I am trying to install Photorec on an Ubuntu 20.04 linux machine.
because I primarily want to use E01 (Encase EWF) I followed the instruction at: https://www.cgsecurity.org/wiki/TestDisk_Compilation to install on the EWF library.
It seems that the EWF modules work fine like ewfinfo.
However photorec keeps indicating that E01 files cannot be opened:
The version information also states:photorec test.E01
PhotoRec 7.1, Data Recovery Utility, July 2019
Unable to open file or device test.E01: Success
ewf lib: none
Version: 7.1
Compiler: GCC 9.2
ext2fs lib: 1.45.5, ntfs lib: libntfs-3g, ewf lib: none, libjpeg: libjpeg-turbo-2.0.2, curses lib: ncurses 6.1, zlib: 1.2.11
OS: Linux, kernel 4.19.121-linuxkit (#1 SMP Tue Dec 1 17:50:32 UTC 2020) x86_64
root@7cfe1e2e0a64:/Data# photorec test.E01
https://www.cgsecurity.orgThanks!
DigiD
