What I did:
- I deleted partition thru os installed but did not format
- I run search, didnt saw my partition, did deep search and saw my parition there that was labled correctly "Mechanik" which was 1TB size (correct)
- pick it as L and hit "write", rebooted
I probably pick wrong source of table (there was backup or org) because there were error about them being different
Now I have partition "Reserved by system (D:)" which is correct size but dont contains my data.
When I run testdisk search/deepserach I cannot see my partition that was labeled.
This is my disk:
Disk /dev/sdb - 1000 GB / 931 GiB - SAMSUNG HD103SJ
CHS 121601 255 63 - sector size=512
When entering into Rebuild BS I get:
TestDisk 7.2-WIP, Data Recovery Utility, September 2020
5 L HPFS - NTFS 0 32 33 121600 247 55 1953517568 [Zastrze]
filesystem size 1953517568 102400
sectors_per_cluster 8 8
mft_lcn 4266 4266
mftmirr_lcn 2 2
clusters_per_mft_record -10 -10
clusters_per_index_record 1 1
Any suggestion what can I do now ?
My Partition vanished after writing it to disk Topic is solved
Re: My Partition vanished after writing it to disk
Run TestDisk, Advanced, Boot, RebuildBS, List. If you can see your lost files, choose Write, confirm, Quit and restart your computer.
sorry for late response I was freak out by the issue and handle it in other way.cgrenier wrote: 17 Sep 2020, 10:05 Run TestDisk, Advanced, Boot, RebuildBS, List. If you can see your lost files, choose Write, confirm, Quit and restart your computer.
Im not sure how it was when I was doing it but just in case some lost soul will struggle, testdisk would only show bad size partition, same with files.
When I was listing files some of them were missing. I tried few other tools but most of them (the "free" if was showing parition size correct then it would need to "unlock" premium function).
As a last resort I tried non-free application and was able to somehow read correct parition size - looks like I mess with those tools too much, I overwrite bad MBR and so on (inside RebuildBS)
To be honest I had decent success rate wtih TestDisk but that was not enough of knowleght to be able to use it to recover my partition.
Somehow I end up with 100% intact (can't check crc but im using day even now, so what was lost wasn't important)
