[BUG] testdisk keep running background in 100% cpu usage, causing overheating
allexj
#1 Post by allexj »
I didn't know why my pc was having this overheating problem, because checking with gnome-system-monitor there wasn't any process that was using CPU resources.
But then, I checked with "top" via terminal, and there was a testdisk process with 100% cpu usage that was causing an heavy overheating and fun loud. After I killed it, problem was fixed.
Version of testdisk: 7.1
Re: [BUG] testdisk keep running background in 100% cpu usage, causing overheating
Try out using version 7.2 WIP to see if your load indicator rises to 100% again.
Modern CPUs slow down cores to prevent overheating so it would be interesting to know what you consider as overheating. ;)
