17.3.2021 20:52 MEZ recuperation: Created separate topic for this posting
I have a similar problem. On my laptop with a 256GB SSD and Win10Pro in the 1st bootable NTFS partition, and data files in the 2nd simple NTFS partition, I installed an antivirus program. After starting the antivirus with a reboot, my C: drive and Win10 crashed. Recovery didn't help. Disk D: remained normal, I did not make a copy of it. I wanted to delete partition C: diskpart> clean, but this command deleted all partitions, cleaned up the entire disk and I was left with no working files.
Directories and files from drive D: I copied using the "hirensbootcd" utility collection (https://www.hirensbootcd.org). One of the utilities sees all partitions and allows you to copy directories and files, but I could not recover. It scanned a 256GB SSD ~ 20 minutes. Try you.
Now I'm trying to recover disk data using the TestDisk program.
diskpart clean + cre par (GPT, exFAT)
