) lseek err Invalid argument
file_pread(5,8,buffer,1565565917(364801/81/46)) lseek err Invalid argument
file_pread(5,11,buffer,1565565964(364801/82/30)) lseek err Invalid argument
file_pread(5,2,buffer,1565567886(364801/112/62)) lseek err Invalid argument
file_pread(5,3,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567888(364801/113/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565905(364801/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565926(364801/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565565976(364801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567889(364801/113/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565977(364801/82/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567890(364801/113/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(5,8,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,11,buffer,1565565968(364801/82/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567891(364801/113/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565979(364801/82/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567892(364801/113/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565980(364801/82/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567893(364801/113/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567894(364801/113/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(5,8,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,11,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567895(364801/113/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565983(364801/82/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567896(364801/113/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565913(364801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567897(364801/113/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(5,8,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,11,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567898(364801/113/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565936(364801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567899(364801/113/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565916(364801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567900(364801/113/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565917(364801/81/46)) lseek err Invalid argument
file_pread(5,8,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,11,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567901(364801/113/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565989(364801/82/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567902(364801/113/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565872(364801/81/1)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,1,buffer,1565565919(364801/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567903(364801/113/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(5,8,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,11,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567904(364801/113/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565942(364801/82/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567905(364801/113/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565993(364801/82/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567906(364801/113/19)) lseek err Invalid argument
file_pread(5,8,buffer,1565565866(364801/80/58)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,3,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,3,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,8,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,11,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567907(364801/113/20)) lseek err Invalid argument
file_pread(5,3,buffer,1565565872(364801/81/1)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,1,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565995(364801/82/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567908(364801/113/21)) lseek err Invalid argument
file_pread(5,14,buffer,1565565862(364801/80/54)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,3,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(5,3,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(5,8,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,11,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,2,buffer,1565567908(364801/113/21)) lseek err Invalid argument
file_pread(5,14,buffer,1565565863(364801/80/55)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,4,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,3,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,8,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,11,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,2,buffer,1565567909(364801/113/22)) lseek err Invalid argument
file_pread(5,14,buffer,1565565864(364801/80/56)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,5,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,3,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,8,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,11,buffer,1565565988(364801/82/54)) lseek err Invalid argument
file_pread(5,2,buffer,1565567910(364801/113/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565999(364801/83/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567912(364801/113/25)) lseek err Invalid argument
file_pread(5,14,buffer,1565565866(364801/80/58)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,7,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,3,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,8,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,11,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567913(364801/113/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565951(364801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566001(364801/83/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567914(364801/113/27)) lseek err Invalid argument
file_pread(5,14,buffer,1565565868(364801/80/60)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,8,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,3,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,3,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,8,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,11,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567915(364801/113/28)) lseek err Invalid argument
file_pread(5,10,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565932(364801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566003(364801/83/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567916(364801/113/29)) lseek err Invalid argument
file_pread(5,14,buffer,1565565870(364801/80/62)) ReadFile La unidad no puede encontrar el sector solicitado.
file_pread(5,3,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,3,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,8,buffer,1565565947(364801/82/13)) lseek err Invalid argument
file_pread(5,11,buffer,1565565994(364801/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567917(364801/113/30)) lseek err Invalid argument
file_pread(5,12,buffer,1565565873(364801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565887(364801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565955(364801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566005(364801/83/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567918(364801/113/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565888(364801/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565935(364801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565956(364801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566006(364801/83/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567919(364801/113/32)) lseek err Invalid argument
file_pread(5,2,buffer,1565565885(364801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565889(364801/81/18)) lseek err Invalid argument
file_pread(5,8,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(5,11,buffer,1565565997(364801/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567920(364801/113/33)) lseek err Invalid argument
file_pread(5,14,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565890(364801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565958(364801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566008(364801/83/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567921(364801/113/34)) lseek err Invalid argument
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/81/36
mft_lcn 3
NTFS at 16/81/36
mft_lcn 3
I can't find "warehouse".
Hint: The log file is easier to read if you disconnect every hard drive exept for the one with your operating system and the broken drive.
You are running two identical drives.
What is the size of the drive in question???
If it is one of those 3TB drives the serial number is obviously required.
You have 6 devices connected. I don't want to guess. Where is the difficulty to deliver a description that I can understand?recuperation wrote: 10 Sep 2020, 19:10 Your description should be detailed enough to enable others to identify your failing drive/partition in the log file.
Never tell anybody what your mistake was! Keep it a secret until the end of your life.
Hola, antes de continuar quiero hacerte saber que mi idioma madre es el español (Chile) y que mis traducciones al inglés son resultado del traductor de Google, por lo que talvez algunas ideas o palabras pudieran estar mal expresadas / Hello, before continuing I want to let you know that my mother tongue is Spanish (Chile) and that my translations into English are the result of the Google translator, so maybe some ideas or words could be wrongly expressed
Ahora bien he seguido el consejo de desconectar los demás discos duros dejando el de raíz y al afectado cuya información enviaré cuando concluya la revisión que va en un 35%, después de 20 horas de análisis profundo. En todo caso el disco afectado corresponde a: / Now, I have followed the advice to disconnect the other hard drives, leaving the root one and the affected one whose information I will send when the review is finished, which is 35%, after 20 hours of deep analysis. In any case, the affected disk corresponds to:
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
The log states: "Partition table type: EFI GPT", in other words: The type of the partition table (and not the partition!) is EFI GPT.curiozzo wrote: 10 Sep 2020, 21:16 Due to a mistake of mine I made the detection of the disk called "Warehouse" disappear from the W10 system, which now does not show it, my intention is to restore the partition without deleting the files, and my problem when using TestDisk, is that it does not it detected an NTFS partition but rather an EFI GPT and I cannot find instructions on how to proceed in this situation to be able to recover the partition, so I turn to you, so that you instruct me in order to do it right.
EFI GPT and INTEL/MBR are just hulls under which different types of partitions like FAT16, FAT32, NTFS, extX, HFS and others can reside.
Please try to write shorter sentences. There is no reason to put the whole content above into one sentence. Furthermore you make the life of your translator much easier!
Hola, copio el nuevo log y al final de él pego el contenido de la pantall de trabajo de TestDisk: / Hello, I copy the new log and at the end of it I paste the content of the TestDisk workscreen:
Thu Sep 10 22:49:51 2020
filewin32_getfilesize(/dev/sdc) GetFileSize err Función incorrecta.
filewin32_setfilepointer(/dev/sdc) SetFilePointer err Función incorrecta.
Warning: can't get size for Disk /dev/sdc - 0 B - 0 sectors, sector size=512
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=8589934592
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=8589934592
Disk /dev/sde - 8589 MB / 8192 MiB - CHS 1044 255 63, sector size=512 - Msft Virtual Disk, FW:1.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/81/36
mft_lcn 3
NTFS at 16/81/36
mft_lcn 3
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/81/36
mft_lcn 3
NTFS at 16/81/36
mft_lcn 3
1 P MS Data 262178 5860533133 5860270956 [Almacen ]
NTFS at 16/81/36
mft_lcn 3
NTFS at 16/81/36
mft_lcn 3
Unknown 268335625 35390882974693896 35390882706358272
WBFS, 18120131 TB / 16480164 TiB
Partition not added.
HFS magic value at 38721/65/10
part_size 516
Mac HFS 622056969 622057484 516
HFS blocksize=512, 264 KB / 258 KiB
HFS magic value at 38721/65/12
part_size 516
Mac HFS 622056457 622056972 516
HFS found using backup sector!, 264 KB / 258 KiB
check_FAT: Unusual, only one FAT
check_FAT: number of bytes per sector mismatches 41982 (FAT) != 512 (HD)
Unknown 1591975817 4568089302 2976113486
FATX, 1523 GB / 1419 GiB
FAT12 at 102697/251/41
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
EFI System 1649843158 1649846037 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 102698/42/23
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 1649846038 1649848917 2880 [EFI System Partition] [EFISECTOR]
SYSV4 Marker at 130442/40/30
recover_sysv4
Unknown 2095553279 27128217695918846 27128215600365568 [‹5Ú·¦¡]
SysV4, 13889646 TB / 12632559 TiB
HFS magic value at 187740/91/50
part_size 3305260622
Mac HFS 3016048882 6321309503 3305260622 [¥)P:`±âã…]
HFS blocksize=33554432, 1692 GB / 1576 GiB
This partition ends after the disk limits. (start=3016048882, size=3305260622, end=6321309503, disk end=5860533168)
HFS magic value at 187740/91/52
LVM magic value at 196847/15/49
check_FAT: number of bytes per sector mismatches 58770 (FAT) != 512 (HD)
LVM magic value at 210647/227/50
HFS magic value at 214885/206/52
Mac HFS 3452140554 6757401175 3305260622 [¥)P:`±âã…]
This partition ends after the disk limits. (start=3452140554, size=3305260622, end=6757401175, disk end=5860533168)
HFS magic value at 214885/206/54
Mac HFS 146879936 3452140557 3305260622 [¥)P:`±âã…]
HFS found using backup sector!, 1692 GB / 1576 GiB
Unknown 4141062302 5601394581 1460332280
FATX, 747 GB / 696 GiB
LVM magic value at 270513/214/27
HFS magic value at 300085/151/50
part_size 524290
Mac HFS 4820875087 4821399376 524290
HFS blocksize=32768, 268 MB / 256 MiB
HFS magic value at 300085/151/52
part_size 524290
Mac HFS 4820350801 4820875090 524290
HFS found using backup sector!, 268 MB / 256 MiB
LVM magic value at 313039/225/56
LVM magic value at 345933/237/22
NTFS at 16/81/36
mft_lcn 3
NTFS at 16/81/36
mft_lcn 3
part_size 516
part_size 516
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
recover_sysv4
part_size 524290
part_size 524290
file_pread(5,1,buffer,1565565876(364801/81/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565878(364801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565879(364801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565880(364801/81/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565882(364801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565884(364801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565886(364801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565891(364801/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565892(364801/81/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565565893(364801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565565894(364801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565895(364801/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565565896(364801/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565565897(364801/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565898(364801/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565565899(364801/81/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565565900(364801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565565902(364801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565903(364801/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565904(364801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565923(364801/81/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565938(364801/82/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565941(364801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565565944(364801/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565946(364801/82/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565947(364801/82/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565565948(364801/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565565950(364801/82/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565954(364801/82/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565565957(364801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565565959(364801/82/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565565960(364801/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565565961(364801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565565962(364801/82/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565565963(364801/82/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565565964(364801/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565565965(364801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565565966(364801/82/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565565967(364801/82/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565565968(364801/82/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565969(364801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565970(364801/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565565971(364801/82/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565972(364801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565973(364801/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565974(364801/82/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565978(364801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565982(364801/82/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565985(364801/82/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565988(364801/82/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565991(364801/82/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565994(364801/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565996(364801/82/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565997(364801/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565998(364801/83/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566000(364801/83/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566002(364801/83/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566004(364801/83/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566007(364801/83/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566009(364801/83/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566010(364801/83/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566011(364801/83/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566012(364801/83/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566013(364801/83/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566014(364801/83/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566015(364801/83/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566016(364801/83/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566017(364801/83/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566018(364801/83/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566019(364801/83/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566020(364801/83/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566021(364801/83/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566022(364801/83/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566023(364801/83/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566024(364801/83/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566025(364801/83/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566026(364801/83/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566027(364801/83/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566028(364801/83/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566029(364801/83/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566030(364801/83/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566031(364801/83/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566032(364801/83/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566033(364801/83/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566034(364801/83/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566035(364801/83/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566036(364801/83/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566037(364801/83/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566038(364801/83/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566039(364801/83/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566040(364801/83/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566041(364801/83/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566042(364801/83/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566043(364801/83/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566044(364801/83/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566045(364801/83/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566046(364801/83/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566047(364801/83/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566048(364801/83/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566049(364801/83/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566050(364801/83/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566051(364801/83/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566052(364801/83/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566053(364801/83/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566054(364801/83/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566055(364801/83/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566056(364801/83/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566057(364801/83/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566058(364801/83/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566059(364801/83/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566060(364801/83/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566061(364801/84/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566062(364801/84/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566063(364801/84/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566064(364801/84/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566065(364801/84/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566066(364801/84/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566067(364801/84/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566068(364801/84/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566069(364801/84/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566070(364801/84/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566071(364801/84/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566072(364801/84/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566073(364801/84/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566074(364801/84/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566075(364801/84/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566076(364801/84/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566077(364801/84/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566078(364801/84/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566079(364801/84/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566080(364801/84/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566081(364801/84/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566082(364801/84/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566083(364801/84/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566084(364801/84/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566085(364801/84/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566086(364801/84/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566087(364801/84/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566088(364801/84/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566089(364801/84/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566090(364801/84/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566091(364801/84/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566092(364801/84/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566093(364801/84/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566094(364801/84/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566095(364801/84/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566096(364801/84/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566097(364801/84/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566098(364801/84/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566099(364801/84/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566100(364801/84/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566101(364801/84/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566102(364801/84/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566103(364801/84/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566104(364801/84/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566105(364801/84/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566106(364801/84/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566107(364801/84/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566108(364801/84/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566109(364801/84/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566110(364801/84/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566111(364801/84/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566112(364801/84/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566113(364801/84/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566114(364801/84/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566115(364801/84/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566116(364801/84/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566117(364801/84/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566118(364801/84/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566119(364801/84/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566120(364801/84/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566121(364801/84/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566122(364801/84/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566123(364801/84/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566124(364801/85/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566125(364801/85/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566126(364801/85/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566127(364801/85/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566128(364801/85/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566129(364801/85/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566130(364801/85/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566131(364801/85/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566132(364801/85/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566133(364801/85/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566134(364801/85/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566135(364801/85/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566136(364801/85/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566137(364801/85/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566138(364801/85/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566139(364801/85/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566140(364801/85/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566141(364801/85/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566142(364801/85/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566143(364801/85/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566144(364801/85/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566145(364801/85/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566146(364801/85/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566147(364801/85/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566148(364801/85/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566149(364801/85/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566150(364801/85/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566151(364801/85/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566152(364801/85/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566153(364801/85/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566154(364801/85/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566155(364801/85/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566156(364801/85/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566157(364801/85/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566158(364801/85/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566159(364801/85/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566160(364801/85/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566161(364801/85/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566162(364801/85/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566163(364801/85/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566164(364801/85/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566165(364801/85/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566166(364801/85/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566167(364801/85/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566168(364801/85/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566169(364801/85/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566170(364801/85/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566171(364801/85/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566172(364801/85/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566173(364801/85/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566174(364801/85/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566175(364801/85/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566176(364801/85/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566177(364801/85/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566178(364801/85/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566179(364801/85/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566180(364801/85/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566181(364801/85/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566182(364801/85/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566183(364801/85/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566184(364801/85/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566185(364801/85/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566186(364801/85/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566187(364801/86/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566188(364801/86/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566189(364801/86/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566190(364801/86/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566191(364801/86/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566192(364801/86/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566193(364801/86/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566194(364801/86/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566195(364801/86/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566196(364801/86/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566197(364801/86/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566198(364801/86/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566199(364801/86/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566200(364801/86/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566201(364801/86/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566202(364801/86/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566203(364801/86/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566204(364801/86/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566205(364801/86/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566206(364801/86/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566207(364801/86/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566208(364801/86/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566209(364801/86/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566210(364801/86/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566211(364801/86/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566212(364801/86/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566213(364801/86/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566214(364801/86/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566215(364801/86/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566216(364801/86/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566217(364801/86/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566218(364801/86/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566219(364801/86/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566220(364801/86/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566221(364801/86/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566222(364801/86/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566223(364801/86/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566224(364801/86/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566225(364801/86/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566226(364801/86/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566227(364801/86/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566228(364801/86/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566229(364801/86/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566230(364801/86/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566231(364801/86/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566232(364801/86/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566233(364801/86/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566234(364801/86/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566235(364801/86/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566236(364801/86/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566237(364801/86/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566238(364801/86/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566239(364801/86/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566240(364801/86/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566241(364801/86/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566242(364801/86/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566243(364801/86/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566244(364801/86/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566245(364801/86/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566246(364801/86/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566247(364801/86/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566248(364801/86/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566249(364801/86/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566250(364801/87/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566251(364801/87/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566252(364801/87/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566253(364801/87/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566254(364801/87/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566255(364801/87/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566256(364801/87/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566257(364801/87/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566258(364801/87/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566259(364801/87/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566260(364801/87/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566261(364801/87/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566262(364801/87/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566263(364801/87/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566264(364801/87/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566265(364801/87/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566266(364801/87/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566267(364801/87/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566268(364801/87/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566269(364801/87/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566270(364801/87/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566271(364801/87/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566272(364801/87/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566273(364801/87/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566274(364801/87/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566275(364801/87/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566276(364801/87/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566277(364801/87/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566278(364801/87/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566279(364801/87/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566280(364801/87/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566281(364801/87/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566282(364801/87/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566283(364801/87/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566284(364801/87/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566285(364801/87/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566286(364801/87/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566287(364801/87/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566288(364801/87/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566289(364801/87/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566290(364801/87/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566291(364801/87/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566292(364801/87/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566293(364801/87/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566294(364801/87/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566295(364801/87/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566296(364801/87/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566297(364801/87/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566298(364801/87/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566299(364801/87/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566300(364801/87/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566301(364801/87/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566302(364801/87/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566303(364801/87/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566304(364801/87/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566305(364801/87/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566306(364801/87/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566307(364801/87/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566308(364801/87/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566309(364801/87/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566310(364801/87/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566311(364801/87/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566312(364801/87/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566313(364801/88/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566314(364801/88/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566315(364801/88/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566316(364801/88/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566317(364801/88/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566318(364801/88/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566319(364801/88/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566320(364801/88/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566321(364801/88/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566322(364801/88/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566323(364801/88/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566324(364801/88/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566325(364801/88/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566326(364801/88/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566327(364801/88/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566328(364801/88/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566329(364801/88/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566330(364801/88/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566331(364801/88/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566332(364801/88/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566333(364801/88/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566334(364801/88/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566335(364801/88/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566336(364801/88/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566337(364801/88/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566338(364801/88/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566339(364801/88/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566340(364801/88/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566341(364801/88/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566342(364801/88/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566343(364801/88/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566344(364801/88/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566345(364801/88/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566346(364801/88/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566347(364801/88/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566348(364801/88/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566349(364801/88/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566350(364801/88/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566351(364801/88/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566352(364801/88/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566353(364801/88/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566354(364801/88/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566355(364801/88/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566356(364801/88/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566357(364801/88/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566358(364801/88/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566359(364801/88/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566360(364801/88/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566361(364801/88/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566362(364801/88/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566363(364801/88/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566364(364801/88/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566365(364801/88/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566366(364801/88/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566367(364801/88/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566368(364801/88/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566369(364801/88/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566370(364801/88/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566371(364801/88/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566372(364801/88/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566373(364801/88/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566374(364801/88/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566375(364801/88/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566376(364801/89/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566377(364801/89/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566378(364801/89/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566379(364801/89/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566380(364801/89/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566381(364801/89/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566382(364801/89/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566383(364801/89/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566384(364801/89/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566385(364801/89/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566386(364801/89/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566387(364801/89/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566388(364801/89/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566389(364801/89/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566390(364801/89/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566391(364801/89/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566392(364801/89/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566393(364801/89/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566394(364801/89/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566395(364801/89/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566396(364801/89/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566397(364801/89/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566398(364801/89/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566399(364801/89/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566400(364801/89/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566401(364801/89/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566402(364801/89/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566403(364801/89/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566404(364801/89/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566405(364801/89/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566406(364801/89/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566407(364801/89/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566408(364801/89/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566409(364801/89/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566410(364801/89/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566411(364801/89/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566412(364801/89/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566413(364801/89/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566414(364801/89/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566415(364801/89/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566416(364801/89/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566417(364801/89/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566418(364801/89/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566419(364801/89/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566420(364801/89/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566421(364801/89/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566422(364801/89/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566423(364801/89/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566424(364801/89/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566425(364801/89/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566426(364801/89/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566427(364801/89/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566428(364801/89/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566429(364801/89/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566430(364801/89/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566431(364801/89/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566432(364801/89/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566433(364801/89/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566434(364801/89/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566435(364801/89/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566436(364801/89/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566437(364801/89/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566438(364801/89/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566439(364801/90/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566440(364801/90/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566441(364801/90/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566442(364801/90/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566443(364801/90/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566444(364801/90/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566445(364801/90/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566446(364801/90/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566447(364801/90/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566448(364801/90/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566449(364801/90/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566450(364801/90/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566451(364801/90/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566452(364801/90/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566453(364801/90/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566454(364801/90/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566455(364801/90/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566456(364801/90/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566457(364801/90/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566458(364801/90/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566459(364801/90/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566460(364801/90/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566461(364801/90/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566462(364801/90/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566463(364801/90/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566464(364801/90/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566465(364801/90/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566466(364801/90/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566467(364801/90/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566468(364801/90/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566469(364801/90/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566470(364801/90/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566471(364801/90/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566472(364801/90/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566473(364801/90/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566474(364801/90/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566475(364801/90/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566476(364801/90/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566477(364801/90/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566478(364801/90/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566479(364801/90/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566480(364801/90/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566481(364801/90/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566482(364801/90/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566483(364801/90/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566484(364801/90/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566485(364801/90/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566486(364801/90/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566487(364801/90/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566488(364801/90/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566489(364801/90/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566490(364801/90/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566491(364801/90/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566492(364801/90/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566493(364801/90/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566494(364801/90/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566495(364801/90/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566496(364801/90/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566497(364801/90/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566498(364801/90/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566499(364801/90/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566500(364801/90/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566501(364801/90/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566502(364801/91/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566503(364801/91/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566504(364801/91/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566505(364801/91/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566506(364801/91/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566507(364801/91/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566508(364801/91/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566509(364801/91/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566510(364801/91/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566511(364801/91/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566512(364801/91/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566513(364801/91/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566514(364801/91/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566515(364801/91/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566516(364801/91/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566517(364801/91/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566518(364801/91/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566519(364801/91/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566520(364801/91/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566521(364801/91/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566522(364801/91/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566523(364801/91/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566524(364801/91/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566525(364801/91/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566526(364801/91/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566527(364801/91/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566528(364801/91/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566529(364801/91/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566530(364801/91/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566531(364801/91/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566532(364801/91/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566533(364801/91/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566534(364801/91/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566535(364801/91/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566536(364801/91/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566537(364801/91/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566538(364801/91/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566539(364801/91/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566540(364801/91/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566541(364801/91/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566542(364801/91/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566543(364801/91/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566544(364801/91/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566545(364801/91/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566546(364801/91/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566547(364801/91/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566548(364801/91/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566549(364801/91/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566550(364801/91/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566551(364801/91/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566552(364801/91/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566553(364801/91/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566554(364801/91/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566555(364801/91/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566556(364801/91/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566557(364801/91/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566558(364801/91/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566559(364801/91/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566560(364801/91/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566561(364801/91/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566562(364801/91/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566563(364801/91/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566564(364801/91/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566565(364801/92/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566566(364801/92/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566567(364801/92/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566568(364801/92/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566569(364801/92/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566570(364801/92/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566571(364801/92/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566572(364801/92/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566573(364801/92/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566574(364801/92/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566575(364801/92/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566576(364801/92/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566577(364801/92/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566578(364801/92/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566579(364801/92/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566580(364801/92/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566581(364801/92/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566582(364801/92/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566583(364801/92/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566584(364801/92/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566585(364801/92/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566586(364801/92/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566587(364801/92/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566588(364801/92/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566589(364801/92/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566590(364801/92/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566591(364801/92/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566592(364801/92/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566593(364801/92/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566594(364801/92/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566595(364801/92/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566596(364801/92/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566597(364801/92/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566598(364801/92/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566599(364801/92/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566600(364801/92/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566601(364801/92/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566602(364801/92/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566603(364801/92/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566604(364801/92/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566605(364801/92/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566606(364801/92/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566607(364801/92/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566608(364801/92/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566609(364801/92/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566610(364801/92/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566611(364801/92/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566612(364801/92/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566613(364801/92/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566614(364801/92/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565874(364801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565875(364801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565565877(364801/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565881(364801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565565883(364801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565565901(364801/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565565905(364801/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565565906(364801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565565907(364801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565565908(364801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565565909(364801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565565910(364801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565565911(364801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565565912(364801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565913(364801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565914(364801/81/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565565915(364801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565565916(364801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565917(364801/81/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565918(364801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565919(364801/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565565920(364801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565921(364801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565922(364801/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565565924(364801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565925(364801/81/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565565926(364801/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565565927(364801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565928(364801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565565929(364801/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565930(364801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565931(364801/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565565932(364801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565933(364801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565565934(364801/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565565935(364801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565565936(364801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565565937(364801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565565939(364801/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565565940(364801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565565942(364801/82/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565565943(364801/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565565945(364801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565565949(364801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565565951(364801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565565953(364801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565565955(364801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565565956(364801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565565958(364801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565565975(364801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565565976(364801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565565977(364801/82/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565565979(364801/82/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565565980(364801/82/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565565981(364801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565565983(364801/82/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565565984(364801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565565986(364801/82/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565565987(364801/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565565989(364801/82/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565565990(364801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565565992(364801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565565993(364801/82/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565565995(364801/82/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565565999(364801/83/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566001(364801/83/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566003(364801/83/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566005(364801/83/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566006(364801/83/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566008(364801/83/11)) lseek err Invalid argument
Re: Recuperar Partición sin eliminar archivos / Recuperar partición sin eliminar archivos
file_pread(5,1,buffer,1565566615(364801/92/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566616(364801/92/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566617(364801/92/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566618(364801/92/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566619(364801/92/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566620(364801/92/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566621(364801/92/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566622(364801/92/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566623(364801/92/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566624(364801/92/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566625(364801/92/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566626(364801/92/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566627(364801/92/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566628(364801/93/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566629(364801/93/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566630(364801/93/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566631(364801/93/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566632(364801/93/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566633(364801/93/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566634(364801/93/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566635(364801/93/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566636(364801/93/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566637(364801/93/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566638(364801/93/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566639(364801/93/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566640(364801/93/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566641(364801/93/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566642(364801/93/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566643(364801/93/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566644(364801/93/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566645(364801/93/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566646(364801/93/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566647(364801/93/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566648(364801/93/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566649(364801/93/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566650(364801/93/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566651(364801/93/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566652(364801/93/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566653(364801/93/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566654(364801/93/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566655(364801/93/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566656(364801/93/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566657(364801/93/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566658(364801/93/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566659(364801/93/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566660(364801/93/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566661(364801/93/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566662(364801/93/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566663(364801/93/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566664(364801/93/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566665(364801/93/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566666(364801/93/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566667(364801/93/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566668(364801/93/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566669(364801/93/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566670(364801/93/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566671(364801/93/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566672(364801/93/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566673(364801/93/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566674(364801/93/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566675(364801/93/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566676(364801/93/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566677(364801/93/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566678(364801/93/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566679(364801/93/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566680(364801/93/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566681(364801/93/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566682(364801/93/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566683(364801/93/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566684(364801/93/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566685(364801/93/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566686(364801/93/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566687(364801/93/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566688(364801/93/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566689(364801/93/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566690(364801/93/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566691(364801/94/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566692(364801/94/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566693(364801/94/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566694(364801/94/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566695(364801/94/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566696(364801/94/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566697(364801/94/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566698(364801/94/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566699(364801/94/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566700(364801/94/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566701(364801/94/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566702(364801/94/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566703(364801/94/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566704(364801/94/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566705(364801/94/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566706(364801/94/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566707(364801/94/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566708(364801/94/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566709(364801/94/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566710(364801/94/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566711(364801/94/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566712(364801/94/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566713(364801/94/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566714(364801/94/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566715(364801/94/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566716(364801/94/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566717(364801/94/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566718(364801/94/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566719(364801/94/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566720(364801/94/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566721(364801/94/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566722(364801/94/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566723(364801/94/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566724(364801/94/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566725(364801/94/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566726(364801/94/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566727(364801/94/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566728(364801/94/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566729(364801/94/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566730(364801/94/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566731(364801/94/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566732(364801/94/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566733(364801/94/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566734(364801/94/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566735(364801/94/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566736(364801/94/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566737(364801/94/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566738(364801/94/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566739(364801/94/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566740(364801/94/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566741(364801/94/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566742(364801/94/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566743(364801/94/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566744(364801/94/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566745(364801/94/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566746(364801/94/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566747(364801/94/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566748(364801/94/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566749(364801/94/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566750(364801/94/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566751(364801/94/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566752(364801/94/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566753(364801/94/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566754(364801/95/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566755(364801/95/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566756(364801/95/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566757(364801/95/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566758(364801/95/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566759(364801/95/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566760(364801/95/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566761(364801/95/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566762(364801/95/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566763(364801/95/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566764(364801/95/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566765(364801/95/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566766(364801/95/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566767(364801/95/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566768(364801/95/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566769(364801/95/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566770(364801/95/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566771(364801/95/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566772(364801/95/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566773(364801/95/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566774(364801/95/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566775(364801/95/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566776(364801/95/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566777(364801/95/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566778(364801/95/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566779(364801/95/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566780(364801/95/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566781(364801/95/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566782(364801/95/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566783(364801/95/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566784(364801/95/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566785(364801/95/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566786(364801/95/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566787(364801/95/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566788(364801/95/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566789(364801/95/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566790(364801/95/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566791(364801/95/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566792(364801/95/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566793(364801/95/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566794(364801/95/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566795(364801/95/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566796(364801/95/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566797(364801/95/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566798(364801/95/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566799(364801/95/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566800(364801/95/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566801(364801/95/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566802(364801/95/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566803(364801/95/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566804(364801/95/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566805(364801/95/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566806(364801/95/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566807(364801/95/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566808(364801/95/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566809(364801/95/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566810(364801/95/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566811(364801/95/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566812(364801/95/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566813(364801/95/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566814(364801/95/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566815(364801/95/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566816(364801/95/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566817(364801/96/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566818(364801/96/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566819(364801/96/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566820(364801/96/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566821(364801/96/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566822(364801/96/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566823(364801/96/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566824(364801/96/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566825(364801/96/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566826(364801/96/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566827(364801/96/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566828(364801/96/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566829(364801/96/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566830(364801/96/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566831(364801/96/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566832(364801/96/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566833(364801/96/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566834(364801/96/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566835(364801/96/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566836(364801/96/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566837(364801/96/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566838(364801/96/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566839(364801/96/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566840(364801/96/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566841(364801/96/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566842(364801/96/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566843(364801/96/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566844(364801/96/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566845(364801/96/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566846(364801/96/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566847(364801/96/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566848(364801/96/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566849(364801/96/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566850(364801/96/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566851(364801/96/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566852(364801/96/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566853(364801/96/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566854(364801/96/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566855(364801/96/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566856(364801/96/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566857(364801/96/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566858(364801/96/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566859(364801/96/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566860(364801/96/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566861(364801/96/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566862(364801/96/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566863(364801/96/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566864(364801/96/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566865(364801/96/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566866(364801/96/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566867(364801/96/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566868(364801/96/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566869(364801/96/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566870(364801/96/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566871(364801/96/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566872(364801/96/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566873(364801/96/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566874(364801/96/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566875(364801/96/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566876(364801/96/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566877(364801/96/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566878(364801/96/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566879(364801/96/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566880(364801/97/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566881(364801/97/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566882(364801/97/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566883(364801/97/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566884(364801/97/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566885(364801/97/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566886(364801/97/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566887(364801/97/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566888(364801/97/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566889(364801/97/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566890(364801/97/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566891(364801/97/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566892(364801/97/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566893(364801/97/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566894(364801/97/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566895(364801/97/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566896(364801/97/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566897(364801/97/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566898(364801/97/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566899(364801/97/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566900(364801/97/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566901(364801/97/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566902(364801/97/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566903(364801/97/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566904(364801/97/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566905(364801/97/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566906(364801/97/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566907(364801/97/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566908(364801/97/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566909(364801/97/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566910(364801/97/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566911(364801/97/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566912(364801/97/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566913(364801/97/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566914(364801/97/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566915(364801/97/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566916(364801/97/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566917(364801/97/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566918(364801/97/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566919(364801/97/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566920(364801/97/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566921(364801/97/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566922(364801/97/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566923(364801/97/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566924(364801/97/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566925(364801/97/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566926(364801/97/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566927(364801/97/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566928(364801/97/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566929(364801/97/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566930(364801/97/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566931(364801/97/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566932(364801/97/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566933(364801/97/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566934(364801/97/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566935(364801/97/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566936(364801/97/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565566937(364801/97/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565566938(364801/97/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565566939(364801/97/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565566940(364801/97/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565566941(364801/97/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565566942(364801/97/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565566943(364801/98/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565566944(364801/98/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565566945(364801/98/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565566946(364801/98/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565566947(364801/98/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565566948(364801/98/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565566949(364801/98/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565566950(364801/98/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565566951(364801/98/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565566952(364801/98/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565566953(364801/98/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565566954(364801/98/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565566955(364801/98/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565566956(364801/98/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565566957(364801/98/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565566958(364801/98/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565566959(364801/98/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565566960(364801/98/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565566961(364801/98/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565566962(364801/98/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565566963(364801/98/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565566964(364801/98/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565566965(364801/98/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565566966(364801/98/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565566967(364801/98/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565566968(364801/98/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565566969(364801/98/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565566970(364801/98/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565566971(364801/98/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565566972(364801/98/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565566973(364801/98/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565566974(364801/98/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566977(364801/98/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565566978(364801/98/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565566979(364801/98/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565566980(364801/98/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565566981(364801/98/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565566982(364801/98/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565566983(364801/98/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565566984(364801/98/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565566985(364801/98/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565566986(364801/98/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565566987(364801/98/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565566988(364801/98/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565566989(364801/98/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565566990(364801/98/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565566991(364801/98/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565566992(364801/98/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565566993(364801/98/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565566994(364801/98/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565566995(364801/98/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565566996(364801/98/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565566997(364801/98/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565566998(364801/98/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565566999(364801/98/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567000(364801/98/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567001(364801/98/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567002(364801/98/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567003(364801/98/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567004(364801/98/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567005(364801/98/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567006(364801/99/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567007(364801/99/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567008(364801/99/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567009(364801/99/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567010(364801/99/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567011(364801/99/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567012(364801/99/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567013(364801/99/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567014(364801/99/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567015(364801/99/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567016(364801/99/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567017(364801/99/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567018(364801/99/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567019(364801/99/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567020(364801/99/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567021(364801/99/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567022(364801/99/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567023(364801/99/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567024(364801/99/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567025(364801/99/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567026(364801/99/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567027(364801/99/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567028(364801/99/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567029(364801/99/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567030(364801/99/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567031(364801/99/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567032(364801/99/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567033(364801/99/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567034(364801/99/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567035(364801/99/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567036(364801/99/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567037(364801/99/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567039(364801/99/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567040(364801/99/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567041(364801/99/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567042(364801/99/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567043(364801/99/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567044(364801/99/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567045(364801/99/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567046(364801/99/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567047(364801/99/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567048(364801/99/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567049(364801/99/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567050(364801/99/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567051(364801/99/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567052(364801/99/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567053(364801/99/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567054(364801/99/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567055(364801/99/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567056(364801/99/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567057(364801/99/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567058(364801/99/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567059(364801/99/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567060(364801/99/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567061(364801/99/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567062(364801/99/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567063(364801/99/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567064(364801/99/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567065(364801/99/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567066(364801/99/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567067(364801/99/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567068(364801/99/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567069(364801/100/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567070(364801/100/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567071(364801/100/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567072(364801/100/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567073(364801/100/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567074(364801/100/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567075(364801/100/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567076(364801/100/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567077(364801/100/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567078(364801/100/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567079(364801/100/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567080(364801/100/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567081(364801/100/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567082(364801/100/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567083(364801/100/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567084(364801/100/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567085(364801/100/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567086(364801/100/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567087(364801/100/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567088(364801/100/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567089(364801/100/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567090(364801/100/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567091(364801/100/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567092(364801/100/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567093(364801/100/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567094(364801/100/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567095(364801/100/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567096(364801/100/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567097(364801/100/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567098(364801/100/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567099(364801/100/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567100(364801/100/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567102(364801/100/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567103(364801/100/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567104(364801/100/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567105(364801/100/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567106(364801/100/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567107(364801/100/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567108(364801/100/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567109(364801/100/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567110(364801/100/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567111(364801/100/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567112(364801/100/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567113(364801/100/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567114(364801/100/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567115(364801/100/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567116(364801/100/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567117(364801/100/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567118(364801/100/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567119(364801/100/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567120(364801/100/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567121(364801/100/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567122(364801/100/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567123(364801/100/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567124(364801/100/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567125(364801/100/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567126(364801/100/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567127(364801/100/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567128(364801/100/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567129(364801/100/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567130(364801/100/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567131(364801/100/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567132(364801/101/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567133(364801/101/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567134(364801/101/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567135(364801/101/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567136(364801/101/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567137(364801/101/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567138(364801/101/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567139(364801/101/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567140(364801/101/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567141(364801/101/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567142(364801/101/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567143(364801/101/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567144(364801/101/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567145(364801/101/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567146(364801/101/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567147(364801/101/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567148(364801/101/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567149(364801/101/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567150(364801/101/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567151(364801/101/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567152(364801/101/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567153(364801/101/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567154(364801/101/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567155(364801/101/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567156(364801/101/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567157(364801/101/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567158(364801/101/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567159(364801/101/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567160(364801/101/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567161(364801/101/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567162(364801/101/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567163(364801/101/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567164(364801/101/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567165(364801/101/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567166(364801/101/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567167(364801/101/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567168(364801/101/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567169(364801/101/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567170(364801/101/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567171(364801/101/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567172(364801/101/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567173(364801/101/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567174(364801/101/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567175(364801/101/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567176(364801/101/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567177(364801/101/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567178(364801/101/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567179(364801/101/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567180(364801/101/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567181(364801/101/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567182(364801/101/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567183(364801/101/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567184(364801/101/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567185(364801/101/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567186(364801/101/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567187(364801/101/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567188(364801/101/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567189(364801/101/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567190(364801/101/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567191(364801/101/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567192(364801/101/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567193(364801/101/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567194(364801/101/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567195(364801/102/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567196(364801/102/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567197(364801/102/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567198(364801/102/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567199(364801/102/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567200(364801/102/6)) lseek err Invalid argument
file_pread(5,1,buffer,1565567201(364801/102/7)) lseek err Invalid argument
file_pread(5,1,buffer,1565567202(364801/102/8)) lseek err Invalid argument
file_pread(5,1,buffer,1565567203(364801/102/9)) lseek err Invalid argument
file_pread(5,1,buffer,1565567204(364801/102/10)) lseek err Invalid argument
file_pread(5,1,buffer,1565567205(364801/102/11)) lseek err Invalid argument
file_pread(5,1,buffer,1565567206(364801/102/12)) lseek err Invalid argument
file_pread(5,1,buffer,1565567207(364801/102/13)) lseek err Invalid argument
file_pread(5,1,buffer,1565567208(364801/102/14)) lseek err Invalid argument
file_pread(5,1,buffer,1565567209(364801/102/15)) lseek err Invalid argument
file_pread(5,1,buffer,1565567210(364801/102/16)) lseek err Invalid argument
file_pread(5,1,buffer,1565567211(364801/102/17)) lseek err Invalid argument
file_pread(5,1,buffer,1565567212(364801/102/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565567213(364801/102/19)) lseek err Invalid argument
file_pread(5,1,buffer,1565567214(364801/102/20)) lseek err Invalid argument
file_pread(5,1,buffer,1565567215(364801/102/21)) lseek err Invalid argument
file_pread(5,1,buffer,1565567216(364801/102/22)) lseek err Invalid argument
file_pread(5,1,buffer,1565567217(364801/102/23)) lseek err Invalid argument
file_pread(5,1,buffer,1565567218(364801/102/24)) lseek err Invalid argument
file_pread(5,1,buffer,1565567219(364801/102/25)) lseek err Invalid argument
file_pread(5,1,buffer,1565567220(364801/102/26)) lseek err Invalid argument
file_pread(5,1,buffer,1565567221(364801/102/27)) lseek err Invalid argument
file_pread(5,1,buffer,1565567222(364801/102/28)) lseek err Invalid argument
file_pread(5,1,buffer,1565567223(364801/102/29)) lseek err Invalid argument
file_pread(5,1,buffer,1565567224(364801/102/30)) lseek err Invalid argument
file_pread(5,1,buffer,1565567225(364801/102/31)) lseek err Invalid argument
file_pread(5,1,buffer,1565567226(364801/102/32)) lseek err Invalid argument
file_pread(5,1,buffer,1565567227(364801/102/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567228(364801/102/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565567229(364801/102/35)) lseek err Invalid argument
file_pread(5,1,buffer,1565567230(364801/102/36)) lseek err Invalid argument
file_pread(5,1,buffer,1565567231(364801/102/37)) lseek err Invalid argument
file_pread(5,1,buffer,1565567232(364801/102/38)) lseek err Invalid argument
file_pread(5,1,buffer,1565567233(364801/102/39)) lseek err Invalid argument
file_pread(5,1,buffer,1565567234(364801/102/40)) lseek err Invalid argument
file_pread(5,1,buffer,1565567235(364801/102/41)) lseek err Invalid argument
file_pread(5,1,buffer,1565567236(364801/102/42)) lseek err Invalid argument
file_pread(5,1,buffer,1565567237(364801/102/43)) lseek err Invalid argument
file_pread(5,1,buffer,1565567238(364801/102/44)) lseek err Invalid argument
file_pread(5,1,buffer,1565567239(364801/102/45)) lseek err Invalid argument
file_pread(5,1,buffer,1565567240(364801/102/46)) lseek err Invalid argument
file_pread(5,1,buffer,1565567241(364801/102/47)) lseek err Invalid argument
file_pread(5,1,buffer,1565567242(364801/102/48)) lseek err Invalid argument
file_pread(5,1,buffer,1565567243(364801/102/49)) lseek err Invalid argument
file_pread(5,1,buffer,1565567244(364801/102/50)) lseek err Invalid argument
file_pread(5,1,buffer,1565567245(364801/102/51)) lseek err Invalid argument
file_pread(5,1,buffer,1565567246(364801/102/52)) lseek err Invalid argument
file_pread(5,1,buffer,1565567247(364801/102/53)) lseek err Invalid argument
file_pread(5,1,buffer,1565567248(364801/102/54)) lseek err Invalid argument
file_pread(5,1,buffer,1565567249(364801/102/55)) lseek err Invalid argument
file_pread(5,1,buffer,1565567250(364801/102/56)) lseek err Invalid argument
file_pread(5,1,buffer,1565567251(364801/102/57)) lseek err Invalid argument
file_pread(5,1,buffer,1565567252(364801/102/58)) lseek err Invalid argument
file_pread(5,1,buffer,1565567253(364801/102/59)) lseek err Invalid argument
file_pread(5,1,buffer,1565567254(364801/102/60)) lseek err Invalid argument
file_pread(5,1,buffer,1565567255(364801/102/61)) lseek err Invalid argument
file_pread(5,1,buffer,1565567256(364801/102/62)) lseek err Invalid argument
file_pread(5,1,buffer,1565567257(364801/102/63)) lseek err Invalid argument
file_pread(5,1,buffer,1565567258(364801/103/1)) lseek err Invalid argument
file_pread(5,1,buffer,1565567259(364801/103/2)) lseek err Invalid argument
file_pread(5,1,buffer,1565567260(364801/103/3)) lseek err Invalid argument
file_pread(5,1,buffer,1565567261(364801/103/4)) lseek err Invalid argument
file_pread(5,1,buffer,1565567262(364801/103/5)) lseek err Invalid argument
file_pread(5,1,buffer,1565567263(364801/103/6)) lseek err Invalid argument
B
B
