TestDisk fulled my hdd - cannot boot Topic is solved
xbitz
#1 Post by xbitz »
I tried to recover some deleted files with TestDisk.
It started generating some .dd file on the /home/user/Desktop directory (i used it wrong).
Then it gave me a message that the disk is full.
I exited the application and deleted the .dd file.
However, i could not re-enter ubuntu, i just got a message at the boot process.
I enetered with a linux live usb disk and i opened the filesystem.
The size available were 0 bytes, that's why it could not boot previously.
However, no matter where i looked, i saw no files i could delete.
So where is all the space that TeskDisk has consumed? Where are all the files it has generated?
Re: TestDisk fulled my hdd - cannot boot
I don't know where Testdisk writes files under Linux.
I would look into the home directory of the user you used.
Otherwise I would use the commands du and tree to find the file.
xbitz
#3 Post by xbitz »
Is it only one file? Or did it create many files?
That depends on what you did using Testdisk. What do you mean by "wrong"? Did you intend to restore files with the extension "dd"?
xbitz
#5 Post by xbitz »
I am not exactly sure because i was in panic. But i think it was creating an image of my hdd,, but in the same partition, which is dumb.
It asked me for a folder to write to (ehich i have deleted), but while it was doing its work, i saw a .Dd file in the Desktop.
Then it told me that the disk is full.
I exited the applicationand i deleted the. Dd file.
Turned off, and when i turned on, it could not reboot.
Booted a live linux from usb, and i didnt see any files at the desktop. But still, i have zero bytes available. I dont understand what is going on?
Could it have made copies of each and every file in the system? If yes, where are they?
Are there any commands where i can find what's going on?
#6 Post by recuperation »
You either restored files from a partition or you generated a backup from a whole partition. The latter only produces one file.
You should remember what you did.
Your new questions suggest that you did not read my answers.
xbitz
#7 Post by xbitz »
I dont understand why you are being so aggressive.
I read your answers.
I dont understand what i was doing exactly because i was in panic.
It asked me for a file to write to, i but i have deleted both the. Dd file and the folder.
I saw your post about the du and tree commands, i just asked for more soecofocs on their usage, thats all.
#8 Post by recuperation »
I said:
recuperation wrote: 24 Oct 2020, 09:43 Otherwise I would use the commands du and tree to find the file.
You answered:
xbitz wrote: 24 Oct 2020, 10:50 Are there any commands where i can find what's going on?
Now you pretend
xbitz wrote: 24 Oct 2020, 11:20 I saw your post about the du and tree commands, i just asked for more soecofocs on their usage, thats all.
and you are saying that I am aggressive.
Thank you.
I am leaving now to an English class to work on my reading disabilities.
xbitz
#9 Post by xbitz »
I don't understand why you say i am pretending. I saw the commands, i just asked for more specific usage if that was possible.
Sorry if i gave out a feeling that i wasn't appreciating your help.
Anyway, i found the log file. I will dump its contents here:
Hope it will help make sense
Fri Oct 23 18:18:28 2020
OS: Linux, kernel 5.4.0-52-generic (#57-Ubuntu SMP Thu Oct 15 10:57:00 UTC 2020) x86_64
Compiler: GCC 9.2
ext2fs lib: 1.45.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.1
/dev/sda: LBA, LBA48 support
/dev/sda: size       1953525168 sectors
/dev/sda: user_max   1953525168 sectors
Warning: can't get size for Disk /dev/loop26 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10SPZX-75Z10T2, S/N:WXP1A39AER71, FW:03.01A03
Disk /dev/sdc - 7759 MB / 7400 MiB - CHS 1022 239 62, sector size=512 - TOSHIBA TransMemory, FW:1.00
Disk /dev/loop0 - 9588 KB / 9364 KiB - 18728 sectors (RO), sector size=512
Disk /dev/loop1 - 102 MB / 97 MiB - 200088 sectors (RO), sector size=512
Disk /dev/loop10 - 63 MB / 60 MiB - 124440 sectors (RO), sector size=512
Disk /dev/loop11 - 70 MB / 67 MiB - 138368 sectors (RO), sector size=512
Disk /dev/loop12 - 58 MB / 55 MiB - 113296 sectors (RO), sector size=512
Disk /dev/loop13 - 32 MB / 30 MiB - 63360 sectors (RO), sector size=512
Disk /dev/loop14 - 280 MB / 267 MiB - 548728 sectors (RO), sector size=512
Disk /dev/loop15 - 114 MB / 108 MiB - 223160 sectors (RO), sector size=512
Disk /dev/loop16 - 143 KB / 140 KiB - 280 sectors (RO), sector size=512
Disk /dev/loop17 - 133 MB / 126 MiB - 259952 sectors (RO), sector size=512
Disk /dev/loop18 - 52 MB / 49 MiB - 101960 sectors (RO), sector size=512
Disk /dev/loop19 - 228 MB / 217 MiB - 446248 sectors (RO), sector size=512
Disk /dev/loop2 - 102 MB / 97 MiB - 200168 sectors (RO), sector size=512
Disk /dev/loop20 - 114 MB / 108 MiB - 223160 sectors (RO), sector size=512
Disk /dev/loop21 - 53 MB / 50 MiB - 103776 sectors (RO), sector size=512
Disk /dev/loop22 - 65 MB / 62 MiB - 127160 sectors (RO), sector size=512
Disk /dev/loop23 - 57 MB / 54 MiB - 112552 sectors (RO), sector size=512
Disk /dev/loop24 - 280 MB / 267 MiB - 548728 sectors (RO), sector size=512
Disk /dev/loop25 - 32 MB / 30 MiB - 63344 sectors (RO), sector size=512
Disk /dev/loop3 - 170 MB / 162 MiB - 333096 sectors (RO), sector size=512
Disk /dev/loop4 - 63 MB / 60 MiB - 124888 sectors (RO), sector size=512
Disk /dev/loop5 - 170 MB / 162 MiB - 333048 sectors (RO), sector size=512
Disk /dev/loop6 - 267 MB / 255 MiB - 523400 sectors (RO), sector size=512
Disk /dev/loop7 - 9924 KB / 9692 KiB - 19384 sectors (RO), sector size=512
Disk /dev/loop8 - 651 KB / 636 KiB - 1272 sectors (RO), sector size=512
Disk /dev/loop9 - 170 MB / 162 MiB - 333552 sectors (RO), sector size=512
Disk /dev/nvme0n1 - 256 GB / 238 GiB - CHS 244198 64 32, sector size=512
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=500118191 (expected 500118191)
hdr_lba_start=34
hdr_lba_end=500118158
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 2 P MS Reserved              1333248    1595391     262144 [Microsoft reserved partition]
 3 P MS Data                  1595392  262678527  261083136 [Basic data partition]
 1 P EFI System                  2048    1333247    1331200 [EFI system partition]
 7 P Linux filesys. data    262678528  430260223  167581696
 8 P Linux Swap             430260224  463464447   33204224
 4 P Windows Recovery Env   463464448  465491967    2027520
 5 P Windows Recovery Env   465491968  497444863   31952896
 6 P Windows Recovery Env   497446912  500084735    2637824
disk_image write() failed: No space left on device
No space left for the file image.
xbitz
#10 Post by xbitz »
Hello!
I managed to solve the issue.
The .dd file was still in the trash, so i went ahead and deleted.
Space is freed and everything boots now.
I want to thank you for the help, and sorry for the misunderstandings!
Have a nice weekend!
