Copy files with TestDisk transfers huge amounts of data for days Topic is solved
jassenjj
#1 Post by jassenjj »
Hello!
TestDisk 7.2-WIP, Windows 10
The situation is this: a hard drive became unreadable under Windows 10, it started to slow down the boot and Windows Explorer started to take forever to list the drives in the system. Chkdsk did something and afterwards the drive appeared, but on open it said "Access denied" as if it was marked as broken.
Then TestDisk turned out to be a life saver. It found the partition, recognized the file structure and I decided to copy the contents to another drive. It all started perfectly, many gigabytes of files were saved but I noticed that some big files (1-4 GB) recover after a very long time while the read and write speeds are >90 MB/s in Resource Monitor.
Then finally TestDisk reached an 11GB file. It now reads and writes with an average speed of 100 MB/s for 16 hours. I guess TestDisk is "trying" to put file together, but is this OK?
I am actually curious what TestDisk is doing with this file. With that speed it has practically read/written tens of terrabytes of data already just for 1 file of 11GB.
Here are the details from the log (unnecessary info marked with "XXX"):
Sun Mar 14 12:00:01 2021
TestDisk 7.2-WIP, Data Recovery Utility, February 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=8001563222016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=8001563222016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=448995937792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4000768327680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500104691712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8001545043968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000263577600
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - XXX
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - XXX
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - SAMSUNG HD204UI, S/N:S2H7J9KB617136, FW:1AQ10001
Disk /dev/sdd - 8001 GB / 7452 GiB - CHS 972801 255 63, sector size=512 - XXX
Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - XXX
Disk /dev/sdc - 2000 GB / 1863 GiB - SAMSUNG HD204UI
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907029167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=3907029168
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=3907029167
hdr_lba_alt=1 (expected 1)
hdr_lba_start=34
hdr_lba_table=3907029135
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
Bad GPT partition, invalid header checksum.
Trying alternate GPT
 2 P MS Data                   264192 3907028991 3906764800 [Basic data partition] [T2]
NTFS at 16/113/34
filesystem size           3906764800
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=135266304, part_size=2000263577600, sector_size=512
NTFS at 16/113/34
mftmirr_lcn               2
file_pread(6,16,buffer,6555654(408/18/1)) ReadFile Data error (cyclic redundancy check).
     MS Data                   264192 3907028991 3906764800 [T2]
     NTFS, blocksize=4096, 2000 GB / 1862 GiB
file_pread(6,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(6,1,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(6,2,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(6,1,buffer,3907031043(243201/110/49)) lseek err Invalid argument
file_pread(6,1,buffer,3907031044(243201/110/50)) lseek err Invalid argument
file_pread(6,1,buffer,3907031045(243201/110/51)) lseek err Invalid argument
file_pread(6,1,buffer,3907031046(243201/110/52)) lseek err Invalid argument
file_pread(6,1,buffer,3907031047(243201/110/53)) lseek err Invalid argument
file_pread(6,1,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(6,1,buffer,3907031049(243201/110/55)) lseek err Invalid argument
file_pread(6,1,buffer,3907031050(243201/110/56)) lseek err Invalid argument
file_pread(6,1,buffer,3907031051(243201/110/57)) lseek err Invalid argument
file_pread(6,1,buffer,3907031052(243201/110/58)) lseek err Invalid argument
file_pread(6,1,buffer,3907031053(243201/110/59)) lseek err Invalid argument
file_pread(6,1,buffer,3907031054(243201/110/60)) lseek err Invalid argument
file_pread(6,1,buffer,3907031055(243201/110/61)) lseek err Invalid argument
file_pread(6,1,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(6,1,buffer,3907031057(243201/110/63)) lseek err Invalid argument
file_pread(6,1,buffer,3907031058(243201/111/1)) lseek err Invalid argument
file_pread(6,1,buffer,3907031059(243201/111/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907031060(243201/111/3)) lseek err Invalid argument
file_pread(6,1,buffer,3907031061(243201/111/4)) lseek err Invalid argument
file_pread(6,1,buffer,3907031062(243201/111/5)) lseek err Invalid argument
file_pread(6,1,buffer,3907031063(243201/111/6)) lseek err Invalid argument
file_pread(6,1,buffer,3907031064(243201/111/7)) lseek err Invalid argument
file_pread(6,1,buffer,3907031065(243201/111/8)) lseek err Invalid argument
file_pread(6,1,buffer,3907031066(243201/111/9)) lseek err Invalid argument
file_pread(6,1,buffer,3907031067(243201/111/10)) lseek err Invalid argument
file_pread(6,1,buffer,3907031068(243201/111/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907031069(243201/111/12)) lseek err Invalid argument
file_pread(6,1,buffer,3907031070(243201/111/13)) lseek err Invalid argument
file_pread(6,1,buffer,3907031071(243201/111/14)) lseek err Invalid argument
file_pread(6,1,buffer,3907031072(243201/111/15)) lseek err Invalid argument
file_pread(6,1,buffer,3907031073(243201/111/16)) lseek err Invalid argument
file_pread(6,1,buffer,3907031074(243201/111/17)) lseek err Invalid argument
file_pread(6,1,buffer,3907031075(243201/111/18)) lseek err Invalid argument
file_pread(6,1,buffer,3907031076(243201/111/19)) lseek err Invalid argument
file_pread(6,1,buffer,3907031077(243201/111/20)) lseek err Invalid argument
file_pread(6,1,buffer,3907031078(243201/111/21)) lseek err Invalid argument
file_pread(6,1,buffer,3907031079(243201/111/22)) lseek err Invalid argument
file_pread(6,1,buffer,3907031080(243201/111/23)) lseek err Invalid argument
file_pread(6,1,buffer,3907029168(243201/81/1)) ReadFile Incorrect function.
file_pread(6,1,buffer,3907031081(243201/111/24)) lseek err Invalid argument
file_pread(6,1,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907031082(243201/111/25)) lseek err Invalid argument
file_pread(6,1,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(6,1,buffer,3907031083(243201/111/26)) lseek err Invalid argument
file_pread(6,11,buffer,3907029161(243201/80/57)) ReadFile Incorrect function.
file_pread(6,1,buffer,3907031084(243201/111/27)) lseek err Invalid argument
file_pread(6,4,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907031085(243201/111/28)) lseek err Invalid argument
file_pread(6,1,buffer,3907029173(243201/81/6)) lseek err Invalid argument
file_pread(6,1,buffer,3907031086(243201/111/29)) lseek err Invalid argument
file_pread(6,1,buffer,3907029174(243201/81/7)) lseek err Invalid argument
file_pread(6,1,buffer,3907031087(243201/111/30)) lseek err Invalid argument
file_pread(6,1,buffer,3907029175(243201/81/8)) lseek err Invalid argument
file_pread(6,1,buffer,3907031088(243201/111/31)) lseek err Invalid argument
file_pread(6,11,buffer,3907029166(243201/80/62)) ReadFile Incorrect function.
file_pread(6,1,buffer,3907031089(243201/111/32)) lseek err Invalid argument
file_pread(6,1,buffer,3907029177(243201/81/10)) lseek err Invalid argument
file_pread(6,1,buffer,3907031090(243201/111/33)) lseek err Invalid argument
file_pread(6,1,buffer,3907029178(243201/81/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907031091(243201/111/34)) lseek err Invalid argument
file_pread(6,1,buffer,3907029179(243201/81/12)) lseek err Invalid argument
file_pread(6,1,buffer,3907031092(243201/111/35)) lseek err Invalid argument
file_pread(6,1,buffer,3907029180(243201/81/13)) lseek err Invalid argument
file_pread(6,1,buffer,3907031093(243201/111/36)) lseek err Invalid argument
file_pread(6,1,buffer,3907029181(243201/81/14)) lseek err Invalid argument
file_pread(6,1,buffer,3907031094(243201/111/37)) lseek err Invalid argument
file_pread(6,11,buffer,3907029172(243201/81/5)) lseek err Invalid argument
file_pread(6,1,buffer,3907031095(243201/111/38)) lseek err Invalid argument
file_pread(6,1,buffer,3907029183(243201/81/16)) lseek err Invalid argument
file_pread(6,1,buffer,3907031096(243201/111/39)) lseek err Invalid argument
file_pread(6,1,buffer,3907029184(243201/81/17)) lseek err Invalid argument
file_pread(6,1,buffer,3907031097(243201/111/40)) lseek err Invalid argument
file_pread(6,1,buffer,3907029185(243201/81/18)) lseek err Invalid argument
file_pread(6,1,buffer,3907031098(243201/111/41)) lseek err Invalid argument
file_pread(6,1,buffer,3907029186(243201/81/19)) lseek err Invalid argument
file_pread(6,1,buffer,3907031099(243201/111/42)) lseek err Invalid argument
file_pread(6,1,buffer,3907029187(243201/81/20)) lseek err Invalid argument
file_pread(6,1,buffer,3907031100(243201/111/43)) lseek err Invalid argument
file_pread(6,11,buffer,3907029178(243201/81/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907031101(243201/111/44)) lseek err Invalid argument
file_pread(6,11,buffer,3907029179(243201/81/12)) lseek err Invalid argument
file_pread(6,1,buffer,3907031102(243201/111/45)) lseek err Invalid argument
file_pread(6,1,buffer,3907029190(243201/81/23)) lseek err Invalid argument
file_pread(6,1,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(6,1,buffer,3907029191(243201/81/24)) lseek err Invalid argument
file_pread(6,1,buffer,3907031104(243201/111/47)) lseek err Invalid argument
file_pread(6,1,buffer,3907029192(243201/81/25)) lseek err Invalid argument
file_pread(6,1,buffer,3907031105(243201/111/48)) lseek err Invalid argument
file_pread(6,1,buffer,3907029193(243201/81/26)) lseek err Invalid argument
file_pread(6,1,buffer,3907031106(243201/111/49)) lseek err Invalid argument
file_pread(6,1,buffer,3907029194(243201/81/27)) lseek err Invalid argument
file_pread(6,1,buffer,3907031107(243201/111/50)) lseek err Invalid argument
file_pread(6,11,buffer,3907029185(243201/81/18)) lseek err Invalid argument
file_pread(6,1,buffer,3907031108(243201/111/51)) lseek err Invalid argument
file_pread(6,1,buffer,3907029196(243201/81/29)) lseek err Invalid argument
file_pread(6,1,buffer,3907031109(243201/111/52)) lseek err Invalid argument
file_pread(6,1,buffer,3907029197(243201/81/30)) lseek err Invalid argument
file_pread(6,1,buffer,3907031110(243201/111/53)) lseek err Invalid argument
file_pread(6,1,buffer,3907029198(243201/81/31)) lseek err Invalid argument
file_pread(6,1,buffer,3907031111(243201/111/54)) lseek err Invalid argument
file_pread(6,1,buffer,3907029199(243201/81/32)) lseek err Invalid argument
file_pread(6,1,buffer,3907031112(243201/111/55)) lseek err Invalid argument
file_pread(6,1,buffer,3907029200(243201/81/33)) lseek err Invalid argument
file_pread(6,1,buffer,3907031113(243201/111/56)) lseek err Invalid argument
file_pread(6,11,buffer,3907029191(243201/81/24)) lseek err Invalid argument
file_pread(6,1,buffer,3907031114(243201/111/57)) lseek err Invalid argument
file_pread(6,11,buffer,3907029192(243201/81/25)) lseek err Invalid argument
file_pread(6,1,buffer,3907031115(243201/111/58)) lseek err Invalid argument
file_pread(6,1,buffer,3907029203(243201/81/36)) lseek err Invalid argument
file_pread(6,1,buffer,3907031116(243201/111/59)) lseek err Invalid argument
file_pread(6,1,buffer,3907029204(243201/81/37)) lseek err Invalid argument
file_pread(6,1,buffer,3907031117(243201/111/60)) lseek err Invalid argument
file_pread(6,1,buffer,3907029205(243201/81/38)) lseek err Invalid argument
file_pread(6,1,buffer,3907031118(243201/111/61)) lseek err Invalid argument
file_pread(6,1,buffer,3907029206(243201/81/39)) lseek err Invalid argument
file_pread(6,1,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(6,1,buffer,3907029207(243201/81/40)) lseek err Invalid argument
file_pread(6,1,buffer,3907031120(243201/111/63)) lseek err Invalid argument
file_pread(6,11,buffer,3907029198(243201/81/31)) lseek err Invalid argument
file_pread(6,1,buffer,3907031121(243201/112/1)) lseek err Invalid argument
file_pread(6,1,buffer,3907029209(243201/81/42)) lseek err Invalid argument
file_pread(6,1,buffer,3907031122(243201/112/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907029210(243201/81/43)) lseek err Invalid argument
file_pread(6,1,buffer,3907031123(243201/112/3)) lseek err Invalid argument
file_pread(6,1,buffer,3907029211(243201/81/44)) lseek err Invalid argument
file_pread(6,1,buffer,3907031124(243201/112/4)) lseek err Invalid argument
file_pread(6,1,buffer,3907029212(243201/81/45)) lseek err Invalid argument
file_pread(6,1,buffer,3907031125(243201/112/5)) lseek err Invalid argument
file_pread(6,1,buffer,3907029213(243201/81/46)) lseek err Invalid argument
file_pread(6,1,buffer,3907031126(243201/112/6)) lseek err Invalid argument
file_pread(6,11,buffer,3907029204(243201/81/37)) lseek err Invalid argument
file_pread(6,1,buffer,3907031127(243201/112/7)) lseek err Invalid argument
file_pread(6,11,buffer,3907029205(243201/81/38)) lseek err Invalid argument
file_pread(6,1,buffer,3907031128(243201/112/8)) lseek err Invalid argument
file_pread(6,11,buffer,3907029206(243201/81/39)) lseek err Invalid argument
file_pread(6,1,buffer,3907031129(243201/112/9)) lseek err Invalid argument
file_pread(6,11,buffer,3907029207(243201/81/40)) lseek err Invalid argument
file_pread(6,1,buffer,3907031130(243201/112/10)) lseek err Invalid argument
file_pread(6,8,buffer,3907029161(243201/80/57)) ReadFile Incorrect function.
file_pread(6,11,buffer,3907029208(243201/81/41)) lseek err Invalid argument
file_pread(6,1,buffer,3907031131(243201/112/11)) lseek err Invalid argument
file_pread(6,3,buffer,3907029167(243201/80/63)) ReadFile Incorrect function.
file_pread(6,1,buffer,3907029219(243201/81/52)) lseek err Invalid argument
file_pread(6,1,buffer,3907031132(243201/112/12)) lseek err Invalid argument
file_pread(6,1,buffer,3907029220(243201/81/53)) lseek err Invalid argument
file_pread(6,1,buffer,3907031133(243201/112/13)) lseek err Invalid argument
file_pread(6,1,buffer,3907029171(243201/81/4)) lseek err Invalid argument
file_pread(6,1,buffer,3907029221(243201/81/54)) lseek err Invalid argument
file_pread(6,1,buffer,3907031134(243201/112/14)) lseek err Invalid argument
file_pread(6,8,buffer,3907029165(243201/80/61)) ReadFile Incorrect function.
file_pread(6,1,buffer,3907029222(243201/81/55)) lseek err Invalid argument
file_pread(6,1,buffer,3907031135(243201/112/15)) lseek err Invalid argument
file_pread(6,11,buffer,3907029213(243201/81/46)) lseek err Invalid argument
file_pread(6,1,buffer,3907031136(243201/112/16)) lseek err Invalid argument
file_pread(6,1,buffer,3907029224(243201/81/57)) lseek err Invalid argument
file_pread(6,1,buffer,3907031137(243201/112/17)) lseek err Invalid argument
file_pread(6,1,buffer,3907029225(243201/81/58)) lseek err Invalid argument
file_pread(6,1,buffer,3907031138(243201/112/18)) lseek err Invalid argument
file_pread(6,1,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(6,1,buffer,3907029226(243201/81/59)) lseek err Invalid argument
file_pread(6,1,buffer,3907031139(243201/112/19)) lseek err Invalid argument
file_pread(6,8,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(6,11,buffer,3907029217(243201/81/50)) lseek err Invalid argument
file_pread(6,1,buffer,3907031140(243201/112/20)) lseek err Invalid argument
file_pread(6,8,buffer,3907029171(243201/81/4)) lseek err Invalid argument
file_pread(6,1,buffer,3907029228(243201/81/61)) lseek err Invalid argument
file_pread(6,1,buffer,3907031141(243201/112/21)) lseek err Invalid argument
file_pread(6,8,buffer,3907029172(243201/81/5)) lseek err Invalid argument
file_pread(6,1,buffer,3907029172(243201/81/5)) lseek err Invalid argument
file_pread(6,1,buffer,3907029229(243201/81/62)) lseek err Invalid argument
file_pread(6,1,buffer,3907031142(243201/112/22)) lseek err Invalid argument
file_pread(6,8,buffer,3907029173(243201/81/6)) lseek err Invalid argument
file_pread(6,11,buffer,3907029220(243201/81/53)) lseek err Invalid argument
file_pread(6,1,buffer,3907031143(243201/112/23)) lseek err Invalid argument
file_pread(6,8,buffer,3907029174(243201/81/7)) lseek err Invalid argument
file_pread(6,1,buffer,3907029231(243201/82/1)) lseek err Invalid argument
file_pread(6,1,buffer,3907031144(243201/112/24)) lseek err Invalid argument
file_pread(6,8,buffer,3907029175(243201/81/8)) lseek err Invalid argument
file_pread(6,1,buffer,3907029232(243201/82/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907031145(243201/112/25)) lseek err Invalid argument
file_pread(6,8,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(6,11,buffer,3907029223(243201/81/56)) lseek err Invalid argument
file_pread(6,1,buffer,3907031146(243201/112/26)) lseek err Invalid argument
file_pread(6,8,buffer,3907029177(243201/81/10)) lseek err Invalid argument
file_pread(6,1,buffer,3907029234(243201/82/4)) lseek err Invalid argument
file_pread(6,1,buffer,3907031147(243201/112/27)) lseek err Invalid argument
file_pread(6,8,buffer,3907029178(243201/81/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907029235(243201/82/5)) lseek err Invalid argument
file_pread(6,1,buffer,3907031148(243201/112/28)) lseek err Invalid argument
file_pread(6,8,buffer,3907029179(243201/81/12)) lseek err Invalid argument
file_pread(6,11,buffer,3907029226(243201/81/59)) lseek err Invalid argument
file_pread(6,1,buffer,3907031149(243201/112/29)) lseek err Invalid argument
file_pread(6,8,buffer,3907029180(243201/81/13)) lseek err Invalid argument
file_pread(6,1,buffer,3907029237(243201/82/7)) lseek err Invalid argument
file_pread(6,1,buffer,3907031150(243201/112/30)) lseek err Invalid argument
file_pread(6,8,buffer,3907029181(243201/81/14)) lseek err Invalid argument
file_pread(6,1,buffer,3907029238(243201/82/8)) lseek err Invalid argument
file_pread(6,1,buffer,3907031151(243201/112/31)) lseek err Invalid argument
file_pread(6,8,buffer,3907029182(243201/81/15)) lseek err Invalid argument
file_pread(6,11,buffer,3907029229(243201/81/62)) lseek err Invalid argument
file_pread(6,1,buffer,3907031152(243201/112/32)) lseek err Invalid argument
file_pread(6,1,buffer,3907029240(243201/82/10)) lseek err Invalid argument
file_pread(6,1,buffer,3907031153(243201/112/33)) lseek err Invalid argument
file_pread(6,1,buffer,3907029241(243201/82/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907031154(243201/112/34)) lseek err Invalid argument
file_pread(6,1,buffer,3907029242(243201/82/12)) lseek err Invalid argument
file_pread(6,1,buffer,3907031155(243201/112/35)) lseek err Invalid argument
file_pread(6,8,buffer,3907029186(243201/81/19)) lseek err Invalid argument
file_pread(6,11,buffer,3907029233(243201/82/3)) lseek err Invalid argument
file_pread(6,1,buffer,3907031156(243201/112/36)) lseek err Invalid argument
file_pread(6,1,buffer,3907029244(243201/82/14)) lseek err Invalid argument
file_pread(6,1,buffer,3907031157(243201/112/37)) lseek err Invalid argument
file_pread(6,1,buffer,3907029195(243201/81/28)) lseek err Invalid argument
file_pread(6,1,buffer,3907029245(243201/82/15)) lseek err Invalid argument
file_pread(6,1,buffer,3907031158(243201/112/38)) lseek err Invalid argument
file_pread(6,1,buffer,3907029246(243201/82/16)) lseek err Invalid argument
file_pread(6,1,buffer,3907031159(243201/112/39)) lseek err Invalid argument
file_pread(6,8,buffer,3907029190(243201/81/23)) lseek err Invalid argument
file_pread(6,11,buffer,3907029237(243201/82/7)) lseek err Invalid argument
file_pread(6,1,buffer,3907031160(243201/112/40)) lseek err Invalid argument
file_pread(6,1,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(6,1,buffer,3907031161(243201/112/41)) lseek err Invalid argument
file_pread(6,1,buffer,3907029249(243201/82/19)) lseek err Invalid argument
file_pread(6,1,buffer,3907031162(243201/112/42)) lseek err Invalid argument
file_pread(6,1,buffer,3907029250(243201/82/20)) lseek err Invalid argument
file_pread(6,1,buffer,3907031163(243201/112/43)) lseek err Invalid argument
file_pread(6,8,buffer,3907029194(243201/81/27)) lseek err Invalid argument
file_pread(6,11,buffer,3907029241(243201/82/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907031164(243201/112/44)) lseek err Invalid argument
file_pread(6,1,buffer,3907029202(243201/81/35)) lseek err Invalid argument
file_pread(6,1,buffer,3907029252(243201/82/22)) lseek err Invalid argument
file_pread(6,1,buffer,3907031165(243201/112/45)) lseek err Invalid argument
file_pread(6,1,buffer,3907029182(243201/81/15)) lseek err Invalid argument
file_pread(6,1,buffer,3907029253(243201/82/23)) lseek err Invalid argument
file_pread(6,1,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(6,1,buffer,3907029254(243201/82/24)) lseek err Invalid argument
file_pread(6,1,buffer,3907031167(243201/112/47)) lseek err Invalid argument
file_pread(6,8,buffer,3907029198(243201/81/31)) lseek err Invalid argument
file_pread(6,11,buffer,3907029245(243201/82/15)) lseek err Invalid argument
file_pread(6,1,buffer,3907031168(243201/112/48)) lseek err Invalid argument
file_pread(6,1,buffer,3907029256(243201/82/26)) lseek err Invalid argument
file_pread(6,1,buffer,3907031169(243201/112/49)) lseek err Invalid argument
file_pread(6,1,buffer,3907029257(243201/82/27)) lseek err Invalid argument
file_pread(6,1,buffer,3907031170(243201/112/50)) lseek err Invalid argument
file_pread(6,1,buffer,3907029208(243201/81/41)) lseek err Invalid argument
file_pread(6,1,buffer,3907029258(243201/82/28)) lseek err Invalid argument
file_pread(6,1,buffer,3907031171(243201/112/51)) lseek err Invalid argument
file_pread(6,1,buffer,3907029188(243201/81/21)) lseek err Invalid argument
file_pread(6,8,buffer,3907029202(243201/81/35)) lseek err Invalid argument
file_pread(6,11,buffer,3907029249(243201/82/19)) lseek err Invalid argument
file_pread(6,1,buffer,3907031172(243201/112/52)) lseek err Invalid argument
file_pread(6,1,buffer,3907029189(243201/81/22)) lseek err Invalid argument
file_pread(6,1,buffer,3907029260(243201/82/30)) lseek err Invalid argument
file_pread(6,1,buffer,3907031173(243201/112/53)) lseek err Invalid argument
file_pread(6,1,buffer,3907029261(243201/82/31)) lseek err Invalid argument
file_pread(6,1,buffer,3907031174(243201/112/54)) lseek err Invalid argument
file_pread(6,1,buffer,3907029262(243201/82/32)) lseek err Invalid argument
file_pread(6,1,buffer,3907031175(243201/112/55)) lseek err Invalid argument
file_pread(6,8,buffer,3907029206(243201/81/39)) lseek err Invalid argument
file_pread(6,11,buffer,3907029253(243201/82/23)) lseek err Invalid argument
file_pread(6,1,buffer,3907031176(243201/112/56)) lseek err Invalid argument
file_pread(6,1,buffer,3907029214(243201/81/47)) lseek err Invalid argument
file_pread(6,1,buffer,3907029264(243201/82/34)) lseek err Invalid argument
file_pread(6,1,buffer,3907031177(243201/112/57)) lseek err Invalid argument
file_pread(6,1,buffer,3907029215(243201/81/48)) lseek err Invalid argument
file_pread(6,1,buffer,3907029265(243201/82/35)) lseek err Invalid argument
file_pread(6,1,buffer,3907031178(243201/112/58)) lseek err Invalid argument
file_pread(6,1,buffer,3907029216(243201/81/49)) lseek err Invalid argument
file_pread(6,1,buffer,3907029266(243201/82/36)) lseek err Invalid argument
file_pread(6,1,buffer,3907031179(243201/112/59)) lseek err Invalid argument
file_pread(6,8,buffer,3907029210(243201/81/43)) lseek err Invalid argument
file_pread(6,11,buffer,3907029257(243201/82/27)) lseek err Invalid argument
file_pread(6,1,buffer,3907031180(243201/112/60)) lseek err Invalid argument
file_pread(6,1,buffer,3907029218(243201/81/51)) lseek err Invalid argument
file_pread(6,1,buffer,3907029268(243201/82/38)) lseek err Invalid argument
file_pread(6,1,buffer,3907031181(243201/112/61)) lseek err Invalid argument
file_pread(6,1,buffer,3907029269(243201/82/39)) lseek err Invalid argument
file_pread(6,1,buffer,3907031182(243201/112/62)) lseek err Invalid argument
file_pread(6,1,buffer,3907029270(243201/82/40)) lseek err Invalid argument
file_pread(6,1,buffer,3907031183(243201/112/63)) lseek err Invalid argument
file_pread(6,8,buffer,3907029214(243201/81/47)) lseek err Invalid argument
file_pread(6,11,buffer,3907029261(243201/82/31)) lseek err Invalid argument
file_pread(6,1,buffer,3907031184(243201/113/1)) lseek err Invalid argument
file_pread(6,1,buffer,3907029201(243201/81/34)) lseek err Invalid argument
file_pread(6,1,buffer,3907029272(243201/82/42)) lseek err Invalid argument
file_pread(6,1,buffer,3907031185(243201/113/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907029223(243201/81/56)) lseek err Invalid argument
file_pread(6,1,buffer,3907029273(243201/82/43)) lseek err Invalid argument
file_pread(6,1,buffer,3907031186(243201/113/3)) lseek err Invalid argument
file_pread(6,1,buffer,3907029274(243201/82/44)) lseek err Invalid argument
file_pread(6,1,buffer,3907031187(243201/113/4)) lseek err Invalid argument
file_pread(6,8,buffer,3907029218(243201/81/51)) lseek err Invalid argument
file_pread(6,11,buffer,3907029265(243201/82/35)) lseek err Invalid argument
file_pread(6,1,buffer,3907031188(243201/113/5)) lseek err Invalid argument
file_pread(6,1,buffer,3907029276(243201/82/46)) lseek err Invalid argument
file_pread(6,1,buffer,3907031189(243201/113/6)) lseek err Invalid argument
file_pread(6,1,buffer,3907029227(243201/81/60)) lseek err Invalid argument
file_pread(6,1,buffer,3907029277(243201/82/47)) lseek err Invalid argument
file_pread(6,1,buffer,3907031190(243201/113/7)) lseek err Invalid argument
file_pread(6,8,buffer,3907029221(243201/81/54)) lseek err Invalid argument
file_pread(6,11,buffer,3907029268(243201/82/38)) lseek err Invalid argument
file_pread(6,1,buffer,3907031191(243201/113/8)) lseek err Invalid argument
file_pread(6,1,buffer,3907029279(243201/82/49)) lseek err Invalid argument
file_pread(6,1,buffer,3907031192(243201/113/9)) lseek err Invalid argument
file_pread(6,1,buffer,3907029230(243201/81/63)) lseek err Invalid argument
file_pread(6,1,buffer,3907029280(243201/82/50)) lseek err Invalid argument
file_pread(6,1,buffer,3907031193(243201/113/10)) lseek err Invalid argument
file_pread(6,8,buffer,3907029224(243201/81/57)) lseek err Invalid argument
file_pread(6,11,buffer,3907029271(243201/82/41)) lseek err Invalid argument
file_pread(6,1,buffer,3907031194(243201/113/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907029282(243201/82/52)) lseek err Invalid argument
file_pread(6,1,buffer,3907031195(243201/113/12)) lseek err Invalid argument
file_pread(6,1,buffer,3907029233(243201/82/3)) lseek err Invalid argument
file_pread(6,1,buffer,3907029283(243201/82/53)) lseek err Invalid argument
file_pread(6,1,buffer,3907031196(243201/113/13)) lseek err Invalid argument
file_pread(6,8,buffer,3907029227(243201/81/60)) lseek err Invalid argument
file_pread(6,11,buffer,3907029274(243201/82/44)) lseek err Invalid argument
file_pread(6,1,buffer,3907031197(243201/113/14)) lseek err Invalid argument
file_pread(6,1,buffer,3907029285(243201/82/55)) lseek err Invalid argument
file_pread(6,1,buffer,3907031198(243201/113/15)) lseek err Invalid argument
file_pread(6,1,buffer,3907029236(243201/82/6)) lseek err Invalid argument
file_pread(6,1,buffer,3907029286(243201/82/56)) lseek err Invalid argument
file_pread(6,1,buffer,3907031199(243201/113/16)) lseek err Invalid argument
file_pread(6,8,buffer,3907029230(243201/81/63)) lseek err Invalid argument
file_pread(6,11,buffer,3907029277(243201/82/47)) lseek err Invalid argument
file_pread(6,1,buffer,3907031200(243201/113/17)) lseek err Invalid argument
file_pread(6,1,buffer,3907029217(243201/81/50)) lseek err Invalid argument
file_pread(6,1,buffer,3907029288(243201/82/58)) lseek err Invalid argument
file_pread(6,1,buffer,3907031201(243201/113/18)) lseek err Invalid argument
file_pread(6,1,buffer,3907029239(243201/82/9)) lseek err Invalid argument
file_pread(6,1,buffer,3907029289(243201/82/59)) lseek err Invalid argument
file_pread(6,1,buffer,3907031202(243201/113/19)) lseek err Invalid argument
file_pread(6,14,buffer,3907029156(243201/80/52)) ReadFile Incorrect function.
file_pread(6,3,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(6,3,buffer,3907029217(243201/81/50)) lseek err Invalid argument
file_pread(6,8,buffer,3907029233(243201/82/3)) lseek err Invalid argument
file_pread(6,11,buffer,3907029280(243201/82/50)) lseek err Invalid argument
file_pread(6,2,buffer,3907031202(243201/113/19)) lseek err Invalid argument
file_pread(6,14,buffer,3907029157(243201/80/53)) ReadFile Incorrect function.
file_pread(6,2,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,3,buffer,3907029171(243201/81/4)) lseek err Invalid argument
file_pread(6,3,buffer,3907029218(243201/81/51)) lseek err Invalid argument
file_pread(6,8,buffer,3907029234(243201/82/4)) lseek err Invalid argument
file_pread(6,11,buffer,3907029281(243201/82/51)) lseek err Invalid argument
file_pread(6,2,buffer,3907031203(243201/113/20)) lseek err Invalid argument
file_pread(6,14,buffer,3907029158(243201/80/54)) ReadFile Incorrect function.
file_pread(6,3,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,3,buffer,3907029172(243201/81/5)) lseek err Invalid argument
file_pread(6,3,buffer,3907029219(243201/81/52)) lseek err Invalid argument
file_pread(6,8,buffer,3907029235(243201/82/5)) lseek err Invalid argument
file_pread(6,11,buffer,3907029282(243201/82/52)) lseek err Invalid argument
file_pread(6,2,buffer,3907031204(243201/113/21)) lseek err Invalid argument
file_pread(6,14,buffer,3907029159(243201/80/55)) ReadFile Incorrect function.
file_pread(6,3,buffer,3907029173(243201/81/6)) lseek err Invalid argument
file_pread(6,3,buffer,3907029220(243201/81/53)) lseek err Invalid argument
file_pread(6,8,buffer,3907029236(243201/82/6)) lseek err Invalid argument
file_pread(6,11,buffer,3907029283(243201/82/53)) lseek err Invalid argument
file_pread(6,2,buffer,3907031205(243201/113/22)) lseek err Invalid argument
file_pread(6,14,buffer,3907029160(243201/80/56)) ReadFile Incorrect function.
file_pread(6,5,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,3,buffer,3907029174(243201/81/7)) lseek err Invalid argument
file_pread(6,3,buffer,3907029221(243201/81/54)) lseek err Invalid argument
file_pread(6,8,buffer,3907029237(243201/82/7)) lseek err Invalid argument
file_pread(6,11,buffer,3907029284(243201/82/54)) lseek err Invalid argument
file_pread(6,2,buffer,3907031206(243201/113/23)) lseek err Invalid argument
file_pread(6,1,buffer,3907029295(243201/83/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907031208(243201/113/25)) lseek err Invalid argument
file_pread(6,14,buffer,3907029162(243201/80/58)) ReadFile Incorrect function.
file_pread(6,7,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,3,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(6,3,buffer,3907029223(243201/81/56)) lseek err Invalid argument
file_pread(6,8,buffer,3907029239(243201/82/9)) lseek err Invalid argument
file_pread(6,11,buffer,3907029286(243201/82/56)) lseek err Invalid argument
file_pread(6,1,buffer,3907031209(243201/113/26)) lseek err Invalid argument
file_pread(6,1,buffer,3907029247(243201/82/17)) lseek err Invalid argument
file_pread(6,1,buffer,3907029297(243201/83/4)) lseek err Invalid argument
file_pread(6,1,buffer,3907031210(243201/113/27)) lseek err Invalid argument
file_pread(6,14,buffer,3907029164(243201/80/60)) ReadFile Incorrect function.
file_pread(6,3,buffer,3907029178(243201/81/11)) lseek err Invalid argument
file_pread(6,3,buffer,3907029225(243201/81/58)) lseek err Invalid argument
file_pread(6,8,buffer,3907029241(243201/82/11)) lseek err Invalid argument
file_pread(6,11,buffer,3907029288(243201/82/58)) lseek err Invalid argument
file_pread(6,1,buffer,3907031211(243201/113/28)) lseek err Invalid argument
file_pread(6,10,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907029299(243201/83/6)) lseek err Invalid argument
file_pread(6,1,buffer,3907031212(243201/113/29)) lseek err Invalid argument
file_pread(6,14,buffer,3907029166(243201/80/62)) ReadFile Incorrect function.
file_pread(6,3,buffer,3907029180(243201/81/13)) lseek err Invalid argument
file_pread(6,3,buffer,3907029227(243201/81/60)) lseek err Invalid argument
file_pread(6,8,buffer,3907029243(243201/82/13)) lseek err Invalid argument
file_pread(6,11,buffer,3907029290(243201/82/60)) lseek err Invalid argument
file_pread(6,1,buffer,3907031213(243201/113/30)) lseek err Invalid argument
file_pread(6,12,buffer,3907029169(243201/81/2)) lseek err Invalid argument
file_pread(6,1,buffer,3907029251(243201/82/21)) lseek err Invalid argument
file_pread(6,1,buffer,3907029301(243201/83/8)) lseek err Invalid argument
file_pread(6,1,buffer,3907031214(243201/113/31)) lseek err Invalid argument
file_pread(6,1,buffer,3907029302(243201/83/9)) lseek err Invalid argument
file_pread(6,1,buffer,3907031215(243201/113/32)) lseek err Invalid argument
file_pread(6,2,buffer,3907029181(243201/81/14)) lseek err Invalid argument
file_pread(6,8,buffer,3907029246(243201/82/16)) lseek err Invalid argument
file_pread(6,11,buffer,3907029293(243201/82/63)) lseek err Invalid argument
file_pread(6,1,buffer,3907031216(243201/113/33)) lseek err Invalid argument
file_pread(6,14,buffer,3907029170(243201/81/3)) lseek err Invalid argument
file_pread(6,1,buffer,3907029304(243201/83/11)) lseek err Invalid argument
file_pread(6,1,buffer,3907031217(243201/113/34)) lseek err Invalid argument
   P MS Data                   264192 3907028991 3906764800 [T2]
Re: Copy files with TestDisk transfers huge amounts of data for days
Your description suggests that you a dammaged drive.
Before duplicating the drive using ddrescue you can extract a quick health report as shown below:
viewtopic.php?f=5&t=10910
Please post the report.
jassenjj
#3 Post by jassenjj »
Thanks!
The 11GB-file was restored after 30 hours of linear read with 100 MB/s (while the same write rate was happening on the rescue drive). Then many more files were restored, then another big file was reached :) Hopefully I won't have power cuts until the rest of the month.
smartctl 7.2 2020-12-30 r5155 [x86_64-w64-mingw32-w10-20H2] (sf-7.2-1)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     SAMSUNG SpinPoint F4 EG (AF)
Device Model:     SAMSUNG HD204UI
Serial Number:    S2H7J9KB617136
LU WWN Device Id: 5 0024e9 205882f90
Firmware Version: 1AQ10001
User Capacity:    2 000 398 934 016 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Tue Mar 16 10:31:30 2021 FLEST
==> WARNING: Using smartmontools or hdparm with this
drive may result in data loss due to a firmware bug.
****** THIS DRIVE MAY OR MAY NOT BE AFFECTED! ******
Buggy and fixed firmware report same version number!
See the following web pages for details:
http://knowledge.seagate.com/articles/en_US/FAQ/223571en
https://www.smartmontools.org/wiki/SamsungF4EGBadBlocks
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(19560) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					command.
					Self-test supported.
					No Conveyance Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 326) minutes.
SCT capabilities: 	       (0x003f)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       1923
  2 Throughput_Performance  0x0026   252   252   000    Old_age   Always       -       0
  3 Spin_Up_Time            0x0023   068   045   025    Pre-fail  Always       -       9990
  4 Start_Stop_Count        0x0032   087   087   000    Old_age   Always       -       13559
  5 Reallocated_Sector_Ct   0x0033   252   252   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   252   252   051    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0024   252   252   015    Old_age   Offline      -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       63310
 10 Spin_Retry_Count        0x0032   252   252   051    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       397
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       909
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       18470423
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       2945
192 Power-Off_Retract_Count 0x0022   252   252   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0002   064   056   000    Old_age   Always       -       31 (Min/Max 7/44)
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   252   252   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       2
198 Offline_Uncorrectable   0x0030   252   252   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0036   100   100   000    Old_age   Always       -       30
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       61
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       397
225 Load_Cycle_Count        0x0032   094   094   000    Old_age   Always       -       66878
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Completed [00% left] (0-65535)
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
jassenjj
#4 Post by jassenjj »
Btw the drive is not affected by the reported bug from smartctl. I remember I installed the fix for this drive around 9 years ago, although the production date of the drive is 2011.6 (presumably only drives until Q3 of 2010 were affected) :)
jassenjj
#5 Post by jassenjj »
I have an indisputable happy ending: 143,584 files, 10,943 folder of total of 1.5TB were successfully recovered after 3 days.
Again, my only concern is that after that the drive which was plugged only to be the destination of the copied files has seen an increase of the Total_LBAs_Written of nearly 51858414613 or nearly 30TB of data.
