Recover partition w/files (partition ends after disk limits) Topic is solved
LeonimuZ
#1 Post by LeonimuZ »
UPDATE: DISREGARD. I found a guide deep within this forum. Got my files back now trying to set the HDD back to normal. Thanks!
Original Post:
Hello!, I have been looking on how to solve this for about 24 hours now. Here is my story:
I was deleting a "System Reserved" with Windows Disk Utility because i didn't need it anymore. Oh that went well, i merged it with the other partition, but it still showed as 2 different partitions. I clicked on Delete on the "System Reserved" but it deleted both partitions instead of just the one i didn't want.
Enter testdisk:
Quick scan shows both partitions, but i can only recover the "System Reserved" one (aka the one i don't want) because the main partition "LeonimuZ HDD" because it ends after the limits.
Deep scan showed the same 2 times. The third scan showed me the partition and i could see the files, but I was dumb and didn't copy them in hopes of restoring the partition without copying everything over (my other HD is only 160gb and has Windows installed on it). this never happened again.
This is a non bootable Drive. It used to have Windows 8 on it, but now i'm using it to store all my data. I can use both Windows and Ubuntu to do fixes so pick the one you know best.
I have searched all over the place and have found no precise answer to my conundrum. No other software has been able to find that partition, only testdisk has (open source FTW).
Thanks in advance.
The log with all my attempts:
Tue Aug 21 18:46:23 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
Compilation date: 2012-08-14T11:59:29
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=160039960576
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - FUJITSU MHY2160BH, S/N:344b313137543242553733522020202020202020, FW:890B
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - FUJITSU MHZ2250BH G2, S/N:364b3731385432384a524b4c2020202020202020, FW:8909
Drive C: - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512
Disk /dev/sdb - 250 GB / 232 GiB - FUJITSU MHZ2250BH G2
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Analyse Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63
NTFS at 0/32/33
filesystem size           204800
sectors_per_cluster       8
mft_lcn                   8533
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              0  32 33    12 223 19     204800 [System Reserved]
NTFS at 12/223/20
filesystem size           488390656
mftmirr_lcn               2
     HPFS - NTFS             12 223 20 30413 200 59  488390656 [LeonimuZ HDD]
     NTFS, blocksize=4096, 250 GB / 232 GiB
This partition ends after the disk limits. (start=206848, size=488390656, end=488597503, disk end=488397168)
The harddisk (250 GB / 232 GiB) seems too small! (< 250 GB / 232 GiB)
   * HPFS - NTFS              0  32 33    12 223 19     204800 [System Reserved]
 1 * HPFS - NTFS              0  32 33    12 223 19     204800 [System Reserved]
New options :
 Dump : No
 Expert mode : No
NTFS at 0/32/33
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/20
mftmirr_lcn               2
NTFS at 0/32/33
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/190/50
mftmirr_lcn               2
NTFS part_offset=104857088, part_size=250056015872, sector_size=512
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/20
mftmirr_lcn               2
Using locale 'C.UTF-8'.
Tue Aug 21 19:57:11 2012
Command line: TestDisk /debug /log
