QPhotoRec Nikon RAW .NEF file recovery
halogenbulb
Hi, Great system, however I can't seem to fine this. I know from another recovery app that there are .NEF files that can be recovered. What selection in the File Types (extensions) do I select to extract these. Many Thanks
Re: QPhotoRec Nikon RAW .NEF file recovery
There is no reason to double-post a question by sending a private message!
This contradicts the forum rule that you can read above:
Select TIF.
halogenbulb
Thank you, that worked a treat.
