extracting SMART parameters into a file
#1 Post by recuperation »
Use smartmontools on a working system or by running Knoppix from DVD or a USB stick if your installation broke down.
Gparted Live and SystemrescueCD already contain smartmontools as well. If you have an internet connection you can run Linuxmint, too. When keying in "smartctl" Linuxmint tells you the command how to install smartmontools.
Smartmontools is a free and open source software that deals with the health information of drives.
On windows installations of smartmontools you can find a menu entry to update the database. Running that updates could resolve issues with some unknown attributes in newer drives.
Create a report of the SMART parameters running
smartctl -a /dev/sdx > myreport.txt
at the command prompt.
Under Windows you probably need admin rights to run that command.
Under Linux some distributions migh require you to put a "sudo" in front of the command:
sudo smartctl -a /dev/sdx > myreport.txt
Replace the "x" in "sdx" by the drive letter (a small letter!) of your HDD in question. Post the log in your forum thread using the attachment tab on the bottom of the page.
Hint for beginners:
The linux drive names a,b,c,... in a device name like /dev/sdb correspond to complete disk drives, not to Windows drive letters like "a:" for floppy or "c:" which is typically a partition on a hard drive.
When running smartmontools under Windows, use the disk management function. Your disks are listed with numbers in ascending order (drive 0, drive 1, drive 2). Normally drive 0 corresponds to /dev/sda, drive 1 corresponds to /dev/sdb....
When unsure, look at the log, smartmontools provides you with the maker, the model and the serial number of the drive that it is reporting about.
External drives may require some variations of the command.
If smartctl fails, use the additional parameter "-d sat,12" or "-d sat,16".
Example:
smartctl -a -d sat,12 /dev/sdx > myreport.txt
Other variants of the -"d"-parameter are outlined here:
https://www.smartmontools.org/browser/t ... rtctl.8.in
On older systems it may be necessary to adress the drives a little bit differently:
smartctl -a /dev/hdx > myreport.txt
additional help for starters:
In windows you would use the Windows Explorer to navigate to where the folder "smartmontools" is located which contains the file "smartctl.exe".
You can reach the command window (at least in Windows 7) by keying "cmd" into the address line of your explorer.
Then an additional command prompt windows pops up.
When running dir s* the file "smartctl.exe" should be visible.
Then you enter the command in bold letters above.
Updated 6.5.2023
