Lexar 633x 512GB microSD Boot sector&Backup boot sector Bad
lu96a06
#1 Post by lu96a06 »
I come from taiwan
I'm very sorry I use a translator for English
The newly purchased card fails after being inserted into the phone
It is displayed as RAW on the system,
Can't format
I tried using the following steps
Run TestDisk, Advanced, Boot, RebuildBS
Screen after operation
[Rebuild BS] What steps should be performed after execution :?:
Re: Lexar 633x 512GB microSD Boot sector&Backup boot sector Bad
Use the "p"-key (list files) to check each partition found for valid content.
In case of failure run deep search.
You can use the copy functions of Testdisk to duplicate content to another healthy drive.
Anyway you should claim your guarantee with your newly purchased Lexar card.
Maybe it's a fake.
lu96a06
#3 Post by lu96a06 »
Sat Oct 17 09:33:10 2020
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=10000831348736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=496928555008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=10000831348736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=496928555008
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1023532859392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000381018112
filewin32_getfilesize(\\.\E:) GetFileSize err 函数不正确。
filewin32_setfilepointer(\\.\E:) SetFilePointer err 函数不正确。
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=450094956544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=480085278720
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=496895000576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=10000812474368
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - TOSHIBA DT01ACA200, S/N:38K0JMUAS, FW:MX4OABB0
Disk /dev/sdb - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - HGST HUH721010ALE600, S/N:1SGBJG9Z, FW:LHGAT2F6
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - CT500MX500SSD1, S/N:1815E135DDE6, FW:M3CR023
Disk /dev/sdd - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - KLEVV NEO N400 SSD 480GB, S/N:N400C1J24A034E, FW:SBFM61.3
Disk /dev/sde - 1024 GB / 953 GiB - CHS 124519 255 63, sector size=512 - ADATA SX8200PNP, S/N:2J4920147192 _00000001., FW:42AZS6AC
Disk /dev/sdf - 496 GB / 462 GiB - CHS 60414 255 63, sector size=512 - Mass Storage Device, S/N:121220130416, FW:1.00
Disk /dev/sdf - 496 GB / 462 GiB - Mass Storage Device
1 P HPFS - NTFS 4 20 17 60414 201 11 970498048
ntfs_boot_sector
filesystem size 1
sectors_per_cluster 0
mft_lcn 0
mftmirr_lcn 0
clusters_per_mft_record 0
clusters_per_index_record 0
Status: Bad
Status: Bad
Sectors are identical.
rebuild_NTFS_BS
Search mft stopped: 65536/970498048
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
file_pread(9,1,buffer,970563584(60414/201/12)) ReadFile 数据错误(循环冗余检查)。
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
Search mft stopped: 262144/970498048
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
Boot sector Backup boot sector
0000 00000000 00000000 ........ 00000000 00000000 ........
0008 00000000 00000000 ........ 00000000 00000000 ........
0010 00000000 00000000 ........ 00000000 00000000 ........
0018 00000000 00000000 ........ 00000000 00000000 ........
0020 00000000 00000000 ........ 00000000 00000000 ........
0028 00000000 00000000 ........ 00000000 00000000 ........
0030 00000000 00000000 ........ 00000000 00000000 ........
0038 00000000 00000000 ........ 00000000 00000000 ........
0040 00000000 00000000 ........ 00000000 00000000 ........
0048 00000000 00000000 ........ 00000000 00000000 ........
0050 00000000 00000000 ........ 00000000 00000000 ........
0058 00000000 00000000 ........ 00000000 00000000 ........
0060 00000000 00000000 ........ 00000000 00000000 ........
0068 00000000 00000000 ........ 00000000 00000000 ........
0070 00000000 00000000 ........ 00000000 00000000 ........
0078 00000000 00000000 ........ 00000000 00000000 ........
0080 00000000 00000000 ........ 00000000 00000000 ........
0088 00000000 00000000 ........ 00000000 00000000 ........
0090 00000000 00000000 ........ 00000000 00000000 ........
0098 00000000 00000000 ........ 00000000 00000000 ........
00A0 00000000 00000000 ........ 00000000 00000000 ........
00A8 00000000 00000000 ........ 00000000 00000000 ........
00B0 00000000 00000000 ........ 00000000 00000000 ........
00B8 00000000 00000000 ........ 00000000 00000000 ........
00C0 00000000 00000000 ........ 00000000 00000000 ........
00C8 00000000 00000000 ........ 00000000 00000000 ........
00D0 00000000 00000000 ........ 00000000 00000000 ........
00D8 00000000 00000000 ........ 00000000 00000000 ........
00E0 00000000 00000000 ........ 00000000 00000000 ........
00E8 00000000 00000000 ........ 00000000 00000000 ........
00F0 00000000 00000000 ........ 00000000 00000000 ........
00F8 00000000 00000000 ........ 00000000 00000000 ........
0100 00000000 00000000 ........ 00000000 00000000 ........
0108 00000000 00000000 ........ 00000000 00000000 ........
0110 00000000 00000000 ........ 00000000 00000000 ........
0118 00000000 00000000 ........ 00000000 00000000 ........
0120 00000000 00000000 ........ 00000000 00000000 ........
0128 00000000 00000000 ........ 00000000 00000000 ........
0130 00000000 00000000 ........ 00000000 00000000 ........
0138 00000000 00000000 ........ 00000000 00000000 ........
0140 00000000 00000000 ........ 00000000 00000000 ........
0148 00000000 00000000 ........ 00000000 00000000 ........
0150 00000000 00000000 ........ 00000000 00000000 ........
0158 00000000 00000000 ........ 00000000 00000000 ........
0160 00000000 00000000 ........ 00000000 00000000 ........
0168 00000000 00000000 ........ 00000000 00000000 ........
0170 00000000 00000000 ........ 00000000 00000000 ........
0178 00000000 00000000 ........ 00000000 00000000 ........
0180 00000000 00000000 ........ 00000000 00000000 ........
0188 00000000 00000000 ........ 00000000 00000000 ........
0190 00000000 00000000 ........ 00000000 00000000 ........
0198 00000000 00000000 ........ 00000000 00000000 ........
01A0 00000000 00000000 ........ 00000000 00000000 ........
01A8 00000000 00000000 ........ 00000000 00000000 ........
01B0 00000000 00000000 ........ 00000000 00000000 ........
01B8 00000000 00000000 ........ 00000000 00000000 ........
01C0 00000000 00000000 ........ 00000000 00000000 ........
01C8 00000000 00000000 ........ 00000000 00000000 ........
01D0 00000000 00000000 ........ 00000000 00000000 ........
01D8 00000000 00000000 ........ 00000000 00000000 ........
01E0 00000000 00000000 ........ 00000000 00000000 ........
01E8 00000000 00000000 ........ 00000000 00000000 ........
01F0 00000000 00000000 ........ 00000000 00000000 ........
01F8 00000000 00000000 ........ 00000000 00000000 ........
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
ntfs_boot_sector
filesystem size 1
mft_lcn 0
mftmirr_lcn 0
Status: Bad
Status: Bad
Change partition type:
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/sdf - 496 GB / 462 GiB - CHS 60414 255 63
Invalid NTFS or exFAT boot
file_pread(9,2,buffer,970563583(60414/201/11)) ReadFile 数据错误(循环冗余检查)。
file_pread(9,1,buffer,970563585(60414/201/13)) lseek err Invalid argument
file_pread(9,14,buffer,970563586(60414/201/14)) lseek err Invalid argument
file_pread(9,3,buffer,970563600(60414/201/28)) lseek err Invalid argument
file_pread(9,3,buffer,970563647(60414/202/12)) lseek err Invalid argument
file_pread(9,8,buffer,970563663(60414/202/28)) lseek err Invalid argument
file_pread(9,11,buffer,970563710(60414/203/12)) lseek err Invalid argument
file_pread(9,2,buffer,970565632(60414/233/44)) lseek err Invalid argument
If you did not write onto this card there is no use in using Testdisk. Claim your guaranty.
