get current status e.g. Copying, please wait... 1234 ok, 0 failed
rosch
#1 Post by rosch »
Hi all,
I was wondering if there is a way to get the current status of the file recovery.
I'm using Advanced / Filesystem Utils to list and copy files from the dying HD.
Is the log file testdisk.log an option to compute the status?
By current status I mean the text
The idea is to read this status regularly using some terminal command, and set up a cron job to get updates on the recovery on a regular basis..
Many thanks in advance.
Re: get current status e.g. Copying, please wait... 1234 ok, 0 failed
I don't know.
Please run Testdisk and select any healthy volume and try copying a directory tree from there to another location.
Check the log file for any lines relating to the copy process.
Please report your findings here.
Thanks.
rosch
#3 Post by rosch »
It looks like this is not trivial / not doable using testdisk or its log file.
You can use the usual file commands like the following to give you the number of files:
find /path/to/recovery -type f | wc -l
find: lists the files, -type f is to limit the search to only files (no folders), one file name per line
| wc -l: the output of the find command is fed to wc -l which prints the newline counts
Thank you. As I am a casual linux command line user I will have to read documentation to understand what it does. :)
rosch
#5 Post by rosch »
recuperation wrote: 06 Oct 2020, 21:53 Thank you. As I am a casual linux command line user I will have to read documentation to understand what it does. :)
Edited my post, added some explaining about the used commands.
