Partition Recovery problem with SSD
natec
#1 Post by natec »
I have a 512 GB Samsung SSD. The disk had one partition for the entire capacity.
The Windows 10 installer probably formatted the entire drive and created a 32 GB partition with the Windows 10 installer.
Currently, the disk is seen in Windows as 476 GB of free space.
Normally, a search in TestDisk shows only a 32 GB partition. After using the search options, the program shows two partitions:
Disk / dev / sdb - 512 GB / 476 GiB - CHS 62260 255 63 Partition Start End Size in sectors
D FAT32 LBA 0 32 33 4177 117 36 67108864 [EFI System Partition] [ESD-USB]
D HPFS - NTFS 0 32 33 62 260 88 36 1000 210 432
Structure: Ok. Use Up/Down Arrow keys to select partition. Use Left/Right Arrow keys to CHANGE partition characteristics: *=Primary bootable P=Primary L=Logical E=Extended D=Deleted Keys A: add partition, L: load backup, T: change type, P: list files, Enter: to continue NTFS found using backup sector, blocksize=4096, 512 GB / 476 GiB[/size]
Using options on the 476 GB drive "P" displays the message: Can't open filesystem. Filesystem seems damaged.
I need to restore the 476 GB partition where my personal files were. Please help in this matter.
Thank you very much.
natec
Sun Dec 27 21:26:17 2020
TestDisk 7.2-WIP, Data Recovery Utility, Novembre 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=5000981077504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=5000981077504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239810379776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=5000845590528
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - IM2P33F3 NVMe ADATA 256GB, S/N:0000_0000_0000_0000_0000_0000_0000_0001., FW:92009161
Disk /dev/sdb - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - Samsung SSD 850 PRO 512G, S/N:0000AB123560, FW:8101
Disk /dev/sdc - 5000 GB / 4657 GiB - CHS 608001 255 63, sector size=512 - Seagate Expansion, S/N:NAAQ0FHJ, FW:0710
Disk /dev/sdb - 512 GB / 476 GiB - Samsung SSD 850 PRO 512G
Analyse Disk /dev/sdb - 512 GB / 476 GiB - CHS 62260 255 63
 1 P EFI GPT                  0   0  2 62260 131 63 1000215215
FAT32 at 0/32/33
FAT1 : 8196-16385
FAT2 : 16386-24575
start_rootdir : 24576 root cluster : 2
Data : 24576-67108863
sectors : 67108864
cluster_size : 64
no_of_cluster : 1048192 (2 - 1048193)
fat_length 8190 calculated 8190
FAT32 at 0/32/33
FAT: cluster=2(0x2), pos=26624
     FAT32, blocksize=32768, 34 GB / 32 GiB
file_pread(5,2,buffer,1000216575(62260/153/37)) lseek err Invalid argument
file_pread(5,1,buffer,1000216575(62260/153/37)) lseek err Invalid argument
file_pread(5,2,buffer,1000216576(62260/153/38)) lseek err Invalid argument
file_pread(5,14,buffer,1000216578(62260/153/40)) lseek err Invalid argument
file_pread(5,3,buffer,1000216592(62260/153/54)) lseek err Invalid argument
file_pread(5,3,buffer,1000216639(62260/154/38)) lseek err Invalid argument
file_pread(5,8,buffer,1000216655(62260/154/54)) lseek err Invalid argument
file_pread(5,11,buffer,1000216702(62260/155/38)) lseek err Invalid argument
file_pread(5,2,buffer,1000218624(62260/186/7)) lseek err Invalid argument
   * FAT32 LBA                0  32 33  4177 117 36   67108864 [EFI System Partition] [ESD-USB]
 1 * FAT32 LBA                0  32 33  4177 117 36   67108864 [EFI System Partition] [ESD-USB]
FAT32 at 0/32/33
FAT1 : 8196-16385
FAT2 : 16386-24575
sectors : 67108864
cluster_size : 64
FAT32 at 0/32/33
FAT32 at 0/32/39
FAT1 : 8196-16385
FAT2 : 16386-24575
sectors : 67108864
cluster_size : 64
FAT32 at 0/32/39
     FAT32 LBA                0  32 33  4177 117 36   67108864 [EFI System Partition] [NO NAME]
NTFS at 62260/88/36
filesystem size           1000210432
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              0  32 33 62260  88 36 1000210432
file_pread(5,8,buffer,1000215296(62260/133/18)) lseek err Invalid argument
file_pread(5,1,buffer,1000215296(62260/133/18)) lseek err Invalid argument
file_pread(5,8,buffer,1000215424(62260/135/20)) lseek err Invalid argument
file_pread(5,8,buffer,1000215552(62260/137/22)) lseek err Invalid argument
file_pread(5,8,buffer,1000215680(62260/139/24)) lseek err Invalid argument
file_pread(5,8,buffer,1000215808(62260/141/26)) lseek err Invalid argument
file_pread(5,8,buffer,1000215936(62260/143/28)) lseek err Invalid argument
file_pread(5,8,buffer,1000216064(62260/145/30)) lseek err Invalid argument
file_pread(5,8,buffer,1000216192(62260/147/32)) lseek err Invalid argument
file_pread(5,8,buffer,1000216320(62260/149/34)) lseek err Invalid argument
file_pread(5,8,buffer,1000216448(62260/151/36)) lseek err Invalid argument
file_pread(5,1,buffer,1000216576(62260/153/38)) lseek err Invalid argument
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Re: Partition Recovery problem with SSD
Did you try "deep search"?
natec
#3 Post by natec »
Yes, i tried "deep search: and i got answer about partition:
Next i got answer: Can't open filesystem. Filesystem seems damaged.
With such a result only Photorec or any commercial solution would be the next step.
