Please see my explanation below, but my questions are:
1)Should I attempt a rebuild of the boot sectors as it appears both the main and backup sectors are damaged?
2)Why is a 1TB drive reflecting as ~8 TB when I am trying to create a Disk Image of it?
3)Should I attempt repair without first creating an image?
4)When I used testdisk to perform a partition analysis (Analyze) of this drive, it looks like it found the partitions,
but when I viewed the files they all look to be dated from 2012 (ie inception of the drive). If I try to recover these partitions, will all my current
files become unrecoverable?
BACKGROUND:
Have a 1 TB Toshiba/Hitachi HDS721010DLE630 hard disk that wouldn't boot after a power outage. Took the drive out and tried to power it up with
a separate power cable; sometimes it beeps 6 times and doesn't appear to spin up; other times it does spin up and can see
it in Disk Management with a 3.5 GB RAW 'healthy' partition and a 928 GB unallocated 'partition'.
First tried Easeus; was able to save and transfer a few GB of my files, but most of my files that I found looked to be corrupted (could
not open them after I saved them to a different disk, or if they did open, the underlying data had no connection to the
filename itself). It seems the file directory has no proper connection anymore to the actual data.
On top of that, these corrupted files almost always had multiple copies of the
same file (ie. filex.txt, filex_1.txt, filex_2.txt, etc) all the way up to 8 files each I believe.
Had the exact same filesize on each of these files for a given filename.
Next, using testdisk, I've gotten these messages:
Boot sector: bad Backup boot sector: Bad ntfs_boot_sector: Can't read backup boot sector.
I wanted to first create DD images of the hard disk before working on it, but when I try to back up the Unallocated
portion of the drive, it indicates that it will be 7,997,748 MB in size, which won't fit on the backup drive I have.
I don't know how this is possible given that this is only a 1 TB drive. This seems related to the filename duplication issue above.
<<<TESTDISK LOG (sans Analyze process) >>>
Wed Feb 24 21:04:04 2021
TestDisk 7.2-WIP, Data Recovery Utility, January 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000786153472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000786153472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499498614784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4000784056320
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=3825205248
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM009-2F110A, S/N:W9A8FVJT, FW:CC43
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WD My Book 25ED, S/N:WX42D80C42DH, FW:1031
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - Hitachi HDS721010DLE630, S/N:152D20337A0C
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - Hitachi HDS721010DLE630, S/N:152D20337A0C
Drive F: - 3825 MB / 3648 MiB - CHS 58 255 63, sector size=4096 - Hitachi HDS721010DLE630, S/N:152D20337A0C
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - Hitachi HDS721010DLE630
1 * HPFS - NTFS 0 32 33 58 66 8 933888
2 P HPFS - NTFS 59 0 1 121601 48 31 1952575285
Not an exFAT boot sector.
Disk /dev/sdc - 1000 GB / 931 GiB - Hitachi HDS721010DLE630
Partition table type defaults to None
Drive F: - 3825 MB / 3648 MiB - Hitachi HDS721010DLE630
Partition table type: None
P Unknown 0 0 1 58 33 39 933888
ntfs_boot_sector
filesystem size 1 8048742538622943012
sectors_per_cluster 0 98
mft_lcn 0 4255054225
mftmirr_lcn 0 3305486450
clusters_per_mft_record 0 -26
clusters_per_index_record 0 106
Status: Bad
Status: Bad
Sectors are not identical.
ntfs_boot_sector
filesystem size 35779447885861 1
sectors_per_cluster 0 0
mft_lcn 1305143552 0
mftmirr_lcn 1208493132 0
clusters_per_mft_record 72 0
clusters_per_index_record 0 0
Status: Bad
Status: Bad
Bad filesystem and boot sectors; files are repeated 8 times?
Re: Bad filesystem and boot sectors; files are repeated 8 times?
No.brg6769 wrote: 25 Feb 2021, 04:26 Please see my explanation below, but my questions are:
Lack of documentation! The drives is correctly indicating 931GB. Use ddrescue as described in the manual.2)Why is a 1TB drive reflecting as ~8 TB when I am trying to create a Disk Image of it?
No.3)Should I attempt repair without first creating an image?
I don't know.4)When I used testdisk to perform a partition analysis (Analyze) of this drive, it looks like it found the partitions,
Duplicate your duplicate to have a drive where can safely play around.
Maybe you should try Microsoft?BACKGROUND:
a separate power cable; sometimes it beeps 6 times and doesn't appear to spin up; other times it does spin up and can seeFirst tried EaseusPlease ensure proper power supply to exclude a supply issue. Use a dockingstation.
Your description could suggest that you get power from one computer while simultaneously being connected with the data cable to another.
If it continues beeping or does not spin up contact a professional recovery company.
Easeus is a company. Try being precise.
dd is not able to work on unallocated portions of the drive. There is something wrong with your description.I wanted to first create DD images of the hard disk before working on it, but when I try to back up the Unallocated
Your drive size is fine:
