Greetings,
After simply shutting down my tablet PC (Cube Mix Plus) after a day like any other, I'm unable to boot the OS (Windows 10 Home 64-bit). The Windows Boot Manager option suddenly disappeared from the Boot priority option in the bios.
Using TestDisk, it seems that the partitions were deleted for some unknow reason. The problem is that the only two options for partition characteristic is either Primary or Deleted, so I'm unable to change the partitions from Deleted to Bootable. I tried both quick search (Picture 1) and deeper search (Picture 2), but the problem remains.
I tried to find an answer to this issue by looking at the guide and the documentation, as well as in the forums, but I couldn't find a solution.
Am I missing something here? Can someone please shed some light on the matter? Any help would be appreciated.
Thank you.
Unable to change partition from "Deleted" to "Bootable" (option not available)
Faithlessaint
- Picture 1.png (62.83 KiB) Viewed 1573 times
- Picture 2.png (142.04 KiB) Viewed 1573 times
Re: Unable to change partition from "Deleted" to "Bootable" (option not available)
The boot process using a mainboard in UEFI mode works differently on GPT partitioned drives.Faithlessaint wrote: 16 Sep 2020, 19:11 Using TestDisk, it seems that the partitions were deleted for some unknow reason. The problem is that the only two options for partition characteristic is either Primary or Deleted, so I'm unable to change the partitions from Deleted to Bootable. I tried both quick search (Picture 1) and deeper search (Picture 2), but the problem remains.
To reenable a partition you would need to set it to "primary".
As I don't run such a configuration I have no further details available.
