Testdisk umount the SSD after recovery
yesidt111
#1 Post by yesidt111 »
Hi guys
I'm trying to recover my files from ext4 partition and I have next issues:
1. Is there any way to recovery any full folder once? I have folders into the folders.
2. After I copy any files, the SSD umount and I have to reset the laptop again for testdisk recognizes the SSD
Thanks.
Regards
yesidt111
Re: Testdisk umount the SSD after recovery
unsufficient problem description
yesidt111
#3 Post by yesidt111 »
hi!
Thanks. What else information do you need?. I'm trying to recovery my files from linux mint live CD. I install testdisk and when I try to recover the files, supposedly the tool copy files but after that, the hardisk is unmounted and I can´t see it again. The one way is reseting the laptop for seeing again the SSD.
Regards.
yesidt111
#4 Post by yesidt111 »
Hi!
So, something additional. The files copied have a size 0 bytes, why?.
Thanks.
#5 Post by recuperation »
yesidt111 wrote: 29 Dec 2020, 11:36 Hi guys
Are you using Testdisk???
There is a list of commands on the screen where you selected files. Yes, you can copy folders. There is no choice to select between folder with and without content.
What is "reset" exactly?
When does the SSD unmount?
Please describe exactly and/or provide a screenshot.
You did not state how the disc is connected.
yesidt111
#6 Post by yesidt111 »
Hi!!
I'm using testdisk
Reset=restart the laptop
The SSD unmount when testdisk ends the copy of any files or folder. When I end copy files, testdisk doesn't recognize the SSD and I must restart my laptop.
Thanks.
#7 Post by recuperation »
How is the drive (which drive?) connected physically?
Use drive diagnostics:
viewtopic.php?p=31992#p31992
yesidt111
#8 Post by yesidt111 »
Hi!
Thanks a lot. The SSD is into the laptop, is a disk of 512 GB. I'll see the link you share me. Again, thaks.
Regards
