Recover files after mkfs.ext4 /dev/mapper/<vg>-data.
cmonty14
#1 Post by cmonty14 »
I have accidently deleted all files in a logical volume by executing
The disk is not damaged, the partition table is correct, all partitions are accessible, LVM is showing no errrors.
Based on the documentation I cannot undelete files of an ext4 filesystems, instead I can use photorec.
If this is correct, can you please advise how to proceed?
Should I run photorec on the logical volume? Or should I mount the logical volume and then run photorec?
THX
Re: Recover files after mkfs.ext4 /dev/mapper/<vg>-data.
No need to mount the filesystem.
Run PhotoRec and select "/dev/mapper/<vg>-data"
Good luck
cmonty14
#3 Post by cmonty14 »
The original fileystem on the relevant logical volume was: EXT4
Is there any other "promising" option for data recovery?
PhotoRec is usually the easiest solution.
You can also try to recover your files by using the ext4 journal: https://gist.github.com/ebautistabar/cc ... 15f53fac4a
Usually it only works if the amount of files is limited.
