The following partition can't be recovered
karmapala
#1 Post by karmapala »
Hi dear experts,
I have a 5 month old USB hard-drive which suddenly yesterday became raw.
I didn't do anything, I didn't format it, I didn't run chkdsk,
I didn't even try to double click the drive to see if it still can be explored.
The hard disk contains only HD movie mkv files.
So today I use TestDisk, follow the instruction from this site "
Until that I don't know what to do,
should I continue or just close the window ?
Here is the log:
Fri Nov 13 20:37:39 2020
TestDisk 7.2-WIP, Data Recovery Utility, Novembre 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119356260352
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=392365604864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=107374182400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000398932480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=367001600
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - ADATA SU650, S/N:2J1020071968, FW:V8X01c62
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM002-1ER14C, S/N:Z4X0CMMH, FW:CC45
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate BUP Slim, S/N:00000000NABDHZHP, FW:1707
Disk /dev/sdc - 2000 GB / 1863 GiB - Seagate BUP Slim
BAD_RS LBA=2 16450559
Invalid NTFS or exFAT boot
 1 P HPFS - NTFS              0   0  3 243201  80 62 3907029165
Bad relative sector.
What should I do now ?
Any kind of help would be greatly appreciated.
Thank you in advanced.
Re: The following partition can't be recovered
karmapala wrote: 13 Nov 2020, 15:05 Hi dear experts,
Image.
That is the best reaction possible!
Run quick search and have a look at the partitions found trying to explore them using the "p"-key (list files).
If the content cannot be displayed or does not match your expectations continue with deep search.
If succesful you can either copy the files inside to another drive or write the partition info found.
karmapala
#3 Post by karmapala »
Thank you for your quick respond, recuperation.
Because yesterday after the Quick Search the result is :
"The following partition can't be recovered"
(btw, I don't know why the pictures are not shown in the desktop Chrome browser
but in my android cellphone Chrome browser I can see all the pictures I inserted)
And I didn't dare enough to hit Enter on my keyboard to [continue],
so yesterday I just closed the cmd window.
Today I run TestDisk again, and at this time the Quick Search show 95%.
if the result of the Quick Search is the same like yesterday "The following partition can't be recovered",
I will hit Enter on my keyboard to [continue] and I will do the Deep Search.
And then I will report to you the result of the Deep Search here.
Anyway, the result of the Quick Search today is the same like yesterday.
So I hit Enter on the keyboard to [continue], below is the result :
There is no "P: List Files" option there.
So I hit Enter on my keyboard to continue, it show like below :
Again I hit Enter on my keyboard to do the [Deeper Search].
Now it's analyzing the cylinder and after 03% it show like below :
After I get the result, I will report it here.
Thank you once again, recuperation.
karmapala
#4 Post by karmapala »
The Analyze Cylinder in [Deeper Search] now is 37%.
When I touch my hard disk, it's very very hot which my finger can't stand the hot if I touch it more than 1 minute.
Is this normal ?
Should I better stop the process ?
#5 Post by cgrenier »
Your partition may be listed as Raw
- because the partition location listed in the partition table is wrong. As the current partition location is unusual, searching the partition using Quick Search and Deeper Search is a good idea. If your disk is really getting too hot, you can stop TestDisk but it will not be able to resume the partition search, you will have to restart from the beginning.
- or because the NTFS boot sector is corrupted. In this case, run TestDisk, Advanced, Boot, if BackupBS is listed, choose it, confirm, Quit and restart your computer
It may be a good idea to check the second hypothesis and if it works, stop the other TestDisk running Deeper Search.
karmapala
#6 Post by karmapala »
Yes you are correct.
Too bad, my picture is not appearing in Desktop Browser (it appear in my cellphone browser though).
Anyway :
Done just now.
I think I won't do the [Deeper Search] anymore because I'm too coward if the hard disk getting very hot again ;) .
This is what I got just before I perform the [Quick Search] :
Ok... I will try this, cgrenier.
Thank you for the quick reply, , cgrenier.
Below is the log after I stop the [Deeper Search] because the hard disk too hot :
Sat Nov 14 12:58:22 2020
BAD_RS LBA=1616642733 16248234
     FAT16 >32M           100631  90 49 224640  81 37 1992204007
BAD_RS LBA=1670796474 14100972
file_pread(6,3,buffer,1670796474(371351/158/2)) lseek err Invalid argument
file_pread(6,1,buffer,1670796474(371351/158/2)) lseek err Invalid argument
     FAT12                371351 158  2 499971 159 10 2066280372
This partition ends after the disk limits. (start=5965763770, size=2066280372, end=8032044141, disk end=3907029167)
file_pread(6,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(6,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(6,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(6,14,buffer,3907031042(243201/110/48)) lseek err Invalid argument
file_pread(6,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(6,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(6,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(6,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(6,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4112 GB / 3829 GiB)
   L FAT16 >32M           100631  90 49 224640  81 37 1992204007
add_ext_part_i386: max
add_ext_part_i386: min
 1 E extended LBA         100631   0  1 224640 254 63 1992220650
 5 L FAT16 >32M           100631  90 49 224640  81 37 1992204007
karmapala
#7 Post by karmapala »
Too bad, there is no [BackupBS] listed, but [Rebuild BS], cgrenier.
I hope there is something else that you can suggest me to do.
Thank you once again, cgrenier.
Below is the log after I try the [Advance] then enter the [Boot]:
Sat Nov 14 17:16:53 2020
ntfs_boot_sector
filesystem size           5184059791298460365 1
sectors_per_cluster       2 0
mft_lcn                   2412677071 0
mftmirr_lcn               3899778265 0
clusters_per_mft_record   -103 0
clusters_per_index_record -30 0
Status: Bad
Status: Bad
Sectors are not identical.
