19 Nov 2020
Can anyone point me to compiled binaries of PhotoRec and/or TestDisk that
I can run on a Raspberry Pi (ARM) Processor ?
of, if not, a link to the source from which I can compile, and any compile hints if you have any...
I have a GB image of a possibly corrupted disk from which i want to recover
many Photoshop files (my best friends' life work as a photographer),
If i can get a copy of PhotoRec working on my PI 4, I'll just let it run ...
thanks for your help,
Craig
Raspberry Pi Binaries of TestDisk and PhotoRec
Re: Raspberry Pi Binaries of TestDisk and PhotoRec
There is no binary for your platform:craig wrote: 19 Nov 2020, 21:56 19 Nov 2020
https://www.cgsecurity.org/wiki/TestDisk_Download
rottenronnie
They should be included in the current repository (note that I am running Raspberry OS buster 64bit beta)
From the command prompt issue:
sudo apt search testdisk
To install it:
sudo apt install testdisk
I hope this helps.
pi@pi4:/mnt/storage $ sudo apt search testdisk
Sorting... Done
Full Text Search... Done
forensics-extra/stable,stable,now 2.8 all [installed]
Forensics Environment - extra console components (metapackage)
testdisk/stable,now 7.0-3+b4 arm64 [installed,automatic]
Partition scanner and disk recovery tool, and PhotoRec file recovery tool
testdisk-dbg/stable 7.0-3+b4 arm64
I hope this helps.
thank you, and, I was able build from source . I think I'm running Raspbian.
Amazingly, ./configure; make ; make install
actually worked !
actually worked !
