My windows XP HDD partition went RAW and i cant access any of the files. I have tried to use TestDisk to solve this problem but even after detecting the partition and checking the "boot" and MFT are correct, my computer wont boot. I conected the hdd to a second computer and the partition keeps displaying it is in raw format. I dont know if i am missing some steps to change this or what i am doing wrong.
Windows Hdd Bootable Partition Went Raw
victorhu91
Hello
https://ibb.co/0JSTqxk
https://ibb.co/jWbg4mc
Re: Windows Hdd Bootable Partition Went Raw
Please upload your pictures using the attachment tab.
Did you use the "p"-key to see if the partitions are accessible?
Please post your log file.
