Hey, I Plugged my phone USB, and seems that it Shortened my computer for some reason and now my external hard drive (2TB) is changed to raw
it happened 4 days ago and I did some runs with testdisk on intel partition and deep search but nothing found now he auto select EFI GPT so I tried it and he showed me one partition but it was empty so now I run a deep search
there is something else that I can do to recover the drive ? or it's lost?
Hard drive changed to raw
Re: Hard drive changed to raw
Any help?
I tried with icare recovery and getdataback both of them found nothing
I tried to RebuildBS with NTFS but nothing worked
what should I do ?
what should I do ?
I think I have the same problem. I followed a video from youtube that looked exactly the same as my problem and the testdisk found my partition name, but after a reboot nothing had changed and in my log file shows some errors:
Hope someone here can suggest something...
Thu Apr 22 13:22:36 2021
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=238927933440
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1069286400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000395698176
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - KINGSTON SA400S37240G, S/N:50026B738005099F, FW:SBFKB1E1
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate Expansion, S/N:NA889QBY, FW:9300
Disk /dev/sdb - 2000 GB / 1863 GiB - Seagate Expansion
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 243201 13 12 3907022848 [2TB - A]
NTFS at 0/32/33
filesystem size 3907022848
mftmirr_lcn 2
file_pread(5,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(5,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(5,8,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(5,8,buffer,3907030912(243201/108/44)) lseek err Invalid argument
file_pread(5,7,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(5,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(5,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(5,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(5,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(5,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(5,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 243201 13 12 3907022848 [2TB - A]
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 0 32 32 243201 13 12 3907022849
5 L HPFS - NTFS 0 32 33 243201 13 12 3907022848 [2TB - A]
Now after deep scan i get this two things but I don't have linux in this drive and when I click on them its saying that no partition found or selected for recovery
what should I do ?
what should I do ?
- Screenshot_72.png (22.04 KiB) Viewed 2866 times
