Hello ,
I apologize in advance if my question is repeated but I did my best to search and follow the instructions provided . I erased my 2T WD external drive filesystem by mistake using diskpart clean command then assigned a letter to it . the current situation is :
- Nothing was written to the disk after the accident
- I don't think that the drive has a physical issue
- Photorec and other data recovery software can see my data files but not the root directory and not the original folders tree .
- I took a copy of the raw drive but was never able to create the Linux live USB to try the DDrescue as per the testdisk guide. I kept getting error either to write the USB or to boot from it .
- I'm not sure what was the original file system
- Through my long trials to restore the boot sector, testdisk detected the drive as Intel sometimes and as EFI-GPT other times ( I believe WD my passport might be GPT)
- My data on the disk contained uninstalled Linux Opensuse virtual machines that I believe was detected as Linux partition on my drive .
- The NTFS partition found by testdisk didn't have any files
- I've been trying for more than a month now , my laptop was scanning 24/7 and I don't know what to do anymore .
I appreciate any help I can get .
One of my scans logs is below :
Restore filesystem after diskpart clean
Re: Restore filesystem after diskpart clean
If you used the diskpart clean command the whole content of your disk should have been deleted and there is nothing to recover anymore.
That contradicts your statement "Photorec and other data recovery software can see my data files but not the root directory and not the original folders tree ."
Thank you for the reply Recuperation
As per Microsoft Docs ( https://docs.microsoft.com/en-us/window ... ands/clean )
On master boot record (MBR) disks, only the MBR partitioning information and hidden sector information is overwritten.
On GUID Partition Table (gpt) disks, the gpt partitioning information, including the Protective MBR, is overwritten. There is no hidden sector information.
the scan log :"
Sun Sep 13 18:37:54 2020
TestDisk 7.2-WIP, Data Recovery Utility, August 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1860185692672
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=137438953472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1048576000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000363192320
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000LM015-2E8174, S/N:ZDZBWKA5, FW:0001
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate BUP Slim RD, S/N:NA7SBFTH, FW:0304
Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512 - WD My Passport 0748, S/N:WX21AC2E3137, FW:1019
Disk /dev/sdc - 2000 GB / 1862 GiB - WD My Passport 0748
Partition table type: EFI GPT
Analyse Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3906963455 (expected 3906963455)
hdr_lba_start=34
hdr_lba_end=3906963422
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 3906961407 3906959360 [Basic data partition]
recover_EXT2: s_block_group_nr=0/303, s_mnt_count=2/29, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 9959680
recover_EXT2: part_size 79677440
Filesystem created: Mon Apr 15 03:36:19 2013
Last mount time: Mon Apr 15 03:45:07 2013
Linux filesys. data 275868454 355545893 79677440
ext4 blocksize=4096 Large_file Sparse_SB Recover, 40 GB / 37 GiB
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/303, s_mnt_count=0/23, s_blocks_per_group=32768, s_inodes_per_group=8192
Filesystem created: Fri Apr 19 03:29:06 2013
Linux filesys. data 323676702 403354141 79677440
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 40 GB / 37 GiB
recover_EXT2: s_block_group_nr=0/303, s_mnt_count=14/23, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Thu May 2 18:14:25 2013
Linux filesys. data 1120788646 1200466085 79677440
ext4 blocksize=4096 Large_file Sparse_SB, 40 GB / 37 GiB
recover_EXT2: s_block_group_nr=0/303, s_mnt_count=18/23, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Sun May 5 11:48:13 2013
Linux filesys. data 1200483280 1280160719 79677440
recover_EXT2: s_block_group_nr=0/125, s_mnt_count=21/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8144
recover_EXT2: s_blocks_count 4102400
recover_EXT2: part_size 32819200
Filesystem created: Wed Mar 13 15:26:17 2013
Last mount time: Mon Mar 25 19:14:47 2013
Linux filesys. data 1347756920 1380576119 32819200
ext4 blocksize=4096 Large_file Sparse_SB Recover, 16 GB / 15 GiB
Linux filesys. data 1381456984 1414276183 32819200
Linux filesys. data 1414903360 1414903359 0
LUKS 0 (Data size unknown), 0 B
Partition not added.
recover_EXT2: s_block_group_nr=0/303, s_mnt_count=4/29, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Wed Apr 17 17:52:07 2013
Linux filesys. data 1416765326 1496442765 79677440
Linux filesys. data 1562491864 1595311063 32819200
Linux filesys. data 1596191920 1629011119 32819200
Linux filesys. data 1629637792 1629637791 0
Linux filesys. data 1631499758 1711177197 79677440
Linux Swap 1715790584 1715790599 16
SWAP2 version 0, pagesize=8192, 8192 B
recover_EXT2: s_block_group_nr=0/89, s_mnt_count=6/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8112
recover_EXT2: s_blocks_count 2917376
recover_EXT2: part_size 23339008
Filesystem created: Wed Nov 27 03:52:02 2013
Last mount time: Sat Dec 14 08:25:05 2013
Linux filesys. data 1776693496 1800032503 23339008
ext4 blocksize=4096 Large_file Sparse_SB Recover, 11 GB / 11 GiB
recover_EXT2: s_block_group_nr=0/303, s_mnt_count=5/23, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Sun Dec 8 22:01:20 2013
Linux filesys. data 1805802278 1885479717 79677440
LVM magic value at 119005/81/59
LVM magic value at 119123/203/58
FAT16 at 119143/197/38
FAT1 : 1-119
FAT2 : 120-238
start_rootdir : 239
Data : 271-967438
sectors : 967439
cluster_size : 32
no_of_cluster : 30224 (2 - 30225)
fat_length 119 calculated 119
FAT differs, FAT sectors=0-16/119
heads/cylinder 16 (FAT) != 255 (HD)
MS Data 1914044743 1915012181 967439 [NO NAME]
FAT16, blocksize=16384, 495 MB / 472 MiB
file_pread(6,1,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,1,buffer,3906963458(243197/57/63)) lseek err Invalid argument
file_pread(6,1,buffer,3906963459(243197/58/1)) lseek err Invalid argument
file_pread(6,1,buffer,3906963460(243197/58/2)) lseek err Invalid argument
file_pread(6,1,buffer,3906963461(243197/58/3)) lseek err Invalid argument
file_pread(6,1,buffer,3906963462(243197/58/4)) lseek err Invalid argument
file_pread(6,1,buffer,3906963463(243197/58/5)) lseek err Invalid argument
file_pread(6,1,buffer,3906963464(243197/58/6)) lseek err Invalid argument
file_pread(6,1,buffer,3906965366(243197/88/18)) lseek err Invalid argument
file_pread(6,1,buffer,3906965367(243197/88/19)) lseek err Invalid argument
file_pread(6,1,buffer,3906965368(243197/88/20)) lseek err Invalid argument
file_pread(6,1,buffer,3906965369(243197/88/21)) lseek err Invalid argument
file_pread(6,1,buffer,3906965370(243197/88/22)) lseek err Invalid argument
file_pread(6,1,buffer,3906965371(243197/88/23)) lseek err Invalid argument
file_pread(6,1,buffer,3906965372(243197/88/24)) lseek err Invalid argument
file_pread(6,11,buffer,3906963450(243197/57/55)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,3906965373(243197/88/25)) lseek err Invalid argument
file_pread(6,5,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,1,buffer,3906965374(243197/88/26)) lseek err Invalid argument
file_pread(6,1,buffer,3906965375(243197/88/27)) lseek err Invalid argument
file_pread(6,1,buffer,3906965376(243197/88/28)) lseek err Invalid argument
file_pread(6,1,buffer,3906965377(243197/88/29)) lseek err Invalid argument
file_pread(6,1,buffer,3906963465(243197/58/7)) lseek err Invalid argument
file_pread(6,1,buffer,3906965378(243197/88/30)) lseek err Invalid argument
file_pread(6,11,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,3906965379(243197/88/31)) lseek err Invalid argument
file_pread(6,1,buffer,3906963467(243197/58/9)) lseek err Invalid argument
file_pread(6,1,buffer,3906965380(243197/88/32)) lseek err Invalid argument
file_pread(6,1,buffer,3906963468(243197/58/10)) lseek err Invalid argument
file_pread(6,1,buffer,3906965381(243197/88/33)) lseek err Invalid argument
file_pread(6,1,buffer,3906963469(243197/58/11)) lseek err Invalid argument
file_pread(6,1,buffer,3906965382(243197/88/34)) lseek err Invalid argument
file_pread(6,1,buffer,3906963470(243197/58/12)) lseek err Invalid argument
file_pread(6,1,buffer,3906965383(243197/88/35)) lseek err Invalid argument
file_pread(6,1,buffer,3906963471(243197/58/13)) lseek err Invalid argument
file_pread(6,1,buffer,3906965384(243197/88/36)) lseek err Invalid argument
file_pread(6,11,buffer,3906963462(243197/58/4)) lseek err Invalid argument
file_pread(6,1,buffer,3906965385(243197/88/37)) lseek err Invalid argument
file_pread(6,1,buffer,3906963473(243197/58/15)) lseek err Invalid argument
file_pread(6,1,buffer,3906965386(243197/88/38)) lseek err Invalid argument
file_pread(6,1,buffer,3906963474(243197/58/16)) lseek err Invalid argument
file_pread(6,1,buffer,3906965387(243197/88/39)) lseek err Invalid argument
file_pread(6,1,buffer,3906963475(243197/58/17)) lseek err Invalid argument
file_pread(6,1,buffer,3906965388(243197/88/40)) lseek err Invalid argument
file_pread(6,1,buffer,3906963476(243197/58/18)) lseek err Invalid argument
file_pread(6,1,buffer,3906965389(243197/88/41)) lseek err Invalid argument
file_pread(6,1,buffer,3906963477(243197/58/19)) lseek err Invalid argument
file_pread(6,1,buffer,3906965390(243197/88/42)) lseek err Invalid argument
file_pread(6,11,buffer,3906963468(243197/58/10)) lseek err Invalid argument
file_pread(6,1,buffer,3906965391(243197/88/43)) lseek err Invalid argument
file_pread(6,1,buffer,3906963479(243197/58/21)) lseek err Invalid argument
file_pread(6,1,buffer,3906965392(243197/88/44)) lseek err Invalid argument
file_pread(6,1,buffer,3906963480(243197/58/22)) lseek err Invalid argument
file_pread(6,1,buffer,3906965393(243197/88/45)) lseek err Invalid argument
file_pread(6,1,buffer,3906963481(243197/58/23)) lseek err Invalid argument
file_pread(6,1,buffer,3906965394(243197/88/46)) lseek err Invalid argument
file_pread(6,1,buffer,3906963482(243197/58/24)) lseek err Invalid argument
file_pread(6,1,buffer,3906965395(243197/88/47)) lseek err Invalid argument
file_pread(6,1,buffer,3906963483(243197/58/25)) lseek err Invalid argument
file_pread(6,1,buffer,3906965396(243197/88/48)) lseek err Invalid argument
file_pread(6,11,buffer,3906963474(243197/58/16)) lseek err Invalid argument
file_pread(6,1,buffer,3906965397(243197/88/49)) lseek err Invalid argument
file_pread(6,11,buffer,3906963475(243197/58/17)) lseek err Invalid argument
file_pread(6,1,buffer,3906965398(243197/88/50)) lseek err Invalid argument
file_pread(6,1,buffer,3906963486(243197/58/28)) lseek err Invalid argument
file_pread(6,1,buffer,3906965399(243197/88/51)) lseek err Invalid argument
file_pread(6,1,buffer,3906963487(243197/58/29)) lseek err Invalid argument
file_pread(6,1,buffer,3906965400(243197/88/52)) lseek err Invalid argument
file_pread(6,1,buffer,3906963488(243197/58/30)) lseek err Invalid argument
file_pread(6,1,buffer,3906965401(243197/88/53)) lseek err Invalid argument
file_pread(6,1,buffer,3906963489(243197/58/31)) lseek err Invalid argument
file_pread(6,1,buffer,3906965402(243197/88/54)) lseek err Invalid argument
file_pread(6,1,buffer,3906963490(243197/58/32)) lseek err Invalid argument
file_pread(6,1,buffer,3906965403(243197/88/55)) lseek err Invalid argument
file_pread(6,11,buffer,3906963481(243197/58/23)) lseek err Invalid argument
file_pread(6,1,buffer,3906965404(243197/88/56)) lseek err Invalid argument
file_pread(6,1,buffer,3906963492(243197/58/34)) lseek err Invalid argument
file_pread(6,1,buffer,3906965405(243197/88/57)) lseek err Invalid argument
file_pread(6,1,buffer,3906963493(243197/58/35)) lseek err Invalid argument
file_pread(6,1,buffer,3906965406(243197/88/58)) lseek err Invalid argument
file_pread(6,1,buffer,3906963494(243197/58/36)) lseek err Invalid argument
file_pread(6,1,buffer,3906965407(243197/88/59)) lseek err Invalid argument
file_pread(6,1,buffer,3906963495(243197/58/37)) lseek err Invalid argument
file_pread(6,1,buffer,3906965408(243197/88/60)) lseek err Invalid argument
file_pread(6,1,buffer,3906963496(243197/58/38)) lseek err Invalid argument
file_pread(6,1,buffer,3906965409(243197/88/61)) lseek err Invalid argument
file_pread(6,11,buffer,3906963487(243197/58/29)) lseek err Invalid argument
file_pread(6,1,buffer,3906965410(243197/88/62)) lseek err Invalid argument
file_pread(6,11,buffer,3906963488(243197/58/30)) lseek err Invalid argument
file_pread(6,1,buffer,3906965411(243197/88/63)) lseek err Invalid argument
file_pread(6,11,buffer,3906963489(243197/58/31)) lseek err Invalid argument
file_pread(6,1,buffer,3906965412(243197/89/1)) lseek err Invalid argument
file_pread(6,11,buffer,3906963490(243197/58/32)) lseek err Invalid argument
file_pread(6,1,buffer,3906965413(243197/89/2)) lseek err Invalid argument
file_pread(6,11,buffer,3906963491(243197/58/33)) lseek err Invalid argument
file_pread(6,1,buffer,3906963491(243197/58/33)) lseek err Invalid argument
file_pread(6,1,buffer,3906965414(243197/89/3)) lseek err Invalid argument
file_pread(6,11,buffer,3906963492(243197/58/34)) lseek err Invalid argument
file_pread(6,1,buffer,3906965415(243197/89/4)) lseek err Invalid argument
file_pread(6,11,buffer,3906963493(243197/58/35)) lseek err Invalid argument
file_pread(6,1,buffer,3906965416(243197/89/5)) lseek err Invalid argument
file_pread(6,11,buffer,3906963494(243197/58/36)) lseek err Invalid argument
file_pread(6,1,buffer,3906965417(243197/89/6)) lseek err Invalid argument
file_pread(6,11,buffer,3906963495(243197/58/37)) lseek err Invalid argument
file_pread(6,1,buffer,3906965418(243197/89/7)) lseek err Invalid argument
file_pread(6,11,buffer,3906963496(243197/58/38)) lseek err Invalid argument
file_pread(6,1,buffer,3906965419(243197/89/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906963507(243197/58/49)) lseek err Invalid argument
file_pread(6,1,buffer,3906965420(243197/89/9)) lseek err Invalid argument
file_pread(6,1,buffer,3906963508(243197/58/50)) lseek err Invalid argument
file_pread(6,1,buffer,3906965421(243197/89/10)) lseek err Invalid argument
file_pread(6,1,buffer,3906963509(243197/58/51)) lseek err Invalid argument
file_pread(6,1,buffer,3906965422(243197/89/11)) lseek err Invalid argument
file_pread(6,8,buffer,3906963453(243197/57/58)) ReadFile The drive cannot find the sector requested.
file_pread(6,11,buffer,3906963500(243197/58/42)) lseek err Invalid argument
file_pread(6,1,buffer,3906965423(243197/89/12)) lseek err Invalid argument
file_pread(6,1,buffer,3906963511(243197/58/53)) lseek err Invalid argument
file_pread(6,1,buffer,3906965424(243197/89/13)) lseek err Invalid argument
file_pread(6,1,buffer,3906963512(243197/58/54)) lseek err Invalid argument
file_pread(6,1,buffer,3906965425(243197/89/14)) lseek err Invalid argument
file_pread(6,1,buffer,3906963513(243197/58/55)) lseek err Invalid argument
file_pread(6,1,buffer,3906965426(243197/89/15)) lseek err Invalid argument
file_pread(6,1,buffer,3906963514(243197/58/56)) lseek err Invalid argument
file_pread(6,1,buffer,3906965427(243197/89/16)) lseek err Invalid argument
file_pread(6,8,buffer,3906963458(243197/57/63)) lseek err Invalid argument
file_pread(6,11,buffer,3906963505(243197/58/47)) lseek err Invalid argument
file_pread(6,1,buffer,3906965428(243197/89/17)) lseek err Invalid argument
file_pread(6,8,buffer,3906963459(243197/58/1)) lseek err Invalid argument
file_pread(6,1,buffer,3906963516(243197/58/58)) lseek err Invalid argument
file_pread(6,1,buffer,3906965429(243197/89/18)) lseek err Invalid argument
file_pread(6,8,buffer,3906963460(243197/58/2)) lseek err Invalid argument
file_pread(6,1,buffer,3906963517(243197/58/59)) lseek err Invalid argument
file_pread(6,1,buffer,3906965430(243197/89/19)) lseek err Invalid argument
file_pread(6,8,buffer,3906963461(243197/58/3)) lseek err Invalid argument
file_pread(6,11,buffer,3906963508(243197/58/50)) lseek err Invalid argument
file_pread(6,1,buffer,3906965431(243197/89/20)) lseek err Invalid argument
file_pread(6,8,buffer,3906963462(243197/58/4)) lseek err Invalid argument
file_pread(6,1,buffer,3906963519(243197/58/61)) lseek err Invalid argument
file_pread(6,1,buffer,3906965432(243197/89/21)) lseek err Invalid argument
file_pread(6,8,buffer,3906963463(243197/58/5)) lseek err Invalid argument
file_pread(6,1,buffer,3906963520(243197/58/62)) lseek err Invalid argument
file_pread(6,1,buffer,3906965433(243197/89/22)) lseek err Invalid argument
file_pread(6,8,buffer,3906963464(243197/58/6)) lseek err Invalid argument
file_pread(6,11,buffer,3906963511(243197/58/53)) lseek err Invalid argument
file_pread(6,1,buffer,3906965434(243197/89/23)) lseek err Invalid argument
file_pread(6,8,buffer,3906963465(243197/58/7)) lseek err Invalid argument
file_pread(6,1,buffer,3906963522(243197/59/1)) lseek err Invalid argument
file_pread(6,1,buffer,3906965435(243197/89/24)) lseek err Invalid argument
file_pread(6,8,buffer,3906963466(243197/58/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906963466(243197/58/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906963523(243197/59/2)) lseek err Invalid argument
file_pread(6,1,buffer,3906965436(243197/89/25)) lseek err Invalid argument
file_pread(6,8,buffer,3906963467(243197/58/9)) lseek err Invalid argument
file_pread(6,11,buffer,3906963514(243197/58/56)) lseek err Invalid argument
file_pread(6,1,buffer,3906965437(243197/89/26)) lseek err Invalid argument
file_pread(6,8,buffer,3906963468(243197/58/10)) lseek err Invalid argument
file_pread(6,1,buffer,3906963525(243197/59/4)) lseek err Invalid argument
file_pread(6,1,buffer,3906965438(243197/89/27)) lseek err Invalid argument
file_pread(6,8,buffer,3906963469(243197/58/11)) lseek err Invalid argument
file_pread(6,1,buffer,3906963526(243197/59/5)) lseek err Invalid argument
file_pread(6,1,buffer,3906965439(243197/89/28)) lseek err Invalid argument
file_pread(6,8,buffer,3906963470(243197/58/12)) lseek err Invalid argument
file_pread(6,11,buffer,3906963517(243197/58/59)) lseek err Invalid argument
file_pread(6,1,buffer,3906965440(243197/89/29)) lseek err Invalid argument
file_pread(6,1,buffer,3906963478(243197/58/20)) lseek err Invalid argument
file_pread(6,1,buffer,3906963528(243197/59/7)) lseek err Invalid argument
file_pread(6,1,buffer,3906965441(243197/89/30)) lseek err Invalid argument
file_pread(6,1,buffer,3906963529(243197/59/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906965442(243197/89/31)) lseek err Invalid argument
file_pread(6,1,buffer,3906963530(243197/59/9)) lseek err Invalid argument
file_pread(6,1,buffer,3906965443(243197/89/32)) lseek err Invalid argument
file_pread(6,8,buffer,3906963474(243197/58/16)) lseek err Invalid argument
file_pread(6,11,buffer,3906963521(243197/58/63)) lseek err Invalid argument
file_pread(6,1,buffer,3906965444(243197/89/33)) lseek err Invalid argument
file_pread(6,1,buffer,3906963532(243197/59/11)) lseek err Invalid argument
file_pread(6,1,buffer,3906965445(243197/89/34)) lseek err Invalid argument
file_pread(6,1,buffer,3906963533(243197/59/12)) lseek err Invalid argument
file_pread(6,1,buffer,3906965446(243197/89/35)) lseek err Invalid argument
file_pread(6,1,buffer,3906963484(243197/58/26)) lseek err Invalid argument
file_pread(6,1,buffer,3906963534(243197/59/13)) lseek err Invalid argument
file_pread(6,1,buffer,3906965447(243197/89/36)) lseek err Invalid argument
file_pread(6,8,buffer,3906963478(243197/58/20)) lseek err Invalid argument
file_pread(6,11,buffer,3906963525(243197/59/4)) lseek err Invalid argument
file_pread(6,1,buffer,3906965448(243197/89/37)) lseek err Invalid argument
file_pread(6,1,buffer,3906963536(243197/59/15)) lseek err Invalid argument
file_pread(6,1,buffer,3906965449(243197/89/38)) lseek err Invalid argument
file_pread(6,1,buffer,3906963537(243197/59/16)) lseek err Invalid argument
file_pread(6,1,buffer,3906965450(243197/89/39)) lseek err Invalid argument
file_pread(6,1,buffer,3906963538(243197/59/17)) lseek err Invalid argument
file_pread(6,1,buffer,3906965451(243197/89/40)) lseek err Invalid argument
file_pread(6,8,buffer,3906963482(243197/58/24)) lseek err Invalid argument
file_pread(6,11,buffer,3906963529(243197/59/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906965452(243197/89/41)) lseek err Invalid argument
file_pread(6,1,buffer,3906963540(243197/59/19)) lseek err Invalid argument
file_pread(6,1,buffer,3906965453(243197/89/42)) lseek err Invalid argument
file_pread(6,1,buffer,3906963541(243197/59/20)) lseek err Invalid argument
file_pread(6,1,buffer,3906965454(243197/89/43)) lseek err Invalid argument
file_pread(6,1,buffer,3906963542(243197/59/21)) lseek err Invalid argument
file_pread(6,1,buffer,3906965455(243197/89/44)) lseek err Invalid argument
file_pread(6,1,buffer,3906963472(243197/58/14)) lseek err Invalid argument
file_pread(6,8,buffer,3906963486(243197/58/28)) lseek err Invalid argument
file_pread(6,11,buffer,3906963533(243197/59/12)) lseek err Invalid argument
file_pread(6,1,buffer,3906965456(243197/89/45)) lseek err Invalid argument
file_pread(6,1,buffer,3906963544(243197/59/23)) lseek err Invalid argument
file_pread(6,1,buffer,3906965457(243197/89/46)) lseek err Invalid argument
file_pread(6,1,buffer,3906963545(243197/59/24)) lseek err Invalid argument
file_pread(6,1,buffer,3906965458(243197/89/47)) lseek err Invalid argument
file_pread(6,1,buffer,3906963546(243197/59/25)) lseek err Invalid argument
file_pread(6,1,buffer,3906965459(243197/89/48)) lseek err Invalid argument
file_pread(6,8,buffer,3906963490(243197/58/32)) lseek err Invalid argument
file_pread(6,11,buffer,3906963537(243197/59/16)) lseek err Invalid argument
file_pread(6,1,buffer,3906965460(243197/89/49)) lseek err Invalid argument
file_pread(6,1,buffer,3906963498(243197/58/40)) lseek err Invalid argument
file_pread(6,1,buffer,3906963548(243197/59/27)) lseek err Invalid argument
file_pread(6,1,buffer,3906965461(243197/89/50)) lseek err Invalid argument
file_pread(6,1,buffer,3906963499(243197/58/41)) lseek err Invalid argument
file_pread(6,1,buffer,3906963549(243197/59/28)) lseek err Invalid argument
file_pread(6,1,buffer,3906965462(243197/89/51)) lseek err Invalid argument
file_pread(6,1,buffer,3906963500(243197/58/42)) lseek err Invalid argument
file_pread(6,1,buffer,3906963550(243197/59/29)) lseek err Invalid argument
file_pread(6,1,buffer,3906965463(243197/89/52)) lseek err Invalid argument
file_pread(6,8,buffer,3906963494(243197/58/36)) lseek err Invalid argument
file_pread(6,11,buffer,3906963541(243197/59/20)) lseek err Invalid argument
file_pread(6,1,buffer,3906965464(243197/89/53)) lseek err Invalid argument
file_pread(6,1,buffer,3906963502(243197/58/44)) lseek err Invalid argument
file_pread(6,1,buffer,3906963552(243197/59/31)) lseek err Invalid argument
file_pread(6,1,buffer,3906965465(243197/89/54)) lseek err Invalid argument
file_pread(6,1,buffer,3906963503(243197/58/45)) lseek err Invalid argument
file_pread(6,1,buffer,3906963553(243197/59/32)) lseek err Invalid argument
file_pread(6,1,buffer,3906965466(243197/89/55)) lseek err Invalid argument
file_pread(6,1,buffer,3906963504(243197/58/46)) lseek err Invalid argument
file_pread(6,1,buffer,3906963554(243197/59/33)) lseek err Invalid argument
file_pread(6,1,buffer,3906965467(243197/89/56)) lseek err Invalid argument
file_pread(6,8,buffer,3906963498(243197/58/40)) lseek err Invalid argument
file_pread(6,11,buffer,3906963545(243197/59/24)) lseek err Invalid argument
file_pread(6,11,buffer,3906963559(243197/59/38)) lseek err Invalid argument
file_pread(6,1,buffer,3906965482(243197/90/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906963570(243197/59/49)) lseek err Invalid argument
file_pread(6,1,buffer,3906965483(243197/90/9)) lseek err Invalid argument
file_pread(6,1,buffer,3906963521(243197/58/63)) lseek err Invalid argument
file_pread(6,1,buffer,3906963571(243197/59/50)) lseek err Invalid argument
file_pread(6,1,buffer,3906965484(243197/90/10)) lseek err Invalid argument
file_pread(6,1,buffer,3906963501(243197/58/43)) lseek err Invalid argument
file_pread(6,8,buffer,3906963515(243197/58/57)) lseek err Invalid argument
file_pread(6,11,buffer,3906963562(243197/59/41)) lseek err Invalid argument
file_pread(6,1,buffer,3906965485(243197/90/11)) lseek err Invalid argument
file_pread(6,1,buffer,3906963573(243197/59/52)) lseek err Invalid argument
file_pread(6,1,buffer,3906965486(243197/90/12)) lseek err Invalid argument
file_pread(6,1,buffer,3906963524(243197/59/3)) lseek err Invalid argument
file_pread(6,1,buffer,3906963574(243197/59/53)) lseek err Invalid argument
file_pread(6,1,buffer,3906965487(243197/90/13)) lseek err Invalid argument
file_pread(6,8,buffer,3906963518(243197/58/60)) lseek err Invalid argument
file_pread(6,11,buffer,3906963565(243197/59/44)) lseek err Invalid argument
file_pread(6,1,buffer,3906965488(243197/90/14)) lseek err Invalid argument
file_pread(6,1,buffer,3906963505(243197/58/47)) lseek err Invalid argument
file_pread(6,1,buffer,3906963576(243197/59/55)) lseek err Invalid argument
file_pread(6,1,buffer,3906965489(243197/90/15)) lseek err Invalid argument
file_pread(6,1,buffer,3906963506(243197/58/48)) lseek err Invalid argument
file_pread(6,1,buffer,3906963527(243197/59/6)) lseek err Invalid argument
file_pread(6,1,buffer,3906963577(243197/59/56)) lseek err Invalid argument
file_pread(6,1,buffer,3906965490(243197/90/16)) lseek err Invalid argument
file_pread(6,14,buffer,3906963444(243197/57/49)) ReadFile The drive cannot find the sector requested.
file_pread(6,3,buffer,3906963458(243197/57/63)) lseek err Invalid argument
file_pread(6,3,buffer,3906963505(243197/58/47)) lseek err Invalid argument
file_pread(6,8,buffer,3906963521(243197/58/63)) lseek err Invalid argument
file_pread(6,11,buffer,3906963568(243197/59/47)) lseek err Invalid argument
file_pread(6,2,buffer,3906965490(243197/90/16)) lseek err Invalid argument
file_pread(6,14,buffer,3906963445(243197/57/50)) ReadFile The drive cannot find the sector requested.
file_pread(6,2,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,3,buffer,3906963459(243197/58/1)) lseek err Invalid argument
file_pread(6,3,buffer,3906963506(243197/58/48)) lseek err Invalid argument
file_pread(6,8,buffer,3906963522(243197/59/1)) lseek err Invalid argument
file_pread(6,11,buffer,3906963569(243197/59/48)) lseek err Invalid argument
file_pread(6,2,buffer,3906965491(243197/90/17)) lseek err Invalid argument
file_pread(6,14,buffer,3906963446(243197/57/51)) ReadFile The drive cannot find the sector requested.
file_pread(6,3,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,3,buffer,3906963460(243197/58/2)) lseek err Invalid argument
file_pread(6,3,buffer,3906963507(243197/58/49)) lseek err Invalid argument
file_pread(6,8,buffer,3906963523(243197/59/2)) lseek err Invalid argument
file_pread(6,11,buffer,3906963570(243197/59/49)) lseek err Invalid argument
file_pread(6,2,buffer,3906965492(243197/90/18)) lseek err Invalid argument
file_pread(6,14,buffer,3906963447(243197/57/52)) ReadFile The drive cannot find the sector requested.
file_pread(6,4,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,3,buffer,3906963461(243197/58/3)) lseek err Invalid argument
file_pread(6,3,buffer,3906963508(243197/58/50)) lseek err Invalid argument
file_pread(6,8,buffer,3906963524(243197/59/3)) lseek err Invalid argument
file_pread(6,11,buffer,3906963571(243197/59/50)) lseek err Invalid argument
file_pread(6,2,buffer,3906965493(243197/90/19)) lseek err Invalid argument
file_pread(6,14,buffer,3906963448(243197/57/53)) ReadFile The drive cannot find the sector requested.
file_pread(6,3,buffer,3906963462(243197/58/4)) lseek err Invalid argument
file_pread(6,3,buffer,3906963509(243197/58/51)) lseek err Invalid argument
file_pread(6,8,buffer,3906963525(243197/59/4)) lseek err Invalid argument
file_pread(6,11,buffer,3906963572(243197/59/51)) lseek err Invalid argument
file_pread(6,2,buffer,3906965494(243197/90/20)) lseek err Invalid argument
file_pread(6,1,buffer,3906963583(243197/59/62)) lseek err Invalid argument
file_pread(6,1,buffer,3906965496(243197/90/22)) lseek err Invalid argument
file_pread(6,14,buffer,3906963450(243197/57/55)) ReadFile The drive cannot find the sector requested.
file_pread(6,7,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,3,buffer,3906963464(243197/58/6)) lseek err Invalid argument
file_pread(6,3,buffer,3906963511(243197/58/53)) lseek err Invalid argument
file_pread(6,8,buffer,3906963527(243197/59/6)) lseek err Invalid argument
file_pread(6,11,buffer,3906963574(243197/59/53)) lseek err Invalid argument
file_pread(6,1,buffer,3906965497(243197/90/23)) lseek err Invalid argument
file_pread(6,1,buffer,3906963535(243197/59/14)) lseek err Invalid argument
file_pread(6,1,buffer,3906963585(243197/60/1)) lseek err Invalid argument
file_pread(6,1,buffer,3906965498(243197/90/24)) lseek err Invalid argument
file_pread(6,14,buffer,3906963452(243197/57/57)) ReadFile The drive cannot find the sector requested.
file_pread(6,3,buffer,3906963466(243197/58/8)) lseek err Invalid argument
file_pread(6,3,buffer,3906963513(243197/58/55)) lseek err Invalid argument
file_pread(6,8,buffer,3906963529(243197/59/8)) lseek err Invalid argument
file_pread(6,11,buffer,3906963576(243197/59/55)) lseek err Invalid argument
file_pread(6,1,buffer,3906965499(243197/90/25)) lseek err Invalid argument
file_pread(6,10,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,1,buffer,3906963587(243197/60/3)) lseek err Invalid argument
file_pread(6,1,buffer,3906965500(243197/90/26)) lseek err Invalid argument
file_pread(6,14,buffer,3906963454(243197/57/59)) ReadFile The drive cannot find the sector requested.
file_pread(6,3,buffer,3906963468(243197/58/10)) lseek err Invalid argument
file_pread(6,3,buffer,3906963515(243197/58/57)) lseek err Invalid argument
file_pread(6,8,buffer,3906963531(243197/59/10)) lseek err Invalid argument
file_pread(6,11,buffer,3906963578(243197/59/57)) lseek err Invalid argument
file_pread(6,1,buffer,3906965501(243197/90/27)) lseek err Invalid argument
file_pread(6,12,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,1,buffer,3906963518(243197/58/60)) lseek err Invalid argument
file_pread(6,1,buffer,3906963539(243197/59/18)) lseek err Invalid argument
file_pread(6,1,buffer,3906963589(243197/60/5)) lseek err Invalid argument
file_pread(6,1,buffer,3906965502(243197/90/28)) lseek err Invalid argument
file_pread(6,1,buffer,3906963590(243197/60/6)) lseek err Invalid argument
file_pread(6,1,buffer,3906965503(243197/90/29)) lseek err Invalid argument
file_pread(6,2,buffer,3906963469(243197/58/11)) lseek err Invalid argument
file_pread(6,8,buffer,3906963534(243197/59/13)) lseek err Invalid argument
file_pread(6,11,buffer,3906963581(243197/59/60)) lseek err Invalid argument
file_pread(6,1,buffer,3906965504(243197/90/30)) lseek err Invalid argument
file_pread(6,14,buffer,3906963458(243197/57/63)) lseek err Invalid argument
file_pread(6,1,buffer,3906963592(243197/60/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906965505(243197/90/31)) lseek err Invalid argument
P Linux filesys. data 1120788646 1200466085 79677440
P Linux filesys. data 1200483280 1280160719 79677440
P Linux filesys. data 1347756920 1380576119 32819200
P Linux filesys. data 1381456984 1414276183 32819200
P Linux filesys. data 1416765326 1496442765 79677440
P Linux filesys. data 1562491864 1595311063 32819200
P Linux filesys. data 1596191920 1629011119 32819200
P Linux filesys. data 1631499758 1711177197 79677440
P Linux Swap 1715790584 1715790599 16
P Linux filesys. data 1776693496 1800032503 23339008
P Linux filesys. data 1805802278 1885479717 79677440
P MS Data 1914044743 1915012181 967439 [NO NAME]
dir_partition inode=0
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571402.
1 P Linux filesys. data 1120788646 1200466085 79677440
2 P Linux filesys. data 1200483280 1280160719 79677440
3 P Linux filesys. data 1347756920 1380576119 32819200
4 P Linux filesys. data 1381456984 1414276183 32819200
5 P Linux filesys. data 1416765326 1496442765 79677440
6 P Linux filesys. data 1562491864 1595311063 32819200
7 P Linux filesys. data 1596191920 1629011119 32819200
8 P Linux filesys. data 1631499758 1711177197 79677440
9 P Linux Swap 1715790584 1715790599 16
10 P Linux filesys. data 1776693496 1800032503 23339008
11 P Linux filesys. data 1805802278 1885479717 79677440
12 P MS Data 1914044743 1915012181 967439 [NO NAME]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
I confirm that photorec was able to recover some data files ( different types ) but my target is recover the boot sector it will save me going into thousands of files to reorganize it if I'm able to .
the scan log :"
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
block_group_nr 125
FAT1 : 1-119
FAT2 : 120-238
start_rootdir : 239
Data : 271-967438
sectors : 967439
cluster_size : 32
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Thanks for quoting the primary information source regarding the behaviour of the "clean" command showing that I was wrong regarding the scope of the command!mjoseph wrote: 20 Sep 2020, 03:18 Thank you for the reply Recuperation
Did you run deep search as well?
Do you know the file system used on your cleaned drive - maybe you formated it yourself?
You might have possibly applied the Microsoft "clean" command to a partition in extX-format.
I had an experience with a single NTFS partition that I accidentally formated. Testdisk showed me a lot of partitions which must have been my VMWare virtual machines that were stored on that partition. I did not recover anything using Testdisk because the MFT was overwritten. Instead only Photorec worked.
The fact that your partition contains virtual machines which have their own partition storage makes it a little bit complicated.
I have never formatted the drive it has its original WD My Passport formatting .
The quick scan took 6 days so I refrained from doing the deep scan .
through other data recovery softwares ( can't remember which one ), I have seen ( preview) my data starting the first level of subdirectories ( with the correct names) which made me believe that if I'm able to rebuild/restore the MFT using testdisk ( may be manually ) I will restore my drive as it was .
I care more about my other data files 1000 times more than the VM . If there is a way to keep the other data files rather than the VM , I have no problem to take it .
BitterColdSoul
@recuperation
@mjoseph
But if those other DR softwares could successfully analyse the former filesystem, why didn't you simply extract the files / folders you need to another HDD ?
Please do some quick fact checking before writing BS. If you type “help clean”, you'll see that only “clean all” performs a complete wipe of the partition's data ; “clean” alone merely deletes partitions.If you used the diskpart clean command the whole content of your disk should have been deleted and there is nothing to recover anymore.
Normally after a simple reformat only the first 256KB of the MFT are overwritten (as of Windows 7), which, after deduction of the system files occupying the first records, corresponds to 229 user files -- which is significant, depending on which files are concerned, but very little on a typical partition containing thousands of files.I did not recover anything using Testdisk because the MFT was overwritten.
@mjoseph
This is staggeringly high for a 2TB HDD. Normally to read the whole thing, even at USB 2.0 rate, should take at most about 18 hours. (If it's indeed in a USB 2.0 enclosure, the problem is that you probably can't connect the drive directly in SATA to get a much higher read/write rate, as WD My Passport are generally encrypted at the controller level. There are means to bypass that encryption, though, in case the enclosure is dysfunctional, but then it gets really complicated. If by “I took a copy of the raw drive” you mean that you made a complete clone or image file, through the enclosure, then this won't be needed anyway.)The quick scan took 6 days so I refrained from doing the deep scan .
AFAIK, TestDisk doesn't rebuild / restore the MFT, it can only restore the first 4 MFT records from the $MFTMirr, the so-called MFT mirror, which is a backup of only those first 4 records which point to filesystem structures which are essential for the system to access the partition. I've had a situation where MFT records 2 to 4 were corrupted in both the $MFT and $MFTMirr, and so TestDisk couldn't fix anything. I had to painstakingly rebuild those three records by learning about their structure and modifying the corresponding MFT records of working partitions according to the specific parameters of this one. (More details here and here.) Generally speaking, in such a situation attempting an “in-place” fix is risky, and the odds of success are rather low (before attempting what I described above I first extracted the complete contents to another HDD).which made me believe that if I'm able to rebuild/restore the MFT using testdisk ( may be manually ) I will restore my drive as it was .
That's the first thing to assess with certainty before attempting anything at all.I don't think that the drive has a physical issue
Photorec by design doesn't care at all about the original filesystem / folders tree, it's a program dedicated to file carving based on signature search.Photorec and other data recovery software can see my data files but not the root directory and not the original folders tree .
@ BitterColdSoul
I was able to use a software to copy the raw drive with the messed MFT to another disk so I believe the enclosure is ok ( I never opened it , the drive was rarely used but had a lot of documents that I care about , it was my main backup )
For the physical issues . I'm 99.9 % certain that the drive has no physical issues and the left 0.1 % is because I'm not an expert .
Thank you enormously for the resources . I can't thank you enough . I'll let you know where these leads me .
The other DR softwares gave me some of the folders and files naming and some files loses their names what will take me years to identify and rename it .
BitterColdSoul
The very purpose of a backup is to have a second copy of files that are already stored elsewhere.the drive was rarely used but had a lot of documents that I care about , it was my main backup
Well, at least I did sumptin' useful that day ! (Let's say that this year has been generally very unproductive.)Thank you enormously for the resources . I can't thank you enough . I'll let you know where these leads me .
The most recommanded ones at forum.hddguru.com are R-Studio, DMDE and UFS Explorer. You could try one of these. (I know the first one well, the second one a bit, the third one not at all. The first one is reputed as being excellent at piecing together remnants of a damaged filesystem.)The other DR softwares gave me some of the folders and files naming and some files loses their names what will take me years to identify and rename it .
But if a file's or folder's metadata is totally gone, then no software can retrieve its original path, name and attributes, all that's left is “raw” recovery through file signature search, which is a bit like a blind man trying to identify mushrooms and seaslugs by their shapes and textures, or even a not blind man trying to distinguish between pairs of women's legs and pairs of sausages.
