Recover removed luks partition before reboot Topic is solved
spaceham
#1 Post by spaceham »
I've done some mistake, but my system is still running and runs properly and I've still access to everything needed.
I have deleted boot partition, tried to recover it with testdisk however in the process I deleted my two other partition.
My inital setup was pretty simple:
  • one EFI system partition
  • one encrypted ext4 partition making most of the disk
  • one encrypted swap partition.
I've tried a deeper searc(simple search just wasn't seing so much) with testdisk here's what I found:
Disk /dev/nvme0n1 - 512 GB / 476 GiB - CHS 488386 64 32
 P EFI System                  2048    1619967    1617920 [EFI System Partition] [ESP]
 D MS Data                     2054    1619973    1617920 [NO NAME]
 D EFI System                  4096     618495     614400 [EFI System Partition]
 D MS Data                     4102     618501     614400
 D MS Data                    37699      43872       6174
 D MS Data                    43872      50045       6174 [Boot]
 D Linux filesys. data       618494 1000206893  999588400
 P Linux filesys. data       618496     622591       4096
 D Linux filesys. data       618496 1000206895  999588400
 D MS Data                374180459  374183338       2880 [NO NAME]
 D MS Data                374180483  374183362       2880 [NO NAME]
 D MS Data                374181379  374184258       2880 [NO NAME]
>P Linux filesys. data    965039160  965043255       4096
The two partition with block size of 4096 are marked as luks with bad structure. How should I identify the one to restore ?
I've been able to backup Luks header maybe they come useful ?
My partitions look like this from /sys/class/block
#main partition
/sys/class/block/nvme0n1p2/start
618496
/sys/class/block/nvme0n1p2/size
964420664
#Swap partition
/sys/class/block/nvme0n1p3/start
965039160
/sys/class/block/nvme0n1p3/size
35167740
My current partition table looks like this:
Disk /dev/nvme0n1: 1000215216 sectors, 476.9 GiB
Model: BC511 NVMe SK hynix 512GB
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 56029EED-7ABF-414D-9D67-7ECF15B53AAC
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 1000215182
Partitions will be aligned on 2048-sector boundaries
Total free space is 998597229 sectors (476.2 GiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1            2048         1619967   790.0 MiB   EF00  EFI System Partition
I hope someone will be able to drive me in such a mess.
Thank you
Re: Recover removed luks partition before reboot
spaceham wrote: 21 Dec 2020, 13:35 I've done some mistake, but my system is still running and runs properly and I've still access to everything needed.
Size, please, if not known exactly then roughly!
#main partition
618496
964420664
#Swap partition
965039160
35167740
Thank you
Please post your complete log file.
You might disconnect unnecessary other drives.
#3 Post by recuperation »
#main partition
618496
964420664
#Swap partition
965039160
35167740
Thank you
spaceham
#4 Post by spaceham »
GPT partition is less than 316 669 952 bytes
luks / partition is 493 783 379 968 bytes
luks swap is 18 005 882 880 bytes
I already know that the restored GTP/EFI partition is bigger than it should at the moment.
I've attached the log from deep search.
testdisk.log.bz2
compressed testdisk.log
(11.3 KiB) Downloaded 551 times
Thank you for your answer
spaceham
#5 Post by spaceham »
Whouhou this is solved
After analyzing all those data more precisely,
I've done another testdisk run , and finally understood that my GPT partition shouldn't be that big and is in fact not the one I though.
So to conclude I've marked this partition to be added:
A EFI System                  4096     618495     614400
I then added 2 other partitions with those informations:
Partition Data:
Sector
begin: 964420644
end: 965039159
type: Linux sys - Luks
Partition SWAP:
Sector
start: 965039160
end: 1000206899
I've rebooted et voilà, it simply works.
Have a nice day and thanks for the great tool.
