Find ZFS partition Topic is solved
Find ZFS partition
Hello, I've mistakenly destroyed GPT on HDD. (Yes, both main and backup GPT.)
Here: https://www.cgsecurity.org/wiki/TestDisk is said that Testdisk can find lost ZFS partitions.
Testdisk recovered all partition, except 2 non-raid ZFS pools.
It sees even raw partitions, I've backuped in files and raw VM files, but absolutely blind dealing with ZFS.
Can anybody help me to make Testdisk see ZFS partitions?
Re: Find ZFS partition
Have the ZFS partitions been encrypted?
Support for ZFS in TestDisk is very limited.
TestDisk should be able to find ZFS boot block (struct vdev_boot_header) https://git.cgsecurity.org/cgit/testdisk/tree/src/zfs.c
The beginning of a partition may looks like (hexdump output)
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00003fd0 00 00 00 00 00 00 00 00 11 7a 0c b1 7a da 10 02 |.........z..z...|
zio-data-bloc-tail
00003fe0 3f 2a 6e 7f 80 8f f4 97 fc ce aa 58 16 9f 90 af |?*n........X....|
00003ff0 8b b4 6d ff 57 ea d1 cb ab 5f 46 0d db 92 c6 6e |..m.W...._F....n|
00004000 01 01 00 00 00 00 00 00 00 00 00 01 00 00 00 24 |...............$|
00004010 00 00 00 20 00 00 00 07 76 65 72 73 69 6f 6e 00 |... ....version.|
00004020 00 00 00 08 00 00 00 01 00 00 00 00 00 00 00 08 |................|
00004030 00 00 00 28 00 00 00 28 00 00 00 04 6e 61 6d 65 |...(...(....name|
00004040 00 00 00 09 00 00 00 01 00 00 00 09 74 61 6e 6b |............tank|
00004050 58 31 34 30 65 00 00 00 00 00 00 24 00 00 00 20 |X140e......$... |
00004060 00 00 00 05 73 74 61 74 65 00 00 00 00 00 00 08 |....state.......|
00004070 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 20 |............... |
00004080 00 00 00 20 00 00 00 03 74 78 67 00 00 00 00 08 |... ....txg.....|
00004090 00 00 00 01 00 00 00 00 01 5a 79 28 00 00 00 28 |.........Zy(...(|
000040a0 00 00 00 28 00 00 00 09 70 6f 6f 6c 5f 67 75 69 |...(....pool_gui|
000040b0 64 00 00 00 00 00 00 08 00 00 00 01 6a 72 a9 ee |d...........jr..|
000040c0 37 ec a7 da 00 00 00 24 00 00 00 20 00 00 00 06 |7......$... ....|
000040d0 65 72 72 61 74 61 00 00 00 00 00 08 00 00 00 01 |errata..........|
000040e0 00 00 00 00 00 00 00 00 00 00 00 28 00 00 00 28 |...........(...(|
000040f0 00 00 00 08 68 6f 73 74 6e 61 6d 65 00 00 00 09 |....hostname....|
00004100 00 00 00 01 00 00 00 05 58 31 34 30 65 00 00 00 |........X140e...|
00004110 00 00 00 24 00 00 00 28 00 00 00 08 74 6f 70 5f |...$...(....top_|
00004120 67 75 69 64 00 00 00 08 00 00 00 01 a1 74 3b 25 |guid.........t;%|
00004130 94 94 d9 77 00 00 00 20 00 00 00 20 00 00 00 04 |...w... ... ....|
00004140 67 75 69 64 00 00 00 08 00 00 00 01 c7 16 54 40 |guid..........T@|
00004150 90 b7 bb a2 00 00 00 2c 00 00 00 28 00 00 00 0d |.......,...(....|
00004160 76 64 65 76 5f 63 68 69 6c 64 72 65 6e 00 00 00 |vdev_children...|
00004170 00 00 00 08 00 00 00 01 00 00 00 00 00 00 00 01 |................|
00004180 00 00 04 d8 00 00 00 38 00 00 00 09 76 64 65 76 |.......8....vdev|
00004190 5f 74 72 65 65 00 00 00 00 00 00 13 00 00 00 01 |_tree...........|
000041a0 00 00 00 00 00 00 00 01 00 00 00 24 00 00 00 20 |...........$... |
000041b0 00 00 00 04 74 79 70 65 00 00 00 09 00 00 00 01 |....type........|
000041c0 00 00 00 05 72 61 69 64 7a 00 00 00 00 00 00 20 |....raidz...... |
000041d0 00 00 00 20 00 00 00 02 69 64 00 00 00 00 00 08 |... ....id......|
000041e0 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 20 |............... |
000041f0 00 00 00 20 00 00 00 04 67 75 69 64 00 00 00 08 |... ....guid....|
...Re: Find ZFS partition
Neither LUKS nor plain. May be ZFS native encryption, but no third-party soft.
Thank you, I'll search for "11 7a 0c b1 7a da 10 02" in hexeditor, but it will take a long time...cgrenier wrote: 15 Nov 2020, 10:00 Support for ZFS in TestDisk is very limited.
The beginning of a partition may looks like (hexdump output)Code: Select all
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 00003fd0 00 00 00 00 00 00 00 00 11 7a 0c b1 7a da 10 02 |.........z..z...| zio-data-bloc-tail 00003fe0 3f 2a 6e 7f 80 8f f4 97 fc ce aa 58 16 9f 90 af |?*n........X....| 00003ff0 8b b4 6d ff 57 ea d1 cb ab 5f 46 0d db 92 c6 6e |..m.W...._F....n| 00004000 01 01 00 00 00 00 00 00 00 00 00 01 00 00 00 24 |...............$| 00004010 00 00 00 20 00 00 00 07 76 65 72 73 69 6f 6e 00 |... ....version.| 00004020 00 00 00 08 00 00 00 01 00 00 00 00 00 00 00 08 |................| 00004030 00 00 00 28 00 00 00 28 00 00 00 04 6e 61 6d 65 |...(...(....name| 00004040 00 00 00 09 00 00 00 01 00 00 00 09 74 61 6e 6b |............tank| 00004050 58 31 34 30 65 00 00 00 00 00 00 24 00 00 00 20 |X140e......$... | 00004060 00 00 00 05 73 74 61 74 65 00 00 00 00 00 00 08 |....state.......| 00004070 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 20 |............... | 00004080 00 00 00 20 00 00 00 03 74 78 67 00 00 00 00 08 |... ....txg.....| 00004090 00 00 00 01 00 00 00 00 01 5a 79 28 00 00 00 28 |.........Zy(...(| 000040a0 00 00 00 28 00 00 00 09 70 6f 6f 6c 5f 67 75 69 |...(....pool_gui| 000040b0 64 00 00 00 00 00 00 08 00 00 00 01 6a 72 a9 ee |d...........jr..| 000040c0 37 ec a7 da 00 00 00 24 00 00 00 20 00 00 00 06 |7......$... ....| 000040d0 65 72 72 61 74 61 00 00 00 00 00 08 00 00 00 01 |errata..........| 000040e0 00 00 00 00 00 00 00 00 00 00 00 28 00 00 00 28 |...........(...(| 000040f0 00 00 00 08 68 6f 73 74 6e 61 6d 65 00 00 00 09 |....hostname....| 00004100 00 00 00 01 00 00 00 05 58 31 34 30 65 00 00 00 |........X140e...| 00004110 00 00 00 24 00 00 00 28 00 00 00 08 74 6f 70 5f |...$...(....top_| 00004120 67 75 69 64 00 00 00 08 00 00 00 01 a1 74 3b 25 |guid.........t;%| 00004130 94 94 d9 77 00 00 00 20 00 00 00 20 00 00 00 04 |...w... ... ....| 00004140 67 75 69 64 00 00 00 08 00 00 00 01 c7 16 54 40 |guid..........T@| 00004150 90 b7 bb a2 00 00 00 2c 00 00 00 28 00 00 00 0d |.......,...(....| 00004160 76 64 65 76 5f 63 68 69 6c 64 72 65 6e 00 00 00 |vdev_children...| 00004170 00 00 00 08 00 00 00 01 00 00 00 00 00 00 00 01 |................| 00004180 00 00 04 d8 00 00 00 38 00 00 00 09 76 64 65 76 |.......8....vdev| 00004190 5f 74 72 65 65 00 00 00 00 00 00 13 00 00 00 01 |_tree...........| 000041a0 00 00 00 00 00 00 00 01 00 00 00 24 00 00 00 20 |...........$... | 000041b0 00 00 00 04 74 79 70 65 00 00 00 09 00 00 00 01 |....type........| 000041c0 00 00 00 05 72 61 69 64 7a 00 00 00 00 00 00 20 |....raidz...... | 000041d0 00 00 00 20 00 00 00 02 69 64 00 00 00 00 00 08 |... ....id......| 000041e0 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 20 |............... | 000041f0 00 00 00 20 00 00 00 04 67 75 69 64 00 00 00 08 |... ....guid....| ...
What hexeditor woul you advise?
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364801 255 63
1 P Linux filesys. data 40 4095 4056 [Linux filesystem]
2 P MS Data 4096 2101247 2097152 [T3.D2.E1]
3 P MS Data 2101248 1259382783 1257281536 [Win10]
4 P Linux filesys. data 1259382784 1263609855 4227072 [Linux filesystem]
5 P Linux filesys. data 1263609856 1267771391 4161536
6 P Linux filesys. data 1267771392 1968764927 700993536 <-- this is one of my ZFS,
which I've recovered using bash+losetup+gdisk, without testdisk. In Testdisk it was
only freespace between 2 partitions.
Even now, after I recovered 1 ZFS partition, Testdisk does not detect it's FS.And this is not-damaged disk with ZFS:
> 1 P Unknown 2048 6143 4096 [tb2-d1-p1-bios-boot]
2 P MS Data 6144 1056767 1050624 [DISK_3_EFI] [T2.D1.E1]
3 P MS Reserved 1056768 1093631 36864
4 P Linux filesys. data 1093632 5287935 4194304
5 P Solaris /usr 5287936 216043519 210755584 <-- this is ZFS, but Testdisk does not see it's FS.
6 P Linux filesys. data 216043520 3697315839 3481272320https://gist.github.com/krichter722/bff ... 818fb22cbd
Here krichter shows his Testdisk output:
1 P Solaris /usr 2048 3907012607 3907010560 [zfs-2fa627ed13bb64de]
9 P Unknown 3907012608 3907028991 16384And in his case, ZFS is detected, but noone of my ZFS partitions, both lost and healthy, is visible forTestdisk. Why so?
All ZFS were created and used in Linux.
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.10
Release: 20.10
Codename: groovy```
uname -a
Linux n0 5.8.0-28-generic #30-Ubuntu SMP Thu Nov 5 13:24:33 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux-
If your children are kidnapped they are kind of lost but you can never say they are healthy.arm512 wrote: 15 Nov 2020, 12:42 And in his case, ZFS is detected, but noone of my ZFS partitions, both lost and healthy, is visible forTestdisk. Why so?
The same applies to your ZFS partitions. There is no evidence that they are healthy.
Unfortunately you did not bother providing a log file. It could be that by just looking at the locations of the other partition you could guess where the first ZFS partition should start.
Here is something you could do:
Get a new drive.
Partition that drive as GPT with just one ZFS partition. The partition does not have to fill the whole drive. Maybe that will work as well using an USB stick.
Use the machine and configuration that you used to create the now broken pool and create a new one and assign the freshly created partition above.
Run Testdisk and save the log file. That will show you if Testdisk performs under a clean, healthy configuration.
It should provide you with the first and last sector number of your ZFS partition, too.
Using a hexeditor, zero out the GPT and its backup.
Now rerun Testdisk to see what it gives.
Under healthy partitions I ment partitions on other drives with alive GPT. Testdisk doesn't see them too.recuperation wrote: 15 Nov 2020, 14:30If your children are kidnapped they are kind of lost but you can never say they are healthy.arm512 wrote: 15 Nov 2020, 12:42 And in his case, ZFS is detected, but noone of my ZFS partitions, both lost and healthy, is visible forTestdisk. Why so?
Get a new drive.
I don't think that loop device will be worse than USB-stick.
So I tryed what you've advised, but on the loop device:
Before wiping GPT:
No partition found or selected for recoveryCode: Select all
Sun Nov 15 15:54:10 2020
Command line: TestDisk /log /dev/loop26
OS: Linux, kernel 5.7.0-rc5-zbod-ym29 (#1 SMP Wed May 13 19:59:50 EEST 2020) x86_64
Compiler: GCC 9.2
ext2fs lib: 1.45.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.1
Disk /dev/loop26 - 20 GB / 18 GiB - 39062500 sectors, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/loop26 - 20 GB / 18 GiB - 39062500 sectors
1 P Linux filesys. data 2048 39061503 39059456
TestDisk exited normally.Code: Select all
Sun Nov 15 16:05:34 2020
Compiler: GCC 9.2
Disk /dev/loop26 - 2000 MB / 1907 MiB - 3906250 sectors, sector size=512
Analyse Disk /dev/loop26 - 2000 MB / 1907 MiB - 3906250 sectors
Trying alternate GPT
TestDisk exited normallOfcource I can test ZFS created on NetBSD, Illumos/OpenSolaris deriatives, FreeBSD, and original, Oracle's Solaris ZFS. It would be interesting. I think Testdisk would see either Illumos-created ZFS or when ZFS is on Sun Partition table nested inside the GPT partition (grub-path: 'hd0,gpt1,sunpc1', similar to FreeBSD's MBR setup /dev/ad0s1a (grub's 'hd0,msdos1,bsd1')). In Solaris way there will be also partition 9, just after the pool ends... But that's not my case, I use ZoL version of ZFS.
The end of the partition doesn't matter to recover:
losetup -o $OFFSET -f /dev/sd$LETTER
zpool import -o readonly=on -fN $ZPOOL -d /dev/$LOOP_DEVICE
zfs send -R .... | zfs recv ...-
Unfortunately I don't have experience with ZFS.
But there are a few interesting things to note:
There are different GPT identifiers for ZFS on different operating systems. There is no reserved one for Linux.
Search ZFS in this document:
https://en.wikipedia.org/wiki/GUID_Partition_Table
I guess creating a pool does not change the identifier in the GPT. You can test that.
After creating the pool I would write at least one file into the pool to make sure that the structure gets initialized.
I still do not know where the pool specs are stored.
Your documentation did not tell if and when you created a pool.
Anyway you could save the first sector of your ZFS partition to be able to compare it with the fingerprint Testdisk is looking for.
There might be differences.
Searching "11 7a 0c b1 7a da 10 02" was not the best idea. After find-counter turned to 8500, I decided to search "00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11 7a 0c b1 7a da 10 02" instead.
We'll see what will give.
