Hello everyone, I'd like to ask for help/guidance as I need to recover my data from the external WD 1TB HDD. The issue occurred after I unplugged the USB cable from the PC while uploading some files to the HDD. Below are some screenshots of my initial trouble-shooting. After running TestDisk quick search it seems that it cannot find any partition. I'd like to know if there is any chance of repairing the disk and getting access to the data or whether reformatting is the only option.
This is what happens everyime I plug the WD drive:
https://paste.pics/b4a736266d1537edcb5e8bb61e4a69bd
When I try to open the E: drive:
The HDD is recognized in the device manager:
And the disk is format is RAW according to the disk management:
After I run TestDisk and select the E: drive
https://paste.pics/1eb5ed707cc71366391c5782238a13bb
After the TestDrive Quick Search finished:
https://paste.pics/35e8ee6d069ceb1ae85f4773a5d50cfe
Logfile is full of "ReadFile The request failed due to a fatal device hardware error." I wanted to attach the log file here but cannot due to the .log being invalid file extension.
Need help recovering files from 1TB WD HDD - partition not found
Re: Need help recovering files from 1TB WD HDD - partition not found
I can't see your pictures. Please upload them using the attachment tab below on the bottom of the page.
Hello, I was able to upload only 3 attachments. I fixed the URL links for rest of the screenshots in the original post.recuperation wrote: 28 Sep 2020, 20:53 I can't see your pictures. Please upload them using the attachment tab below on the bottom of the page.
Try renaming the log-extension into txt.
Please attach a logfile from smartmontools or simply post it here.
Use the command
smartctl -a /dev/sdX > C:\mylog.txt
to redirect the output of smartmontools into the file mylog.txt on your C-drive.
Replace X by the disc drive letter in question.
Use administrator rights for this operation.
Use the command
Logs below:recuperation wrote: 28 Sep 2020, 21:56 Try renaming the log-extension into txt.
Use the command
smartctl 7.1 2019-12-30 r5022 [x86_64-w64-mingw32-w10-1909] (sf-7.1-1)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
/dev/sde: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
still unable to attach the logs from the testdisk. File is now .txt however i receive the "Invalid file extension: testdisk.txt" while trying to upload it here. I just noticed it has 900+ Mb which might be the reason why. Adding the first few lines below. After while it keeps repeating the same error over and over again.
Fri Sep 25 18:03:32 2020
TestDisk 7.2-WIP, Data Recovery Utility, September 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=112652785664
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000168488960
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000168488960
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - TOSHIBA THNSNK128GVN8 M.2 2280 128GB, S/N:77DB611LKLMU, FW:K8DC4101
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MQ01ABD100, S/N:87B3S5XTS, FW:AX0P3D
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512 - WD My Passport 0748, S/N:WXB1E62NRN12, FW:1015
Disk /dev/sdc - 1000 GB / 931 GiB - WD My Passport 0748
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121597 255 63
Partition: Read error
file_pread(6,16,buffer,32(0/0/33)) ReadFile The request failed due to a fatal device hardware error.
file_pread(6,3,buffer,48(0/0/49)) ReadFile The request failed due to a fatal device hardware error.
file_pread(6,3,buffer,95(0/1/33)) ReadFile The request failed due to a fatal device hardware error.
file_pread(6,8,buffer,111(0/1/49)) ReadFile The request failed due to a fatal device hardware error.
file_pread(6,11,buffer,158(0/2/33)) ReadFile The request failed due to a fatal device hardware error.
file_pread(6,2,buffer,2080(0/33/2)) ReadFile The request failed due to a fatal device hardware error.
file_pread(6,2,buffer,51(0/0/52)) ReadFile The request failed due to a fatal device hardware error.
file_pread(6,2,buffer,98(0/1/36)) ReadFile The request failed due to a fatal device hardware error.
I realized I did a mistake when running the smartmontools, I specified the disk incorrectly. I tried to run it again but now, for some reason the external HDD started to behave wierdly. When I plug it in, it takes quite some time for it to appear in "This PC", also when I try to right click the drive or run diskmgmt.msc it takes forever to load. When I unplug the HDD suddenly everything loads.
Please try out the additional -d parameter
smartctl -a -d,sat /dev/sdX > C:\mylog.txt
or the other -d parameter variants mentioned here:
https://www.smartmontools.org/wiki/USB
I suspect a hardware error that would require you contacting a professional recovery company.
But I would like to see the SMART parameters if they can be pulled out of the disc.
Log below:
Model Family: Western Digital Elements / My Passport (USB, AF)
Device Model: WDC WD10TMVW-11ZSMS5
Serial Number: WD-WXB1E62NRN12
LU WWN Device Id: 5 0014ee 2074c7c28
Firmware Version: 01.01A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 5200 rpm
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Tue Sep 29 12:36:52 2020 CEDT
SMART support is: Enabled
SMART Status not supported: Incomplete response, ATA output registers missing
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
been run.
data collection: (25500) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 247) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 199 199 051 Pre-fail Always - 2492
3 Spin_Up_Time 0x0027 154 137 021 Pre-fail Always - 5266
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 989
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 172 172 000 Old_age Always - 1943
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1313
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 661
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 235
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4450
194 Temperature_Celsius 0x0022 122 099 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 4
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 256 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 256 occurred at disk power-on lifetime: 1313 hours (54 days + 17 hours)
ER ST SC SN CL CH DH
04 51 02 00 00 00 00
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
e1 00 02 00 00 00 00 00 00:07:29.549 IDLE IMMEDIATE
ec 00 01 00 00 00 00 00 00:07:29.542 IDENTIFY DEVICE
e1 00 0f 00 00 00 00 00 00:07:27.542 IDLE IMMEDIATE
e1 00 02 00 00 00 00 00 00:07:26.898 IDLE IMMEDIATE
ec 00 01 00 00 00 00 00 00:07:26.891 IDENTIFY DEVICE
Error 255 occurred at disk power-on lifetime: 1313 hours (54 days + 17 hours)
04 51 0f 00 00 00 00
Error 254 occurred at disk power-on lifetime: 1313 hours (54 days + 17 hours)
Error 253 occurred at disk power-on lifetime: 1313 hours (54 days + 17 hours)
e1 00 02 00 00 00 00 00 00:06:19.018 IDLE IMMEDIATE
ec 00 01 00 00 00 00 00 00:06:19.011 IDENTIFY DEVICE
e1 00 0f 00 00 00 00 00 00:06:16.980 IDLE IMMEDIATE
e1 00 02 00 00 00 00 00 00:06:16.311 IDLE IMMEDIATE
ec 00 01 00 00 00 00 00 00:06:16.304 IDENTIFY DEVICE
Error 252 occurred at disk power-on lifetime: 1313 hours (54 days + 17 hours)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Interrupted (host reset) 10% 1300 -
# 2 Short offline Interrupted (host reset) 10% 1300 -
# 3 Conveyance offline Completed: read failure 90% 1256 6266664
# 4 Conveyance offline Completed without error 00% 609 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
was never started.
been run.
command.
power-saving mode.
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
I just see 4 pending sectors and a statement I do not understand:
Please try to duplicate the drive as described in the testdisk manual
and see how ddrescue reacts.
The smart log does not look threatening to me.# 3 Conveyance offline Completed: read failure 90% 1256 6266664
So I got Ubuntu live on USB and attempted to create an image from the faulty external HDD. I am creating the .img file on my second internal storage which is freshly formatted 1TB Toshiba HDD.
I kept the ddrescue running for a while and the remaining time grew up to 700+ days. Now is around 1000 days
I don't feel like keeping this running. Is there any way i can make this run faster? use some specific parameters e.g. -n - no-trimming?
ubuntu@ubuntu:/media/WDImage$ sudo ddrescue /dev/sdd wd.img wd.log
GNU ddrescue 1.23
Press Ctrl-C to interrupt
ipos: 750452 kB, non-trimmed: 233472 B, current rate: 0 B/s
opos: 750452 kB, non-scraped: 0 B, average rate: 757 kB/s
non-tried: 999570 MB, bad-sector: 0 B, error rate: 0 B/s
rescued: 599814 kB, bad areas: 0, run time: 13m 11s
pct rescued: 0.05%, read errors: 4, remaining time: 713d 22h
time since last successful read: 0s
**EDIT**
I wasn't sure whether I should create an image from the faulty drive or perform full disk to disk copy. Please let me know what is the case here.
GNU ddrescue 1.23
**EDIT**
