"Can't open filesystem. Filesystem seems damaged" Options after Rebuild BS
slowmotion
#1 Post by slowmotion »
Hello, my secondary internal hard drive stopped working suddenly today. I was able to grab all the files I needed from the harddrive without much difficulty but when I tried to reboot Windows to run chkdsk it could no longer recognise the drive. I've been getting the "Can't open filesystem. Filesystem seems damaged." error on the Drive from Quick Search>List files, although it does at least recognize the one partition of the drive. Based on internet research I figured the next thing to do was run Rebuild BS (both the Boot Sector and Backup boot sector were OK, but it still says "A valid NTFS Boot sector must be present in order to access any data; even if the partition is not bootable"). I left it running for a few hours, but it did not seem to make any difference. I've attached the log here;
Wed Apr 14 22:48:13 2021
TestDisk 7.2-WIP, Data Recovery Utility, March 2021
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240065183744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=10000797794304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592981504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=240065183744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=10000797794304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592981504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239824011264
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=10000795697152
Disk /dev/sda - 240 GB / 223 GiB - CHS 29186 255 63, sector size=512 - SanDisk SSD PLUS 240 GB, S/N:3831333139433038313234382020202020202020, FW:UF3600RL
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-08WN4A0, S/N:2020202057202d44435736433359594134595330, FW:02.01A02
Disk /dev/sdc - 10000 GB / 9313 GiB - CHS 1215861 255 63, sector size=512 - WD Elements 25A3, S/N:4DGY7T6Z, FW:1030
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - Seagate Expansion Desk, S/N:NA8X3E46, FW:0911
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10EZEX-08WN4A0
NTFS at 0/32/33
 1 P HPFS - NTFS              0  32 33 121601  25 24 1953519616
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size           1953519616
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 1014054720
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         2
ntfs_find_mft: mft_record_size     1024
mft at 1033299062
ntfs_find_mft: mft_lcn             2058
ntfs_find_mft: mftmirr_lcn         5162
mft at 1033302166
mft at 1044126070
mft at 1044129174
mft at 1054277152
mft at 1065235296
mft at 1066076064
mft at 1078160160
mft at 1082894752
mft at 1083106528
mft at 1094496320
mft at 1103458640
mft at 1108309216
mft at 1121039072
mft at 1125782400
mft at 1127303730
mft at 1127306834
mft at 1137084192
mft at 1149324848
mft at 1149481440
mft at 1164671232
mft at 1164868544
mft at 1181223920
mft at 1181379904
mft at 1192889038
mft at 1192892142
mft at 1199266098
mft at 1199269202
mft at 1232766976
mft at 1246092288
mft at 1246744608
mft at 1295688288
mft at 1333708768
mft at 1423813568
mft at 1461881632
mft at 1667251058
mft at 1667254162
mft at 1844686208
mft at 1894484160
mft at 1953268000
Potential partition:
 1 P HPFS - NTFS          64319 227 17 185920 220  8 1953519616
 1 P HPFS - NTFS          64993 214 34 186594 207 25 1953519616
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
Status: OK
Status: OK
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
Status: OK
Status: OK
Is there anything else I can do to try and salvage the drive? PhotoRec grabbed a lot of stuff after the reboot so perhaps it isn't entirely a lost cause. Based on the end of the log it might seem like the right idea is to run Repair MFT but I'm not quite confident enough in that assumption to know for sure.
Re: "Can't open filesystem. Filesystem seems damaged" Options after Rebuild BS
slowmotion wrote: 15 Apr 2021, 02:24 Is there anything else I can do to try and salvage the drive? PhotoRec grabbed a lot of stuff after the reboot so perhaps it isn't entirely a lost cause. Based on the end of the log it might seem like the right idea is to run Repair MFT but I'm not quite confident enough in that assumption to know for sure.
Apart from running Photorec you can run any commercial recovery software.
I can't find the following message in the source coude:
"Failed to startup volume: Input/output error."
It could either mean physical dammage or maybe caused by trying to access a sector number beyond the disk boundaries I think.
To learn about possible physical dammage which would be a reason to duplicate the drive as described in the manual you would run smartmontools:
viewtopic.php?f=5&t=10910
slowmotion
#3 Post by slowmotion »
recuperation wrote: 15 Apr 2021, 22:44 To learn about possible physical dammage which would be a reason to duplicate the drive as described in the manual you would run smartmontools
I finally got around to running smartmontools with the drive, I'm not entirely sure how to read it although I'm guessing the presence of Pre-fail attributes means that something has gone kaputt in there. This is the log
smartctl 7.2 2020-12-30 r5155 [x86_64-w64-mingw32-win7-sp1] (sf-7.2-1)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Blue
Device Model:     WDC WD10EZEX-08WN4A0
Serial Number:    WD-WCC6Y3AYY40S
LU WWN Device Id: 5 0014ee 2ba6d7a6b
Firmware Version: 02.01A02
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Apr 24 21:16:53 2021 GMTDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(11880) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 123) minutes.
Conveyance self-test routine
recommended polling time: 	 (   5) minutes.
SCT capabilities: 	       (0x3035)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   168   166   021    Pre-fail  Always       -       2566
  4 Start_Stop_Count        0x0032   094   094   000    Old_age   Always       -       6179
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       14765
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1019
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       55
193 Load_Cycle_Count        0x0032   188   188   000    Old_age   Always       -       36043
194 Temperature_Celsius     0x0022   116   110   000    Old_age   Always       -       27
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     14569         -
# 2  Short offline       Completed without error       00%     14546         -
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Any idea where to go from here?
I can't find any indication of your drive failing within this smartmontools log file.
slowmotion
#5 Post by slowmotion »
recuperation wrote: 25 Apr 2021, 11:07 I can't find any indication of your drive failing within this smartmontools log file.
Well that's good to hear, at least. Should I try Rebuild MFT?
#6 Post by recuperation »
I would start running deep search to see if there are readable partitions.
Instead of of playing around with a disk that contains data that needs to be recovered I would duplicate it and play with the duplicate.
