I've searched the www but did not found an answer...
Last post on this topic dates back 2015
So,
My ext. backup HDD crashed after a bad micro-usb connection.
Seagate Desktop HDD 4000GB
It was connected via a USB3.0 hub to my laptop (WIN10/64)
Switched cables etc but it only shows as a USB-device without name or station.
So I took the HDD out of it's case and placed it into a dockingstation that goes ito my laptop via USB2.0
Now it's given a Station letter but I get the popup "Drive needs to be formatted, format now?"
NO !!
So I ran TestDisk but I got the message:
The harddisk (2199 GB / 2047 GiB) seems too small! (< 4000 GB / 3726 GiB)
Also telling me this should be fixed first.
Can someone tell me How to do this ? Without loss of data
Log can be found below
Thnx in advance !
Wevie
Wed Nov 18 02:32:49 2020
TestDisk 7.2-WIP, Data Recovery Utility, Novembre 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2199023255040
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Onjuiste functie.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Onjuiste functie.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2199023255040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=498819749376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500097329664
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HGST HTS725050A7E630, S/N:
Disk /dev/sdc - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512 - ST4000DM 000-1F2168, S/N:00000000003A
Disk /dev/sdc - 2199 GB / 2047 GiB - ST4000DM 000-1F2168
Analyse Disk /dev/sdc - 2199 GB / 2047 GiB - CHS 267349 255 63
Invalid NTFS or exFAT boot
1 * HPFS - NTFS 0 32 33 60800 41 62 976752597
NTFS at 1/5/5
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
filesystem size 976752597
sectors_per_cluster 1
mftmirr_lcn 2
clusters_per_mft_record 1
HPFS - NTFS 1 5 5 486401 80 55 7814020776 [SERIES 3]
NTFS, blocksize=4096, 4000 GB / 3726 GiB
This partition ends after the disk limits. (start=16384, size=7814020776, end=7814037159, disk end=4294967295)
How do I fix Wrong HDD Size ?
Re: How do I fix Wrong HDD Size ?
Thank you for providing a good detailed description of your case!WevieStonder wrote: 18 Nov 2020, 02:47 search_part()
NTFS at 1/5/5
Warning: number of bytes per sector mismatches 4096 (NTFS) !=512 (HD)
If your drive came with an external case put it back there and rerun Testdisk. It looks as if the case electronics emulates a sector size of 4096 byte.
The file system size above is roughly 1e9 sectors according to the NTFS data found.
1e9 sectors * 4096 byte / sector will give approx. 4e12 bytes which are the 4TB of your drive.
