I tried to plug an old Macbook drive via USB enclosure, at first it booted up and i can see the files but then suddenly it froze so i used Disk Utiliy and First Aid from my Macbook, after that i couldn't boot that drive never again...
So i used DDrescue and copied my HDD's image and used PhotoRec (It did really well. I got almost everything i think... but its a mess wrong filenames etc...)
So if i can use DDrescue and can get files with PhotoRec maybe i can also repair/mount the partition using Testdisc on .img file or something?
I need some help on this, just need instructions/guidance and i can post every .log file so we can fix it together. (And yes i checked testdisk.pdf but i got weird errors that i dont understand)
Thank you.
I cant mount the partition (PhotoRec worked but i still need to mount it!)
Re: I cant mount the partition (PhotoRec Worked)
Please choose a different PDF reader.TheCoffee wrote: 08 Dec 2020, 00:53 (And yes i checked testdisk.pdf but i got weird errors that i dont understand)
I mean to say that i didnt understand it well after i read itrecuperation wrote: 12 Dec 2020, 13:53Please choose a different PDF reader.TheCoffee wrote: 08 Dec 2020, 00:53 (And yes i checked testdisk.pdf but i got weird errors that i dont understand)
Re: I cant mount the partition (PhotoRec worked but i still need to mount it!)
Try it out, post the log file and be precise when writing.TheCoffee wrote: 08 Dec 2020, 00:53 So if i can use DDrescue and can get files with PhotoRec maybe i can also repair/mount the partition using Testdisc on .img file or something?
Hi again, i made Mac HFS to Primary and others to Deleted since i dont need them and then choosed Write! this is the .log
Using locale 'C/UTF-8/C/C/C/C'.
Tue Dec 22 19:58:38 2020
Command line: TestDisk /log image.img
OS: Darwin, kernel 20.2.0 (Darwin Kernel Version 20.2.0: Wed Dec 2 20:39:59 PST 2020; root:xnu-7195.60.75~1/RELEASE_X86_64) x86_64
Compiler: GCC 4.2
ext2fs lib: none, ntfs lib: none, reiserfs lib: none, ewf lib: none, curses lib: ncurses 5.7
User is not root!
Disk image.img - 500 GB / 465 GiB - CHS 60802 255 63, sector size=512
Partition table type: EFI GPT
Analyse Disk image.img - 500 GB / 465 GiB - CHS 60802 255 63
1 P Mac HFS 429906 975523857 975093952
heads/cylinder 16 (FAT) != 255 (HD)
EFI System 40 409639 409600 [EFI System Partition] [EFI]
HFS+ blocksize=4096, 499 GB / 464 GiB
Mac HFS 976773124 978042659 1269536
HFS+ blocksize=4096, 650 MB / 619 MiB
This partition ends after the disk limits.
Mac HFS 975503592 976773127 1269536
HFS+ found using backup sector!, 650 MB / 619 MiB
The harddisk (500 GB / 465 GiB) seems too small! (< 500 GB / 466 GiB)
write!
Hopefully your image file contains a disc image and not a partition image - you did not tell.
Testdisk can not repair your HFS file system it can only make a lost HFS partition reappear.
Use third party software for a recovery of a HFS file system.
Oh, i thought it also repairs non-mounatble hdd img's, can you suggest any apps that can help my problem?
You did not get the message: Testdisk does not talk HFS, whether it's on a disc, a disc image or written on a wall. I don't speak Spanish. It does not make a difference in understanding if I try to read Spanish in a newspaper, a book or written on a wall.
Apps are for smart phones as far as I know. You do not use a smart phone for disc recovery. I don't have a Mac - I don't know - use Google!, can you suggest any apps that can help my problem?
Thats why i said "thought" lol, and it was just a "thought"You did not get the message: Testdisk does not talk HFS, whether it's on a disc, a disc image or written on a wall. I don't speak Spanish. It does not make a difference in understanding if I try to read Spanish in a newspaper, a book or written on a wall.
Yeah i know that, consider it as a typo lol. And i thought this forum can find a solution to my un-mountable HDD, but since i have a HFS, well that's my bad i guess... sorry to botherApps are for smart phones as far as I know. You do not use a smart phone for disc recovery. I don't have a Mac - I don't know - use Google!
