last week I deleted my kdbx file unfortunately.
Unfortunately Photorec is not able to find any kdbx file.
Any idea how to proceed?
Windows 10
Thanks,
Unable to recover KDBX file Topic is solved
Re: Unable to recover KDBX file
You will have to build a fingerprint:
viewtopic.php?p=32663#p32663
You find information on the net about kdbx files.
But kdb and kdbx files are already recognized from Photorec, when I chose file options.
So it's no use?
So it's no use?
I did not bother checking Photorec for you, I understood your phrase as if there is no support.
Communication is difficult!
Anyway, Photorec supports kdbx files in their latest version.
The following is not a primary source but contains some information about their file headers:
https://gist.github.com/lgg/e6ccc6e212d ... c116fb1e45
Your left with the option to
1. build a custom fingerprint file.
2. Patch the Photorec executable accordingly
3. recompile Photorec with a modified fingerprint, replacing 0x67 with 0x66 or 0x65
