Cant find a specific partition after deep search
moyasser72
#1 Post by moyasser72 »
I ran testdisk on my hard drive after i accidentally formatted it while installing Zorin distro (im new to whole linux thing, didnt even know about the Live OS before installing the actual OS) the only thing i did to the hard disk was installing zorin after formatting no other overwriting... I had 4 partitions ( one for windows(C:) , and 3 for data ) .. after deep searching, testdisk found 3 partitions out of 4 ( windows and 2 data) but i couldn't find the fourth one... Did i lose that partition or any idea what is going on?
Here is a photo of testdisk results
Here is the log file
https://filebin.net/hhtcwj62gtc2pl8c/te ... t=zrgsr4rt
Re: Cant find a specific partition after deep search
You have probably overwritten one of your data partitions while installing Zorin.
If Testdisk doesn't list a partition where you would find your lost data using the p-key "list files" your options left is using Photorec or some commercial recovery software.
moyasser72
#3 Post by moyasser72 »
Thanks for replying bro, i tried photorec but its really messy because i had many courses and collecting them would take forever... do you have any recommendations for some softwares?
No. I have never received any feedback after the use of recovery software in this forum.
moyasser72
#5 Post by moyasser72 »
Well need a deep google search then :D .. thank you so much for helping out
