I've a pretty weird problem. due to some technical issues 2 drives of my RAID 10 array got non members.
I had 3 partions on it: first (1024gb) and third (327gb) were crypted with Veracrypt. second (512gb) was uncrypted.
I managed to get access to the files on the second partion. which means the RAID is correct connected and set up in BIOS again.
Testdisk scan finds this:
MS Data 1073774593 2147518464 1073743872
NTFS found using backup sector, blocksize=4096, 549 GB / 512 GiB
Linux filesys. data 1794346017 1799027149 4681133 [Ž;ŒF êì¦È€fQ 0þ]
cramfs, 2396 MB / 2285 MiB
MS Data 2147518464 3221262335 1073743872 [Games]
NTFS, blocksize=4096, 549 GB / 512 GiB
the weird thing is that the "advanced" tab shows this info instantly:
1 P MS Reserved 34 32767 32734 [Microsoft reserved partition]
2 P MS Data 32768 2147518463 2147485696 [Basic data partition]
3 P MS Data 2147518464 3221262335 1073743872 [Basic data partition] [Games]
4 P MS Data 3221262336 3907037183 685774848 [Basic data partition]
that's 100% correct. any chance to just write these infos without the scan?
deep scan is running now but it takes ages. maybe there is a faster solution, because I got all the correct data, or?
thnx in advance
best regards
t0m
PS: Windows 10, Testdisk v7.1, Intel RST RAID, Veracrypt 1.24u7
Testdisk doesn't find correct table, but advanced option shows it instantly!?!
Re: Testdisk doesn't find correct table, but advanced option shows it instantly!?!
I don't understand where the problem is.
Could you post a full log file?
