Seems GPT is now confused and corrupt - how do I recover my data?
briandu2
#1 Post by briandu2 »
I am using a 2014 Mac Mini with Ubuntu 20.04 (default install) on a USB connection (1 TB SSD)
This has been working fine for approx a week. Just when I am ready to consider a backup of the drive it somehow will not boot up.
Actually previously the Mac would boot into a small OSX drive - pressing the Mac alt button (on start up) allows one to boot into other drives. This has been working fine and then became erratic.
I booted from a USB boot stick and used gparted which reflects /dev/sdb1 and /dev/sdb3 as filesystem unknown.
Using a small spare drive I installed Ubuntu again and it erratically worked until I re-installed it again with the following partitions using gdisk
/dev/sb1 as EFI +512M
/dev/sdb2 as fs_boot +512M
/dev/sdb3 as fs_root (the rest of the drive)
new install Ubuntu with other (manual partitions) and formatting sdb1 as EFI, sdb2 as /boot and sdb3 as /root.
Once installed and rebooted then went
 cd /boot/efi/EFI/ubuntu
and executed
 mv shimx64.efi shimx64.efi_old
and
 cp grubx64.efi shimx64.efi
This seems quite robust and consistently boots up directly or using the Mac alt key choices. Point is it works properly and no problems.
HOWEVER, I have the problem with my 1TB drive:
Booting up from the small drive gparted still states the partitions are unknown.
Using gdisk
 sudo gdisk -l /dev/sdb
GPT fdisk (gdisk) version 1.0.5
Partition table scan:
MBR: hybrid
BSD: not present
APM: not present
GPT: present
Found valid GPT with hybrid MBR; using GPT.
Disk /dev/sdb: 2000409264 sectors, 953.9 GiB
Model: Name
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): A0D13BCD-15E6-4EA3-A70F-554583C1CC7D
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 2000409230
Partitions will be aligned on 2048-sector boundaries
Total free space is 2669 sectors (1.3 MiB)
Number Start (sector) End (sector) Size Code Name
1 2048 1050623 512.0 MiB EF00 EFI System Partition
2 1050624 2000408575 953.4 GiB
it seems fine but if I use
 sudo gdisk /dev/sdb1
[sudo] password for xxxxx:
MBR: hybrid
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory. THIS OPERATION IS POTENTIALLY DESTRUCTIVE! Exit by
typing 'q' if you don't want to convert your MBR partitions
to GPT format!
Warning! Secondary partition table overlaps the last partition by
1999360033 blocks!
You will need to delete this partition or resize it in another utility.
and
 Command (? for help): p
Disk /dev/sdb1: 1048576 sectors, 512.0 MiB
Disk identifier (GUID): CD527C6A-F72B-48BE-88F0-A7C45C98A77A
First usable sector is 34, last usable sector is 1048542
Total free space is 1048509 sectors (512.0 MiB)
2 1050624 2000408575 953.4 GiB 8300 Linux filesystem
as can be seen it reports number 2 and not 1!
using option p results in -
still number 2 followed by v
Command (? for help): v
Problem: partition 2 is too big for the disk.
1999360033 blocks!
Identified 2 problems!
it is a mess and if I follow through with /dev/sdb2 then
 sudo gdisk /dev/sdb2
MBR: hybrid
BSD: not present
APM: not present
GPT: not present
to GPT format!
1050657 blocks!
and selecting p results in:
 Disk /dev/sdb2: 1999357952 sectors, 953.4 GiB
Disk identifier (GUID): F35C490F-3BAC-40B6-A2F1-C42BB23B0EF5
First usable sector is 34, last usable sector is 1999357918
Total free space is 1050590 sectors (513.0 MiB)
and selecting v results in -
1050657 blocks!
As such I cannot afford to lose the sdb2 partition; although it is 900GB it is only using approx 200GB and I planned to shrisk the partition and the dd it over to a spare drive. It is the only copy now and I cannot recreate it.
My question is what are my options?
Since I think the Mac Mini 2014 is EUFI and the Ubuntu disk was USB based then probably the Ubuntu 1TB disk was BIOS and not GPT?
As can be seen the filesystems are there but the overlap is causing the GParted status to read unknowns.
How do I get the second partition to be recognised at an ext4?
Reading through the testdisk pdf I am stumped as to what approach to take. - I have tried quite a numbe rof options and have had to dd the 1TB disk several time now and is quite frustrating.
Any guidance?
Re: Seems GPT is now confused and corrupt - how do I recover my data?
briandu2 wrote: 15 Oct 2020, 23:18 As such I cannot afford to lose the sdb2 partition; although it is 900GB it is only using approx 200GB and I planned to shrisk the partition and the dd it over to a spare drive. It is the only copy now and I cannot recreate it.
Any guidance?
Do not boot from your defective drive.
Run Testdisk from CD or USB stick and let Testdisk analyse the disk. Use the "p" key to list files within a partition after selecting it.
If Testdisk shows you the content you expected copy that content to another healthy drive.
If the result does not meet your expectations continue with Deep search and retry to list the content.
If that fails try Photorec or commercial software.
When running Testdisk enable logging and post the log file here.
briandu2
#3 Post by briandu2 »
After 3 days of nonstop trying to figure out what has gone wrong and having to learn some new tools I screwed up the above posting (exhausted). Please ignore! :o :oops:
The problem is a 1TB Macos drive, it has two partitions and was created leveraging the bios internet facility on a Mac Mini.
I installed an external 256GB drive with Ubuntu and copied the data from the Macos to Ubuntu.. IT booted up fine several times and when I was near ready the drives "failed" Both the external 256GB and the 1TB.
Using GParted the Macos shows unknown which does not help.
I have employed varous strategies to recover the partitions but to no avail - I mirrored the 1TB and attempted many paths (to keep the original safe! :roll:
Nevertheless the testdisk file is below. I do note the testdisk states that HFS is not supported? Is this correct?
https://pastebin.com/Rmj9gwRm
BTW I did a deep analysis and the result was a 29MB log file which pastebin will not accept
briandu2 wrote: 18 Oct 2020, 21:34 Nevertheless the testdisk file is below. I do note the testdisk states that HFS is not supported? Is this correct?
Yes.
If you don't believe it, read here:
Furthermore your own report told you so.
Have you found a secret HFS support switch?
Please let me know! ;)
briandu2
#5 Post by briandu2 »
So it seems that I cannot get my data back!!! Grrr!!
#6 Post by recuperation »
Search for commercial recovery software that supports HFS, pay a professional lab.
